You should upgrade or use an
alternative browser .
two things that pop up everytime I start up my laptop.
now that I got my laptop back and runnin again I wanna jus take this time to clear EVERY little problem I seem to be having. This one has been happening for a couple weeks and its not a big problem
its just really annoying.
Right when I start up my laptop, two things pop up
one being, as soon as I log in a pop up comes in the middle of my screen saying:
TaskBarIcon - Access Is Denied
and then the other one that pops up is this
can someone help me out so I can get these pop outs the **** outta my life.
Eye know, eye know
Have you tried disabling whatever is in the startup tab through msconfig and then re-enabling them one at a time?
(Start>type 'Msconfig' in the search bar >Startup tab and untick the boxes)
I'd also navigate directly to that file and check the properties> details and see if it points to a particular app.
It's a sus looking file, so I also wouldn't rule out malware/virus (even if AVG doesn't detect it.)
i7 3770K HT ON 4.7GHz
P8Z68 Deluxe Gen 3
8GB G.Skill Ripjaws X 2133mhz
X-FI Forte + ATH-AD900
1920*1200 / 1920x1080
Corsair AX1200W
Lian Li PC-V1020A
Laptop Specs:
Clevo Sager P170HM //
17.3 Matte 1920x1200 //
i7 2720QM // 8GB 1333mhz //
Dedicated GTX 485M //
Samsung Story 2TB USB 3.0
I'm thinking along the same lines of malware, spyware and or virus as well.
Self built
AMD Athlon 64x2 6000+ 3.0ghz
Asus M4N78 Pro
3Gb PC2-5300 DDR2 @ 667mhz
VIA HD Audio
OEM HP
OEM HP
