UAC, imageres.dll, messed up controls..Help please
Azuth
So I'm sure people have had similar posts of some tweak going into his OS system files and changing things and now screwed up their OS. Well, here's another one :huh:
I found a cool Vista theme I wanted to try out. So I followed the directions but made a mistake or two. I had to download Windows 7 Power Tool Ultimate 2.3 if that matters at all. That whole process in trying to get this vista theme I think I did correctly.
However, I had to 'Take Ownership' of imageres.dll and change the name, and then put the new imageres.dll into system 32. Well, a) the new imageres.dll wouldn't copy into it, it said it did, but the new file never popped up. But this could've been a result of..b) I restarted after thinking I was done, and when it loaded all of my UAC controls are gone. As are some icons and themes and stuff. Which isn't my main concern right now. I have no admin controls, I can't even open anything that requires that. And everything just 'error fails' and such. Can't do System Restore.
I even went to see if I could Enable or Disable UAC (which I was supposed to do in the beginning of trying to put this theme in) and the C:\ box says 'Access denied'.
Sooo.. Idk what to do. And I don't have a Vista disc to do the fix it thing.
Brink
Staff member
mvp
Hello Azuth, and welcome to Vista Forums.
You might see if creating a Vista Recovery Disc to use to do a System Restore at boot using a restore point dated before this problem instead may be able to fix it for you.
  • Show second system?
    Yes
    Operating System
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
    Operating System
    Country Flag
    usa
    State/Region Flag
    us oklahoma
    Gender
    Male
    Yes
    Operating System
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
    Operating System
    Country Flag
    usa
    State/Region Flag
    us oklahoma
    Gender
    Male
