UAC Replacement?
Barman58
Staff member
Hi All, :D
With all the discussion around the forum about the pros and cons of vista's UAC, the news of a better alternative, when it arrived in my inbox today, (from Technibble), looked to be a perfect answer.
However a look around the web found this information on the package, (Smart UAC Replacement), found this warning about the developers of the package.
The package looks like a perfect answer to some of my annoyances with UAC and is available / recommended on sites I would normally class as trusted, so wanted to ask if anybody has any further information or comments.
    Windows 10 Pro x64 1909 - 18363.488
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Asus nVidia GTX750TI-OC-2GD5 (2GB DDR5)
    Samsung 32" TV
    Internal
    Crucial CT256MX100SSD1 256GB SSD,
    Seagate ST2000DM001-1CH1 2TB,
    External (USB3)
    Seagate Backup+ Hub BK SCSI Disk 8TB
    2.5/3.5 Hot Swap Cradle, USB3 + eSata (client HDDs)
    NAS 4TB
    68 MB Down 18.5 MB Up
NormCameron
I agree this looks sooo good, but, do we trust the provider? I don't think I will be the first one to try it out.
    Scratch Built
    Intel Quad Core 6600
    Asus P5B
    4096 MB Xtreme-Dark 800mhz
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
Dwarf
The Contemplator
STEER WELL CLEAR. This feature of Vista, UAC, is tightly integrated into the OS Kernal and as such can grant/deny access to system resources. It controls such things as the installation of programs, modifying certain areas of the registry and other important routines. This is to prevent the casual user from deliberately accessing these things without intention. A replacement like this, whilst it may appear to operate correctly, could also be granting unwanted access to certain parts of your system behind your back. In other words, it could be behaving like a Trojan. I recommend that you keep the UAC provided by Microsoft and to check the Microsoft website for any information about alternatives
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
.Joe
1337 spammer
I too would recommend against replacing the built in UAC with a program that is produced by a company who has other programs flagged as evilware. It would be too easy for the company to program in permissions which bypass normal UAC operation.
    Intel Q6600 Quad Core 2.4 Ghz
    Dell 0TP406
    Nvidia 8800 GT 512 MB
    Dual Dell 22" Widescreen
    3360x1050
    320 GB Internal Main
    500 GB USB External
    160 GB USB External
    2TB USB External
    DSL 3MB
Barman58
Staff member
Dwarf, I agree with you totally, my main reason for the original post was as a warning to others of the company behind a seemingly useful and well presented tool. Interestingly the original Technibble blog post has been removed. so maybe they did some further research too.:D
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    Samsung 32" TV
    Internal
    External (USB3)
    NAS 4TB
NormCameron
Thanks for the warnings. I have noted the consistent theme in these forums of NOT disabling UAC and the advice removes any temptation that might linger.
    Scratch Built
    Asus P5B
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
