Umans web TV downloader.
Oldschool297
I have a problem running Umans webb TV downloader program that crashes every time i try to open it. I have Visual c++ installed. I have tried 2 different hard disks on the same computer and it doesn't work.
But on a other computer a pentium 4 2.8ghz it works. Can my 1,89ghz processor be without some functionality for it?
    Windows Vista ultimate.
I couldn't find anything on the system requirement or if it even supports Vista. I would suggest contacting their support.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
I have it installed and working on my compaq d530 with Vista but it don't work on my other two hard drives with the same Vista..i have Visual c++ 2005,2008,2010,2012,2013,2017 installed on the two hard drives. Will check the working ones.
I wonder if posting at www.uwtd.me\ would be helpful?
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
Sorry, but I don't know enough about it to speak about it. As I stated I couldn't even find system requirements and their webpage isn't in English. However to answer your question, if your processor isn't fast enough performance would be degraded and the software might not even be functional. Outside of that I would suggest contacting their support and/or their forum.
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
Just wanted to mention that if I search on- Umans webb TV
in Firefox using Bing, it suggests the UTWD Forum (the link I provided) and gives a Translate this page option. Converts it from Swedish to English nicely.
I wonder how Oldschool297 is making out on this and what the specific symptoms of the crash are.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
