unable to do a checkdisk
JRCharlie
Hi all
When I try to run the checkdisk I get this error.
The type of the file system is NTFS
Cannot open volume for direct access.
Can someone help me with this.
Thanks
    Gateway p-6829h
    Intel Core2 Duo Cpu
    3GB
richc46
Welcome
There are two types format fat32 XP and older
NTFS Vista and forward.
Are you somehow using Vista to ck an old drive
or are you using an old chkdsk, maybe from XP to check a new Hard Drive?
JRCharlie
Thanks for your quick reply richc46
I am using Vista for sure I just don't know what's the format on it.
Since this is not my pc I need to see what is the format on it.
    Gateway p-6829h
    Intel Core2 Duo Cpu
    3GB
JRCharlie
I finaly was able to check the formmat on the computer.
and it is a NTFS format.
    Gateway p-6829h
    Intel Core2 Duo Cpu
    3GB
richc46
richc46
Can be a false alarm, but back up your stuff. Good luck
richc46
Boatdude
How did you run the check disk? Through cmd or a progam?
    Acer Espire 7730ZG
    Intel Pentium Dual CPU T3400 @2.16GHz
    1T
    GeForce 9300M GS
    C:\
    D:\
    Trust
richc46
Did you test the hard drive?
