Unable to system restore
patch41
Vista Pro
Hi folks,
when i try to do a system restore, and after it going through the motions and restarting, I get a popup box stating, an unspecified error occurred during system restore try a different restore point, I have tried three different restore points with the same results, Any suggestions would be appreciated,thanks. Patch41.
Have you tried running it in Safe mode?
    Advent
    AMD Phenom X4 9550 2.8Ghz
    FOXCONN A6VMX (Socket 940)
    4.0GB RAM
    256MB On-board ATI Radeon X1200 Series
    UnKnown
    19" TFT Mointor
    1400 by 900
    500GB Western Digital WDC
    HP Keyboard
    Mobile Broadband via Vodafone
    250GB External Hard-drive
Thanks for your suggestion wizzkid, did it in safe mode and it worked, But i was curius as to why i cannot get it working in regular mode, So i looked into brinks tutorials on system restore,and as soon as i went into it i got a popup box stating the task image is corrupt or has been tampered with (see attachment) anybody got any suggestions , I did run a sfc/scannow which came up clean,thanks. Patch41.
This is a Common Problem with Task Schedular
Please follow the following techniques to solve the problem with Task Schedular:
Ronnie Vernon - Microsoft Technet said:
Open the Task Scheduler.
On the View Menu, select the 'Show Hidden Tasks' option.
In the left side menu, select 'Task Scheduler Library'.
In the Center section, right click the 'User_Feed_Synchronization' task and select Delete.
Exit the Task Scheduler.
Next, select Start / Accessories. Right click 'Command Prompt' and select the 'Run As Administrator' option.
Click 'Continue' on the UAC prompt.
In the command window, type the following command.
msfeedssync enable
Press ENTER.
This command will replace and refresh the 'User_Feed_Synchronization' task.
This will not affect the RSS Feeds you are subscribed to.
Original Source = Vista Task Scheduler task image is corrup
Hope This Helps,
Josh
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW (1440x900@60Hz)
    Novatech Night
    Dell HID-compliant mouse
Thanks for your reply Shadowjk,I could not find a user feed synchronization task, But did find user task (running), enclosing attachment could you tell me if this is the right one, appreciate it, thanks. patch41
To find the User feed you have to click View> Show hidden Tasks
And then in the left hand pane click Task Schedular Library and you should find a Task labeled User Synchronization Feed
    AMD HD Radeon 6870
    Novatech Night
Thanks for you time Shadowjk, for a minute i thought i was going nuts i just could't find it, So i went to my wifes PC, and sure enough its there, she has the same os, as me vista 32-bit premium, mine is missing, I tried going to cmd and type in what you recomended,but its still missing, any suggestions, thanks. patch41
Do you still receive the Same error?
    AMD HD Radeon 6870
    Novatech Night
Hi Sadowjk, thanks for your time and effort its so appreciated,user feed syncronization is still missing and enclosing attachment popup box error,thanks patch41
    AMD HD Radeon 6870
    Novatech Night
Yes i tried tried that, restarted the computer, still missing user feed synchronization task,maybe i should try microsoft vista repair disc, Its just that it takes about 4-5 hrs and then i have to install all the updates which takes another few hrs,I did it once before, But i do thank you for your help, patch41
