Uniblue speedupmypc won't load
floridapossum
I keep getting a net framework 3.5 error. It just says "net framework setup error", no number or anything. I don't know what to do. Can someone help me please?
H2SO4
A bit of a numpty
"SpeedUpMyPC" sounds like confidenceware. I'd suggest you reevaluate why you're trying to install that thing in the first place. If you have a speed problem, you might be better off to describe the situation so that someone can try to help you with the real issue.
