Solved Uninstalling Optional Updates
Fred44
I was reviewing my Windows update history and found a lot of updates listed as "optional". This is strange because eveytime I receive the prompt that new updates are available, I only install the ones marked "important". When I click on my list of installed updates (where you can delete them) the list looks completely different amd they are not listed as important, recommended, or optional here. Is there a way to remove thes optional updates to free up hard drive space or is it a waste of time? Are these updates taking up enough space to make it worth the while to jump through all the necessary hoops to uninstall them?
    HPs3700y Slimline
    AMD Athlon64 X2 (B) 50000+ 2.6 GHz (65W)
    Asus M2N61-AR
    3 GB
    NVDIA GeForce 6150SE nForce 430 (Integrated on motherboard)
    High Definition 6-channel audio ALC 888S chipset
    SAMSUNG SYNCMASTER 914V FLAT PANEL LCD
    1280 X 1024
    320GB SATA 3G (3.0 Gb/sec)
    160W
    Logitech Marble Mouse
    HP
    Broadband Cable Connection (256 Kpbs?)
    Not sure what case or cooling means. Could not find in any documentation. The keyboard is the standard that comes with the HP Slimline.
Brink
Staff member
mvp
Hello Fred,
What are the optional updates for?
Some of these are recommended to install as well. For example, definition updates for MSE or Windows Defender.
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
Fred44
Hello Fred,
That's what they are...definition updates for MSE.
    HPs3700y Slimline
    Asus M2N61-AR
    3 GB
    1280 X 1024
    160W
    HP
Brink
Staff member
mvp
You would want to keep them. These new definitions are what keeps MSE updated to be able to help detect new malware and viruses.
If you are tight on HDD space, then you might see if the tutorial below may be able to help you free up some space where you are able to. It applies to Vista as well.
Hard Disk Space - Free Up and Recover - Windows 7 Forums
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
Fred44
When I saw they were MSE updates I thought it woud be best to keep them. thanks for the info.
    HPs3700y Slimline
    Asus M2N61-AR
    3 GB
    1280 X 1024
    160W
    HP
Brink
Staff member
mvp
You're welcome. :)
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
