Uninstalling x86 programs: not listed
befuzled
2
Hoping some one can assist... Just got my new Vista Ultimate x64 computer. I'm new to Vista and learned that the system sets up 2 program files: one for 64x bit and 1 for 32 bit programs. My issue is HP has loaded a whole slew of crapware and I want to clean it out... I can see it in the x86 files (as well as numerous shortcuts on my desktop) but I cannot find the programs in the add/remove program utility. I had CCleaner as well and they are not listed in there either.
Additionally, when I navigate to the programs I do not see any options to uninstall. Is there a way to get these programs sitting in the x86 folder to show up in my uninstall list?
Some examples of what I'd like to remove are:
Easy Bits for Kids
JunoPreloader
MSN toolbar
Netzero preloader
Online Services
Ebay
If I just delete these folders from the x86 folder they dont uninstall, correct?
any direction or assistance is greatly appreciated.. Thanks!
befuzled
2
think I solved my issue.. I dont think the items in question are really installed.. they are trials so they just link in to the shortcuts. I deleted the shortcuts and removed the folders in the program list.. we'll see..
JMH
Banned
2,141
    IntelCore 2DuoT8300@2.4GHz x2
    1440 x 900
    SPECS.
    Drive 1. 298.09 GB Fujitzu MHZ2320BH G2 ATA Device
    Drive 2. [ All as above.]
    CONFIG. C:\287.65 GB, D:\298.09 GB, E:\10.44 GB.
    Laptop / notebook.
    Stock.
    IBM enhanced
    ADSL [ Too slow.]
    Webcam.
MilesAhead
Eclectician
2,442
You might also want to look at PC Decrappifier and Norton Removal Tool if you don't want Norton av/firewall/whatever. Uninstall by itself won't get rid of Norton. You have to download the removal tool and keep running it until all entries in the registry are removed. Otherwise, you can find yourself with double boot time as the system waits for drivers no longer on the system to load. Enable boot logging if you have long bootups and see if that's what it is.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
