Solved Unknown errors when updating Vista 32
oxicottin
Unknown errors 643 and 646 when updating Vista 32
Hello, just recently I haven't been able to update vista, I keep getting unknown errors. I look at the updates that failed and they are as follows. What can I do to fix this? Thanks!
Try installing one update at a time
Try with anti Virus turned off
If it just started use system restore to go back to when it was working and then install one at a time. One at a time is always good advice, due to potential conflicts when the computer has to be turned off to complete an update.
Try in safe mode.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
ilikefree that worked.... Thanks everyone! Here is what I did but I only had to change the first reg key and not the last two.
[FONT=&quot]Solution:[/FONT]
[FONT=&quot]1. [/FONT][FONT=&quot]Open the Registry editor. To do so, Click Start, type regedit in the Start Search box, and then click regedit.exe in the Programs list.[/FONT][FONT=&quot]In the User Account Control dialog box, click Continue.[/FONT]
[FONT=&quot]2. [/FONT][FONT=&quot]Navigate to the following registry keysHKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders[/FONT]
[FONT=&quot]3. [/FONT][FONT=&quot]The correct and default value forAppData should be %USERPROFILE%\AppData\Roaming. To change the value, double click on Appdata, then change the string in the value data field.[/FONT]
[FONT=&quot]4. [/FONT][FONT=&quot]Close the Registry editor, and try again Windows Update again. (A reboot shouldnot be required.)[/FONT]
[FONT=&quot]5. [/FONT][FONT=&quot]If the problem persists, repeat the steps 2 through 4 with the following registry keys:[/FONT]
· [FONT=&quot]HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders\[/FONT]
· [FONT=&quot]HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders\[/FONT]
    LENOVO 64734VM
    15 inch
    External Speakers
