Unlocker explorer' extension shell
Lio
Hello guys! newbie here :)
I'm tryng to solve some issue on my Vista x64 based pc.
I've installed (as always in all my pc) the Unlocker prog ( HERE )
No problem during the install, Then I setup the program to work with Admin previlege (Run as administrator) but........... I don't have any unlocker shortcut in my explorer extension (to be more clear....I have no Unlocker choice with right click on the file I want to unlock).
I have the Unlocher assistent in the app Bar, but it is useless.
I see that all you here speak about Unlocker so I can thinks thato many of you have it working.
Can you please help me? (despite my horrible english :o:p)
Thanks in advance
Brink
Staff member
mvp
Hi Lio,
Did you already do the instructions from the program's site?
How to make Unlocker work on Windows Vista? You need to deactivate UAC globally for the whole system or locally just for Unlocker. Globally, go to "Control Panel" then "User Accounts" then again "User Accounts" then "Turn User Account Control" and set it to Off, then restart your computer. Locally go to the Unlocker install directory (usually C:/Program Files/Unlocker), right-click Unlocker.exe, select Properties, and on the "Compatibility" tab, under "Priviledge Level" enable "Run this program as administrator". Click "allow" everytime you will get the UAC prompt to ask if you want to run Unlocker.
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
Lio
Hi Brink, thanks for your reply...
Yes I did it.
After the install I did the "run as Administrator" but I don't have it in the right click.
I also tried to run in compatibility mode (XP service pack 2)..... nothing!!!
Maybe I'm a stupid woman, but there is something wrong....:confused:
Brink
Staff member
mvp
Lio,
While your in the Compatibility Mode window, see if you check the Run this program as an administrator box at the bottom. Then see if it will run ok.
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
Lio
I post some screen, so you can see how I've my setting done. Sometimes my english is too bad to be clear :o
and this is the only (useless...) extension that I've in explorer (right click).
In this way my unlocker don't run.
This morning when I turn on my Vista pc, for the first time I have a UAC windows asking a permit for Unlocker assistent .....
This things make me mad :confused:.......
Unlocker is installed, it's in my explorer shell, but it's not setup to do its work..........
I've uninstalled and reinstalled many times without no change......
There is something that I'm doing wrong. :cry:
Thanks for your support, Vista 64 make me crazy in many things, not only this one (like WD Button Manager permit, or The font Thing impossible setup etc).
I wait for all suggestion
Have a great day!
Brink
Staff member
mvp
Lio,
Uncheck the box for the XP SP2 compatibility and leave the Run as Admin. checked to see how that does. If this still does not get it to work, then you might send a email to the Unlocker support contact at their site to see what they say about it to.
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
Lio
Thanks! but I've already tried with all the different possibility, with and
without check etc.....
I really don't have any idea now......
I see that so many people have Unlocker installed with Vista64 and I don't understand why for me this is impossible.
Iìll try with Unlocker support but with my english....I'm not sure to have an answer!
however thanks for your help, much appreciated
Brink
Staff member
mvp
Lio,
Your doing great, I can understand your English just fine. I hope they can give you answer. It's probably just something simple somewhere.
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
Lio
I wrote to the author of this program and He has already answered: no word.... it's a very kind guy!
here his answer, so I hope it is usefull for all.
I am very sorry but Unlocker can not work yet on x64.
There is a bug that I need to fix. I have no ETA yet
since I am crunching in office like crazy.
Cedrick
So maybe that people with Unlocker running on Vista pc, have Vista 32....:sarc:
But I'm very sad, I'm used to have Unlocker.....:(
Thanks for tour effort
Lio
Brink
Staff member
mvp
Lio,
That would certainely explain why it would not work. LOL
Hopefully he will come out with a 64 bit version soon.
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
Hefty1
Thanks Lio!! Thanks for all your leg work on this......it was a great time saver. I was having the same issue, atleast I know why now.
TitusCicero
Yup, I have Vista 64 too and I too very much miss Unlocker. Does anyone know if there is a similar program that can perform the same tasks and functions as unlocker had?
Thanks
thanks for the info Lio, Its one of my favs also!
    INTEL CORE 2 QUAD Q6600
    ASUS P5K-E WIFI P35
    8GB DDR2 667MHZ KINGSTON
    Nvidia Geforce 8800GTS 512MB G
    1 x Western Digital 500GB 16MB SATA2
SONSiVRi
I deep searched but nothing found yet, there are so many similiar applications but none of them working. vista 64 is really going to be monopoly, monopoly on drivin us crazy. I wonder how they can success to deploy OS that doesnt fit anything on market.
Freelancer852
Vista Vet
Vista Pro
If you go to this page:
UNLOCKER 1.8.7 BY CEDRICK 'NITCH' COLLOMB
There is a comparison chat listing other "similar" programs. I'd suggest looking for one with the features you require (obviously they aren't as good as Unlocker) and check to see if it has 64bit support!
    Acropolis
    Intel Core i7-6800k @ 4.0 GHz
    ASUS X99-M WS
    32GB Corsair Vengeance 2x16GB
    ASUS GeForce GTX 1080 STRIX
    ASUS ROG Swift PG278Q
    2x 256GB Samsung 850 Pro (RAID 0)
    1x 500GB Samsung 850 Evo
    2x Western Digital RED 4TB (RAID 1)
    50TB File Server (Multiple RAID 6)
    Corsair AX1200i
    Corsair Air 240
    Logitech G502
    Razer Blackwidow X Chroma
    250Mbps Down | 15 Mbps Up
its been a few months since the last post here....did anyone find anything similar to unlocker?
Brink, is there a way to manually kill a dll file using CMD prompt or something? (unlocker saved me having to reboot various times in the past on my XP pc, but i keep getting stung on vista 64)
thanks
    ASUS P5K-E WIFI P35
Brink
Staff member
mvp
Hi BleepingCrazy,
Did you want to delete or kill the process for the .dll file?
If kill, then what is the full path of the .dll file? I'll see if I can post back a command that you can try to delete it with. :)
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
hi Brink, it varies, one in particular for example, is when updating ultraISO, it leaves "C:\Program Files (x86)\UltraISO\isoshl64.dll" and doesn't allow it to be deleted until a restart. killing it saves me restarting for nothing. (then I exit/restart explorer.exe)...voilà!
can you make a batch command that does both? (at least the 1st)....so then I could use that on other similar, frequently changed programs, etc.
EDIT: I've heard that Windows 7 has a "unlocker" of sorts as a default....anyone use that? pros/cons?
    ASUS P5K-E WIFI P35
