Unplugging cords
chimp78
I wonder what'd happen if I unplug the desktop tower cord from the power surge or electric outlet? Will I lose what I have in tower? I unplugged the desktop monitor cord from the power surge several times and nothing was lost, but I am not sure about the tower cord. The reason is because I need to move the table around in the room and need to unplug the cords. I am sure nothing will be lost if unplugging tower cord from the power surge or outlet because the table needs to be moved around in the room, something else like moving out of the house, etc if you know what I mean.
Also, what would happen if unplugging the cords from the desktop monitor and tower themselves, not from power surge/outlet? Would everything be lost? Much thanks.
    Dell desktop-XPS
    Intel Core 2 Duo-3.00GHz
    4.00 GB
    NVIDIA Geforce GTX 285
    450 GB
    Microsoft
    High Speed Verizon
richc46
Save everything, then turn everything off, using the approved procedure and then you can unplug.
As always, your important stuff should always be backed up. An unexpected improper shut down, and stuff can be lost.
Stuff can be lost for other reasons, too.
chimp78
Thanks, but are you speaking of first, second, or both questions?
And, what is using the approved procedure?
Thanks again.
    Dell desktop-XPS
    4.00 GB
    450 GB
    Microsoft
    High Speed Verizon
richc46
The approved procedure is to shut down, by clicking on shutdown, the way that you usually turn off the computer.
Once the computer is shutdown, you will not lose data by unplugging. If the computer is on, and you unplug, the computer, data can be lost.
