Solved Unplugging Modem from PC
VFN
Don't have a router and want to use the modem with an Xbox. Should I shut down the computer before removing the modem cable and before plugging it back in when I'm done with the Xbox?
Thanks.
    Vista Home Premium x64
    Dell Inspiron 546
    Sempron LE-1300
    2GB DDR SDRAM 800MHZ-2X1GB DIM M
    Integrated ATI Radeon HD3200
    VIA High Definition Audio
    Samsung 32" HDTV
    1366 x 768
    320GB NCQ Serial ATA (7200 RPM) w/ 16MB DataBurst Cache
Patonb
You don't have to, but it might not pick up the network when you replug the computer back in.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
VFN
Okay. I'll see what happens. Thanks.
    Dell Inspiron 546
    Sempron LE-1300
    Samsung 32" HDTV
    1366 x 768
