Unwanted odd pic's appear in slide show
groundhogday
Hi, i am a complete novice with pc's (please bear with me) and would appreciate any help, not sure if this is the right place to ask?
I have recently had strange pixilated images mixed in with our photos when playing music and selecting slide show, our photos appear along with random images, they are not coming from MY PICTURES folder as i have right clicked when the odd pic appears and they are coming from random folders that i can't find.
I thought the strange graphics were coming from itunes or Tom Tom so i have uninstalled them both...but the images keep coming.
How do i stop media center looking and producing these annoying images, any idea's anyone?
I am running 32bit Vista
Thanks in advance
richc46
groundhogday
Thanks for your reply,
I already have Nortons antivirus and scanned OK, what i have found out is the offending folder is in the WMC Picture Library under Program Files....looking into this folder revealed the same unwanted images!
Can this folder be taken out of WMC ? or how can i make the slide show not look at this folder?
groundhogday
Looking a little closer, the images are from many folders within the Program File folder, they are icons from eg:- Google, Ulead Photo (tons in there) , Microsoft Works and many programs containg graphic images...
Jakeman97
Hello groundhogday,
Well, if you really want to stop iWindows Media Center you can do it this way. Actually there are more than one way to disable Windows Media Center or prevent it from running in Vista. Because you said you were a 'newbie' I think this would be the easiest and sfest way for you.
Disable Windows Media Center Services
Open Services (type services.msc into Start Search). Locate all services related to Windows Media Center, such as Windows Media Center Extender Service, Windows Media Center Receiver Service, Windows Media Center Scheduler Service and Windows Media Center Service Launcher, then set their Startup Type to Disabled.
Personally I never use the WMC for a slide show. I just click on a picture in one of my folders and it opens in 'Windows Viewer', click on the big round button and it starts a slide show of only the photos in that folder. To quit just hit escape.
Have fun,
Jakeman97
    H1 HUMMER
    Phenom II X6 1055T
    GA-890FXA-UD5 AM3
    G.SKILL 4GB F3-10666CL8D-4GBHK
    XFX Radeon HD 5750
    On Board (works for me).
    Acer X223W
    2 Seagate Barracuda 7200.12 750GB \\ 2 Seagate Barracuda 500GB SATA3 7200.12
    Corsair HX 1000W
    Cooler Master 690II Advanced
    Cooler Master V8
    Microsoft
    Microsoft CA9-00001 Black 103 Normal Keys 3 Function Keys PS
    Fast DSL
    A work in progress and changing all the time.
groundhogday
Hello groundhogday,
Have fun,
Jakeman97
Thanks for your reply and help Jakeman97, the thing is i like to use and view my photos in WMC, would your suggestion disable my picture library in WMC?
The other picture program i use is Picassa, which is great, but i cannot make it randomise in Slideshow....is there any way of doing this? i have over 12,000 pic's!
Cheers
Jakeman97
Hello groundhogday,
Have fun,
Jakeman97
Cheers
Hi groundhogday,
YES, unfortunately it would completely disable WMC. I used Picassa a long time ago and have forgotten how it actually works. It was more of a viewer and less of an editor as I recall. I switched to Adobe Photoshop Elements 8 (not 'free') by any means; but it can really edit photos down to the pixel and also provides a great slide show.
Best of luck to you.
jakeman97
    H1 HUMMER
    Phenom II X6 1055T
    GA-890FXA-UD5 AM3
    XFX Radeon HD 5750
    Acer X223W
    Corsair HX 1000W
    Cooler Master V8
    Microsoft
    Fast DSL
groundhogday
Hi ...after doing a lot of searching on this forum i came across this thread from some guy who worked in microsoft i think.....he said press Start then in Search type %localappdata%%\microsoft\mediaplayer , then clear all the files but not the folders....i was a bit hesitant to do this as one of the files said "Database" i was scarred of loosing or stuffing my pc up!....but went ahead anyway....amazingly it has worked!!....it had removed that offending file "Program File" in Picture Library....problem solved.
I would like to thank that guy who posted that, it has been driving me and the wife mad ....
Thanks for your input Jakeman97
Jakeman97
groundhogday kudos to you for the research on that one. Enjoy your pictures.
jakeman97
    H1 HUMMER
    Phenom II X6 1055T
    GA-890FXA-UD5 AM3
    XFX Radeon HD 5750
    Acer X223W
    Corsair HX 1000W
    Cooler Master V8
    Microsoft
    Fast DSL
