Update Not Working 80040154
Kieran Top
Vista Is The Best
I been trying to update my Windows Vista but it comes up with that error while cheking for updates.
Edit: This happened for a week now not since I installed Vista The reason it says Never checked is because I reseted windows update to see if that will fix it but it did not
    Dell XPS 8500
    Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz 8 Cores
    Dell Inc
    16.3 GB
    NVIDIA GeForce GTX 750 Ti Superclocked 2GB Vram
    I don't know
    1 Sony TV
    1920x1080
    2x San disk SSD and an unkown HDD
    Dell XPS 8000
    3 Fans
    Logitech Hyperfurr G402
    Logitech K120
    200 Mb/s Download 20 Mb/s Upload
wither 3
I see you have SP2 installed. When was the last time you installed updates?
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Kieran Top
Vista Is The Best
A week ago
    Dell XPS 8500
    Dell Inc
    16.3 GB
    I don't know
    1 Sony TV
    1920x1080
    Dell XPS 8000
    3 Fans
    Logitech K120
Kieran Top
Vista Is The Best
Hi anyone
    Dell XPS 8500
    Dell Inc
    16.3 GB
    I don't know
    1 Sony TV
    1920x1080
    Dell XPS 8000
    3 Fans
    Logitech K120
lmacri
Vista Pro
A week ago
Hi Kieran Top:
Extended support for Vista SP2 ended in April 2017 so I wouldn't expect that Windows Update would have delivered security updates last week unless it was a virus definition update for Windows Defender or a patch for another supported MS product like MS Office, MS Silverlight, etc. Open your IE9 browser, go to Help | About Internet Explorer and let us know the Update Versions - it should be v9.0.60 / KB4014661 or higher as shown below if you received the last batch of security updates for Vista SP2 and IE9 for the April 2017 Patch Tuesday updates (released 11-Apr-2017).
When you post back also let us know if you have MS Office 2007, MS Office 2010 and/or the MS Office Compatibility Pack SP3 installed.
32-bit Vista Home Premium SP2 * Firefox ESR v52.4.0 * NS Premium v22.11.0.41 * MS Office 2003 Professional SP3
    32-bit Vista SP2 Home Premium
    HP Pavilion dv6835ca
    Quanta 30D2 (U2E1)
    3 GB RAM
    NVIDIA GeForce 8400M GS
    5 MBps
    Norton Security Deluxe v22.15.2.22
Kieran Top
Vista Is The Best
I was installing 200 plus updates and it failed and no updates are installed now but my anti viurs installed IE 9
    Dell XPS 8500
    Dell Inc
    16.3 GB
    I don't know
    1 Sony TV
    1920x1080
    Dell XPS 8000
    3 Fans
    Logitech K120
lmacri
Vista Pro
Hi Kieran Top:
Am I correct that you recently performed a clean reinstall of your Vista SP2 OS? Vista's Service Pack 2 was released in May 2009 and comes bundled with the old IE7 browser, and if I remember correctly the first Windows Update you run after SP2 is installed should upgrade your browser to the original build of IE9 (Update Version 9.0.1 / KB982861) from May 2011. If the last security update installed for IE9 is KB982861 then your Vista SP2 installation could still be missing several years worth of updates.
There is a known issue with Windows Update on Vista SP2 computers and the initial "Checking for updates..." phase can hang for hours (or even days) if there are a large number of updates available for download. Please see the step-by-step instructions on page 1 of m#l's thread Updates not working, it has been searching for updates for hours in the MS Answers forum for a possible workaround. Depending on the last time Windows Update ran to completion on your computer, you might find that all five Vista SP2 / IE9 security updates listed in STEP # 2 [KB3205638 (rel. 13-Dec-2016); KB4012583 (rel. 14-Mar-2017); KB4015195, KB4015380 and KB4014661 (rel. 11-Apr-2017)] are currently missing and will have to be manually installed before Windows Update can run to completion and patch your Vista SP2 OS to April 2017.
As noted in those instructions, additional speed up patches will have to be pre-installed before you run Windows Update if you have MS Office 2007, MS Office 2010 and/or the MS Office Compatibility Pack SP3 installed.
If the instructions in m#l's thread don't work please post back and let me know what method you used to reset your Windows Update components.
    Quanta 30D2 (U2E1)
    3 GB RAM
    5 MBps
Kieran Top
Vista Is The Best
Hi Keiran Top:
Yes But I was Installing Updates Then It Falied And Came With This Every Time I Try To Check For Updates And I Rember Installing The Lastes Update Engine Thingy But I Try The Link
    Dell XPS 8500
    Dell Inc
    16.3 GB
    I don't know
    1 Sony TV
    1920x1080
    Dell XPS 8000
    3 Fans
    Logitech K120
Kieran Top
Vista Is The Best
Hi Kieran Top:
Yeha I rember Installing The Updates Before The Links Are Purple and I rember This. I used This To Get Windows Update Working B4
    Dell XPS 8500
    Dell Inc
    16.3 GB
    I don't know
    1 Sony TV
    1920x1080
    Dell XPS 8000
    3 Fans
    Logitech K120
wither 3
Do you have Windows Installer 4.5 installed?
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Kieran Top
Vista Is The Best
    Dell XPS 8500
    Dell Inc
    16.3 GB
    I don't know
    1 Sony TV
    1920x1080
    Dell XPS 8000
    3 Fans
    Logitech K120
lmacri
Vista Pro
How do I check?
Hi Kieran Top:
Click the Start button, choose Run, type msiexec in the box and click OK. A window will open that displays the version number of your Windows Installer (also known as the Microsoft Installer or MSI) in the first line . The file is located at C:\Windows\System32\msiexec.exe.
I think Windows Installer v4.5 was originally bundled with Vista SP1 back in 2008 so if your SP1 and SP2 service packs both installed correctly you should already have v4.5.x.
    Quanta 30D2 (U2E1)
    3 GB RAM
    5 MBps
wither 3
From what I could see, 4.5 is for SP2. For information, I have 4.5.6002.19...........
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Kieran Top
Vista Is The Best
Hi Kieran Top:
Yes I do I have version 4.5.6002.19424
    Dell XPS 8500
    Dell Inc
    16.3 GB
    I don't know
    1 Sony TV
    1920x1080
    Dell XPS 8000
    3 Fans
    Logitech K120
wither 3
Ex_Brit has both SP1 and SP2 for download. I assume the SP2 has all the updates since it was released. This site- claims to have SP2 with all the updates since it was issued-
Windows Vista Service Pack 2 (Windows) - Download
Strangely, I couldn't find SP2 at a Microsoft website which purports to have all the updates up to April 10 of this year.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Kieran Top
Vista Is The Best
    Dell XPS 8500
    Dell Inc
    16.3 GB
    I don't know
    1 Sony TV
    1920x1080
    Dell XPS 8000
    3 Fans
    Logitech K120
lmacri
Vista Pro
I need The x64 version
Hi Kieran Top:
Forum Administrator Brink has pinned posts at the top of this Windows Update for Vista board with links to 32-bit and 64-bit installers for:
Service Pack 1: Why SP1 may not be available for you and how to get it
Service Pack 2: Download Available for Standalone Vista SP2
I'm a bit confused about what you've done to this point to re-install Vista SP2. If you go to Control Panel | System and Maintenance | System does it say if you have SP1 or SP2 installed? SP1 is a pre-requisite for SP2 so SP1 must be installed before SP2. From my 32-bit Vista SP2 computer:
    Quanta 30D2 (U2E1)
    3 GB RAM
    5 MBps
Kieran Top
Vista Is The Best
Hi Kieran Top:
Forum Administrator Brink pinned posts at the top of this Windows Update for Vista board with links to 32-bit and 64-bit installers for:
I'm a bit confused about what you've done to point to re-install Vista SP2. If you go to Control Panel | System and Maintenance | System does it say if you have SP1 or SP2 installed? SP1 is a pre-requisite for SP2 so SP1 must be installed first. From my 32-bit Vista computer:
    Dell XPS 8500
    Dell Inc
    16.3 GB
    I don't know
    1 Sony TV
    1920x1080
    Dell XPS 8000
    3 Fans
    Logitech K120
lmacri
Vista Pro
I have SP2
Hi Kieran Top:
Then please go back to post # 7 and try my suggestion to install the five speed up patches recommended on page 1 of m#l's thread Updates not working, it has been searching for updates for hours in the MS Answers forum as a first troubleshooting step.
Davide Bianchi's recent 15-Oct-2017 post <here> on page 62 of m#l's thread confirms that those instructions should fix the slow Windows Updates on a machine with a clean re-install of Vista SP2. As I noted in post # 7, you will have to include KB4014661 (Cumulative Security Update for Internet Explorer 9: April 11, 2017) along with KB3205638, KB4012583, KB4015195 and KB4015380 since your IE browser has already upgraded from IE7 to IE9.
The two main factors contributing to the "Checking for updates...." hangs for Vista SP2 (aside from hardware considerations such as 32-bit vs. 64-bit architecture, CPU speed and amount of RAM) are:
  • Microsoft has not performed regular purges of expired (superseded) updates in Vista's update catalog wsusscn2.cab since Win 10 was officially released on 29-Jul-2015
  • The Windows Update Agent (wuaueng.dll) v7.6.7600.256 for Vista SP2 has not been updated since June 2012 and is not optimized for computers with slower CPUs and limited amounts of RAM
As far as I know these Windows Update problems on Vista SP2 computer have nothing to do with the Windows Installer msiexec.exe.
    Quanta 30D2 (U2E1)
    3 GB RAM
    5 MBps
Kieran Top
Vista Is The Best
Hi Kieran Top:
I did that before but now it says that the updates are not for you system
    Dell XPS 8500
    Dell Inc
    16.3 GB
    I don't know
    1 Sony TV
    1920x1080
    Dell XPS 8000
    3 Fans
    Logitech K120
