USB install problems
georgej
I am unable to get the following to work with Vista
1 Tomtom 910
2 Sony P10 camera
3 HP 1210 all in one printer scanner etc
I have tried contacting the above companies help sites and web site but the information they give me does no work. I had no problems running the above with XP. I am a t a loss on what to do so help please
This Tomtom GO 910 is a GPS device? I cannot find any drivers at all for it on the webpage, only software (and I doubt this is Vista64 compatible)
When it comes to the Sony D10 (dat player?) It seems to be way to old to even have native XP support :-)
When it comes to the HP1210 AIO printer it has native Vista support :-)
If you cannot even see them when you connect them to the computer you should probably try updating or installing your USB \ Chipset drivers :-)
