USB Keyboard not function
CatFish
3
OS: Vista Home sp2 x32
Keyboard: It's some USB hello kitty keyboard, on the package, it listed as compatable with vista.
Problem: I plugged the keyboard in on my vista, windows automatically search for drivers. It popped up saying it's ready to use, but I tried typing on the keyboard, nothing happen. Tried pressing the cap key, no light either.
I tried plugging in another usb port, does the same thing. (usb port is not defective)
I tried plugging the keyboard to my xp laptop, everything installs well and keyboard works. (the keyboard is not defective)
I tried to update the usb driver under device manager. although it prompt to say the drivers are updated, but the keyboard still not working.
Patonb
2,245
In device manager, try removing it, aka uninstall it, and then let windows try to refind it, click the scan for new hardware icon.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
ilikefree
2,877
Location
New Zealand
When it installs does it make an entry in C:\Program Files?
If it does try right clicking on the .exe , go to properties run in compatibility mode.
Set it to XP in the dropdown box.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
CatFish
3
Not that I known of.
This USB keyboard doesn't have a cd software, I suspect it installed like plugging a genuine USB hardware
roy69
47,65,65,6B
2,607
Location
uk
Try plugging it into the back of the computer using a usb adaptor if you have the PS/2 type connector present on your motherboard.
If this type of connector is not on your motherboard reset the computer with the keyboard connected, as the computer run it post test see if you can access the bios using it. You may have to turn on legacy bios control if it will not work.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
    Creative Inspire 7.1 T7900 Speakers
    Trust Graphics Tablet
