Solved USB Sound Card
Fiery
Gday fellas
At the moment I have an Sound Blaster X-Fi Xtreme Audio installed,an Edifier Speaker System, is using my Soundcard.
A SteelSeries V2 Siberia Headset, and two generic USB Sound Card Adapters.
The one that will pick up my mic, is being held together with Sticky Tape, the second one, while Vista can hear it, Skype cannot.
I use Skype quite a bit, and my speakers are playing music 24/7.
So I am after a USB adapter that will take the two 3.5mm jacks, and not only hear but also allow me to speak.
I have been looking at the Creative Sound Blaster Play! USB Sound Card and the Creative Sound Blaster X-Fi Go Pro USB Sound Card 3D. What I would like to know is if both will run off a USB 2 Hub. The generic one I have at the moment is, I have USB 2 Hubs galore, and as I quite often take my headset with me when I travel, the ease of unplugging it from a Hub is essential.
The other one I am looking at is the SteelSeries Siberia USB Sound Card. Once again, I need it to run off a Hub.
Or can anyone give me a working alternative?
    Homebuilt
    AMD Phenom II x 4 965
    Gigabyte GA-MA770T-UD3P
    4GB DDR3
    Nvidia GeForce GTX 750 TI
    Creative Sound Blaster X-Fi Xtreme Audio
    Phillips 19"
    1280 x 1024
    1 x 128GB Samsung 840 Pro SSD
    1 x 1TB Sata
    1 x 160GB IDE
    1 x 2Tb WD External My Book Elite
    1 x 1TB WD External My Book Elite
    1 x 4TB WD External My Book
    Thermaltake 850W XT
    Coolermaster Storm Sniper Black Edition
    AC-ALPINE-64PRO ARTIC COOLING
    Microflacid Sterile
    12 year old Compaq, cant see any of the letters anymore :)
    ADSL2+
    My husband and I divorced over religious differences.. He thought he was God and I didn't.
Lottiemansion
Sounds like a good solution & should work fine. All I would ensure is that the USB hub is powered up from an external supply, thats all..
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    BluRay & DVD Weiters
    40 Meg
Fiery
Gday Lottie :D
All of my Hubs are AC powered, but you never answered my question :confused: which card should I go for?
I have contacted Creative asking them the same question, SteelSeries for some reason the "contact us" isn't working :(
    Homebuilt
    4GB DDR3
    Phillips 19"
    1280 x 1024
    1 x 1TB Sata
    1 x 160GB IDE
    Thermaltake 850W XT
    Microflacid Sterile
    ADSL2+
Lottiemansion
    40 Meg
Fiery
Sorry for the omission!
I would go for the Sound blaster play as this device appears to be "Easier" on the main processor
Sound Blaster Play! External USB Sound Card | Creative Store (UK)
lol you're foregiven *bites her tongue*
I have scoured the Creative website, searched google, but still cannot find an answer to the question, will it work off a USB 2 Hub. I know lots of sound cards, need direct access into a USB port.
This is something I do not want, because I take my headset on my travels I want something will work from a Hub (ease of access).
    Homebuilt
    4GB DDR3
    Phillips 19"
    1280 x 1024
    1 x 1TB Sata
    1 x 160GB IDE
    Thermaltake 850W XT
    Microflacid Sterile
    ADSL2+
Lottiemansion
Hi again,
This is the response from Creative.
Thank you for contacting Creative Labs.
We are pleased to know that you are interested with one of our Sound Blaster Play!.
The Sound Blaster Play! uses PC USB bus-powered for main USB audio (400mA required). It is still highly recommended to connect directly the soundcard to the PC.
    40 Meg
