hi im not sure if this is in the correct forum, i dont really use these much
im having a prob with vista hm premeum 32bit
im having a problem with one of my usb ports. when using none of the ports at all, vista will randomly "find" a usb device and tell me that it can perform faster. even though there is nothing plugged in
(spooky)
so after much confusion, i tried to plug my external hard drive in to all my ports (1tb buffallo if your woundering) and when i plugged it into the last one, my computer got a blue screen, with writing on it ( not the blue screen of death tg) saying that it has a problem with one of the usb drivers, and that it needs to shut down to save the computer it only does this when i use this port though. otherwise i just get the "this device can perform faster" thing popping up ever 10 mins or so
i really cant handel loosing one of my usb's so much help would be appriceated
