egydarceyes
Hello folks,
I'm running Vista Home Premium and I've had a little issue with the quick launch buttons on my HP and I needed to reinstall the OS but failed miserably. I had to send in the laptop and they told me all they did is update the BIOS and it worked fine.
Well ever since I had it back, I've noticed that there is user called "test" but I can't find it anywhere. I've created an admin user with my name, but that user will come on in the DOS command, I can see it everywhere but not my username.
example, here is a pic
It has bugged me a lot and I didn't do much about it, but now I really need to find a solution to change this "test" username to mine.
Thank you in advance.
- 1.5G Intel Centrino Core2 Duo
- 4GB DDR2 SDRAM
- Graphics Card(s)
- Intel Graphics X3100 w/ 251MB
- 160GB (5400RPM) serial ATA hard drive
