VBS associated to Notepad problem
Brink
Staff member
mvp
32,205
Location
Oklahoma, USA
Hello JJohall,
The VBS association got associated to Notepad, usually accidentally with the Open With option. You will just need to change the Current Default program for the .vbs file extension (Name) to C:\Windows\System32\wscript.exe (Microsoft Windows Based Script Host) instead of Notepad. Method Two in this tutorial will show you how to if needed.
http://www.vistax64.com/tutorials/69758-default-programs.html
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
4
Hi Shawn,
Thanks for your help, this seemed to work. I did try to change the association to many things such as cmd.exe and so on, i did no know there was a wscript.exe . I was woundering if it was an sp1 issue becasue it was doing the same thing on my laptop. Amy way i have got it working now, thanks for your help, again!!!
Many Thanks
jjohall2000
Brink
Staff member
mvp
32,205
Location
Oklahoma, USA
Your welcome JJohall. I'm happy to hear it is working now for you. I would not think that SP1 would have affected it. It could have happened easily if the Open With was used on it with Notebook selected at one point since it would have originally began as a TXT file before renamed with the VBS extension.
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
