James Colbert
I installed an Akasa sata front panel
Akasa PC Front Panel with SATA Data/Power
to Gsata0 (only device, all other drives on sata connectors, including boot drive). In the bios, Gsata was set for IDE mode. I plugged a sata drive into the sata front panel, started the machine and all is well, the drive is fully functional.
I would like to be able to hot swap to the Akasa, so I changed the Gsata setting in the bios to AHCI, and restarted, but it seems to still be running in IDE mode (Dev Mgr shows '2 port Serial ATA storage controller 2-3A26')
Questions:
1) How do I verify AHCI mode for the drive plugged into the sata front panel?
2) If it is still running in IDE mode, how can I force AHCI?
3) Is it advantageous to 'force' AHCI for the drives (including boot) on the other controller (6sata), and would stability issues arise?
Relevant Specs:
Vista Ultimate 64
GA-EP45N-UD3R mainboard, P45
Q9550
(sata6 controller) 4 Seagate sata HDs, 1 DVD
(Gsata controller) Akasa Front Panel with sata drive plugged in
Thanks!
James
Questions:
Relevant Specs:
Vista Ultimate 64
Q9550
Thanks!
James
- Q9550
- Gigabyte GA-EP45-UD3R
- 8 GB DDR2
- Graphics Card(s)
- ATI XL1800
- xFi Plat
- 2405fpw
- 1920x1200
- Seagate sata
