VGA and Business Vista...Help!
loneliness
Good day to you all.
I have upgraded my windows XP to Vista ( Business version 32 bit...cuz I got it for free :D) , so I am having problem with the VGA card. The operating system won't recognize my Gforce 6600 card and still saying Standared VGA Card. I also tried to run (182.08_geforce_winvista_32bit_english_whql) but no changes. :confused:
Is this problem because of Vista Business version? if yes, is it even possible to solve it?
Thanks alot!
Have you tried to manually install the drivers?
If not then go to device manager
right click on the device and select update driver.
Alternativley install the cd that came with the card.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
hey roy69
Thanks for replying.
I did that few times and it would say that Standard VGA Graphics Adapter is up to date, and unfortunately there is no CD for the card because it came w/ the laptop. In addition, the CDz that came w/ the laptop only works on XP version.
Thanks anyway :)
make sure you have the current driver from nvidia downloaded to your computer--preferable from nvidia website (i am not keen on nvidia, but i would think they would have the drivers for laptops as well on the website).
try going to device manager and uninstalling the standard vga drivers (as those are generic microsoft drivers). after you do, your screen will probably revert to 640x480, but don't worry.
after you've uninstalled the standard vga drivers, if the computer auto detects "new" hardware (the graphics card), stop the auto install of the drivers. go to the downloaded nvidia drivers and install. you'll probably have to reboot and it should be fine afterward.
    Garage PC
    Intel Pentium E3300 @ 2.5GHz
    BioStar G41-M7
    A-Data PC2-6400 (2 X 2GB)
    Diamond Radeon HD 4650
    Realtek
    HP Mx705 (CRT)
    1152x864
    LOGISYS PS480E12 480W
    Generic Barebones Case
    Stock Intel HSF
    Generic PS/2
    10 d / 1 u
For the most part they don't. Like ATI they prefer that you get drivers for laptop video cards from the laptop manufacturer. Only problem is that most of the laptop manufacturer's are rather lackadaisical about updating what is available. That being said the best place for Nvidia laptop drivers is here,
Download NVIDIA drivers | drivers for mobile cards and laptops | laptopvideo2go.com
Just pick the driver version you want. May also need to download the modded INF (link is on the same page as the actual driver) to get it installed, but in most cases it is already included in the driver package.
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
