Videos Freezing In Vista x64 solved! FINALLy after months of headaches
EmulatorX
Power User
DISABLE AERO THEME..Switch to Basic...my problems are all gone... EVERY SINGLE time i would open WMP or POWERDVD and switched to fullscreen the videos would start and after 2 or 3 sec the WHOLE system would freeze and i couldnt even get out of fullscreen.. it would just LOCK UP completely and i would have to hard reboot.. this issue was KILLING me... ..oh and forget about trying dreamscene.. if i had dreamscene running after like 10-15 min it wouold also freeze my computer.. so at first i thought disabling dreamscene would fix my probs... but it didnt...i tried a suugestion by someone on here to get media player classic the CCC( community codec pack) and even that would freeze...it froze less than WMP but still would happen..
the only thing is as much as it not THAT important ..ill miss aero, even thought it was such a minimal thing..hopefully windows 7 will fix many of the issues vista STILL has... i love vista..have stuck with it from the very beginning..but they have to fix these ttypes of issues..my problems NEVER HAD TO DO WITH SLI..sli was not at fault ..an di was already thinking of going ATI cuz of this.. go figure
hope this helps anyone else...
ps: this used to happen to me in 32bit but only once in a blue moon.. i noticed the problems more frequently when i upgraded to 64bit... i dont really wanna go back to 32bit so im glad i found my answer..after so SO MUCH trial and errors
    Intel Core i7 920 2.66ghz @ 3.37ghz 1.33v
    ASUS Rampage II Extreme x58 Bios 1306
    6GB Corsair Dominator DDR3 @ 1604mhz 8-8-8-24 1.65v 1T
    EVGA Nvidia GTX 295 186.16
    Logitech Z-Cinema 2.1 USB speakers @ 24bit 48000hz
    SAMSUNG 2253BW 22" 2ms DVI LCD / Samsung 50" Plasma TV 720p HP-T5064
    1680x1050- LCD, 1366x768 -PLASMA
    300GB 10,000rpm WD Velociraptor
    320GB 7,200 WD
    1TB 7,200rpm WD
    1TB 7,200rpm Seagate 7200.11
    2TB External MY book II WD 7,2000rpm
    /Pioneer 8x BLURAY Burner BDR-203BKS - Sata/
    /Samsung 22x DVD Burner w/lightscribe -Sata
    Antec Signature 850 Watt
    CoolerMaster Storm Sniper
    CoolerMaster v8 35c/60c 5 CASE FANS 2x200mm 3x120mm
    Logitech G9 Laser
    Saitek Eclipse III
    20 MBPS Road Runner Pro
    Edirol PCR-500 49 Key MIdi Controller Keyboard
    3D MARK 06 Score: 21458
    3D MARK 05 Score: 27549
    VANTAGE SCORE: P24129
    VISTA SCORE: 5.9
bruce2
Vista Pro
Hi EmulatorX, welcome to the board. Congrats and thanks for sharing your accomplishment. Please post back periodically on your system status.
    E6850
    EVGA 122-CK-NF67-A1 680i
    4 x OCZ Platinum 1GB
    ATI Radeon HD 5850 1GB
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
Dwarf
The Contemplator
Hi EmulatorX,
I notice that you have SP2 Beta. Did you have the problem prior to you installing this? I don't have any problems with DreamScene or WMP (I don't have PowerDVD).
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
EmulatorX
Power User
yes problems where just as persistant b4 installing sp2 beta...its actually one of teh reasons i decided to try sp2 beta to see if the problems would disappear but same problem... i tried everything i have my mobo bios up to date , i even tried going back to an older bios.. tried all kinds of video drivers.. tried different media players... the only thing that has fixed my issue was disabling aero... im testing WINDOW BLINDS by stardock..they have soom cool themes that "act" like aero but are not really..
    320GB 7,200 WD
    1TB 7,200rpm WD
    Logitech G9 Laser
    Saitek Eclipse III
    VISTA SCORE: 5.9
Dzomlija
Resistance is Futile
This thread cannot be marked as solved.
For one simple reason: Your solution is a bit like curing the disease by killing the patient! Turning of Aero has done nothing but hide the problem.
My suggeestion to you would be to go to your graphics card manufacturers website, and then download and install the latest NON-BETA drivers. Do the same for your motherboard.
You may also have bad Video Codecs installed. I've been using the Vista Codec Pack for nearly 2 years now (alomost as long as I've had Vista x64), and I've had no problems.
Get it here: Vista Codec Package Homepage (VCP)
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    2 x 80GB Seagate (I)
    2 x 120GB Seagate (I/S)
    2 x 200GB Seagate (I/S)
    2 x 250GB Seagate (I/S)
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
smarteyeball
Eye know, eye know
Good to hear you've found a work around. But *ahem* did you try disabling SLI ?
I'd also think twice about going ATI if your considering Xfire and x64. It was broken in 8.10 hotfix, is still broken in 8.11 and may not be fixed in 8.12 (single cards are fine)
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
    Laptop Specs:
    Clevo Sager P170HM //
    17.3 Matte 1920x1200 //
    i7 2720QM // 8GB 1333mhz //
    Dedicated GTX 485M //
    Samsung Story 2TB USB 3.0
Dwarf
The Contemplator
Hi EmulatorX,
I have just had a look at your System Specs and I notice that you are using 2 PSUs. I recommend that you replace these with just a single unit - 1,000W+ units are available. For a PSU to work effectively, it must be correctly loaded. That means that the main ATX cable must be plugged in. Since, obviously, both of these cables cannot be in use, it does mean that the unit where the cable isn't being used is not loaded correctly (one of the 3.3V lines in this connector is also used to provide feedback to the PSU regarding loading factors). This in turn means that the power on the other cables is not as stable as it should be, leading to problems when the loading on them varies. This is OK if they are just used to power case fans, but if they are used to power other components it can cause problems. In addition, you will have problems caused by electrical continuity with the ground line.
    Gigabyte IF233
EmulatorX
Power User
hey guys thanks for all your responses..i've tried everything u guys mentioned aside from the dual psu possibly being the problem..but with aero disabled i dont have ANY issue...the dual psu's are 650 watt( powering MOBO,CPU, GPU's) 550 watt ( powering everything else HDD's FANS, USB devices, dvd roms etc etc) , i've tried WHQL video drivers..sound drivers..bios updates.. ALL CODECS out there and i make sure not to have all of them installed at the same time.. i know that can cause issues.... but why disabling aero completely solves all my problems? i dont know .... after disabling it i have not had one lock up at all from ANY player ( power dvd, wmp, etc etc), and the lock up never happened during intense 3d gaming, i really doubt the pus is the problem... as i've seen other people with the same exact issue and i doubt it was the psu at fault, i have tried disabling SLI and still no good... i know SLI isnt the issue cuz all is fine right now with sli enabled and aero disabled..
see this thread i saw right here on vista forums of other people complaining of the same issue.. apparently their issue was never followed up on or resolved please read this thread..its identical to my problem : http://www.vistax64.com/vista-music-pictures-video/101665-system-hangs-freezes-playing-videos.html
    320GB 7,200 WD
    1TB 7,200rpm WD
    Logitech G9 Laser
    Saitek Eclipse III
    VISTA SCORE: 5.9
Dzomlija
The one thing you haven't mentioned is whether or not yo've tried physically removing one of your graphics cards, and running it not with SLI disabled, but with no SLI at all on the hardware level. If the problem persists, then try using the other graphics card also on it's own.
The reason being why you have no problems with Aero disabled is possibly because there is no longer as much load on the graphics driver as there would be with it enabled. It is likely that Aero, combined with the resources required to play the videos is just simply too much for the graphics driver to deal with. It does not matter which player you use. At some point, they all go through the graphics card driver anyway, which provides the hardware video decoding functions.
Or, there could be a hardware issue. Perhaps the two cards you are using are not 100% compatible with each other? SLI works best really when you are using two graphics cards from the same generation GPU, preferably identical, both each with the same BIOS revisions. In that regard, do you also have the latest BIOS for your motherboard?
You also appear to have a fair number of codecs installed. This problem is elusive enough to not rule out any possibility. Perhaps you have some kind of conflict happening here? Uninstall as many of the codecs as possible, and install ONLY those that you require.
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Genius
    384kbps
EmulatorX
Power User
hey there.. well i havent tried removing the gfx cards really..but i refuse to believe they are the issue..NOT that i dont believe in your suggestions..its that many of the things u mentioned aside from removing each card and testing individually..i have already tried.... BOTH cards are identical in every way ( bios, clocks, model #'s), had it been the gfx cards hardware issue, i'd have problems with rendering or performance in games ( which i dont). I have tried disabling SLI, have also removed ( uninstalled) one of the cards in the device manager ( i know its not the same as physically removing). as far as codecs are concerned.. i DO NOT have many different types of codecs install just 1.. from the vista components..( by shark). Also not sure if i mentioned it, but even running dreamscene created the same freezing issue.. ( and as far as i can remember..back with the first retail version of vista 32bit i was always able to be running dreamscene with no issues..)
    320GB 7,200 WD
    1TB 7,200rpm WD
    Logitech G9 Laser
    Saitek Eclipse III
    VISTA SCORE: 5.9
Dzomlija
Fair enough. But this issue of your is ellusive enough to not discount any possibility.
Yet it remains that you experience the freezing only when you play videos, which includes Dreamscene, then I believe that the problem, as mentioned, lies with either the Video Decoding components of the drivers, or there is some obscure hardware issue that we havn't pinpointed yet...
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Genius
    384kbps
EmulatorX
Power User
hey , quick update on my videos freezing with aero on...somehow magically i can play videos again with aero enabled.. what i cant do is play more than 1 video instance.. so that means i lose dreamscene.. since its still in the "video" playback category, and i cant play 2 differnt videos simultaneously ( but i dont really need to do that anyway :) ) but at least i can now "normally" watch my dvds, xvids, avi etc with regular wmp11 and no freezing.. i have since..done a clean install of vista ultimate 64, but that wasnt the main reason i cleared up my issues.. since b4 i did the clean install everything was ok also.. so i dont know what actually did it..but aero's back!! and im happy now lol
    320GB 7,200 WD
    1TB 7,200rpm WD
    Logitech G9 Laser
    Saitek Eclipse III
    VISTA SCORE: 5.9
KrossX
Could that be related to GF8 (SLI or not), DXVA and PUREVIDEO?
I never tested that combination in Vista.
  • Other Info
    Windows 7 is love~~
EmulatorX
Power User
could very well be related to the geforce 8800's series, ill never know until i upgrade my gfx cards..which right now wont be soon..since they are performing well in games.. other than the fact that i cant have 2 video playback instances running simultaneously..but i could live without that... the only scenario that i would have "2" videos running is Dreamscene+ dvd video or ( xvid, mpg ,avi etc etc)... so right now my best option is to simply not use DS and just live with high quality HD wallpaper ...good enough for me
edit: freezing also occuring with SLI disabled..so gfx cards must be the problem
    320GB 7,200 WD
    1TB 7,200rpm WD
    Logitech G9 Laser
    Saitek Eclipse III
    VISTA SCORE: 5.9
EmulatorX
Power User
Re: Videos Freezing In Vista x64 solved! REALLY SOLVED THIS TIME!!!
i got rid of my 8800gtx SLI cards and installed a single ati radeon 4870x2 ( dual gpu on 1 pcb) and all issues have vanished instantly!..it was my gfx cards all along... i have seen many people stating the same type of vidoes freezing issue, and all of them have nvidia cards installed i noticed.. so i went ATI.. and it seems all is good now.. i can now run dreamscene without the worry of a freeze up.. and to further push it.. i ran dreamscene and opened up 2 video instances , 1 with WMP and one with power dvd.. so i had powerdvd, wmp and dreamsecene all running..and not one hiccup !!..if i ever tried that with my 8800gtx's it would freeze within seconds!..u can mark this one as SOLVED!
    320GB 7,200 WD
    1TB 7,200rpm WD
    Logitech G9 Laser
    Saitek Eclipse III
    VISTA SCORE: 5.9
bruce2
Vista Pro
Glad you had it fixed. But I thought the 8800gtx SLi is powerful enough to handle those tasks you mentioned. The cards must have been defective or some other computability issues.
Nice day and post back.
Bruce
    E6850
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
EmulatorX
Power User
hey Bruce..well as I said before ..im not to sure it was that they were defective per say..since gaming was absolutely fine.. why simple tasks as playing dvds and WMP and dreamscene froze up? not sure , but they problem was definetly with the cards..cuz even with SLI disabled..freezing still occured... took longer but still happened...but i can finally stretch my legs and breathe.. happy vista64 customer now..i was blaming poor little Vista.. shame on me..
    320GB 7,200 WD
    1TB 7,200rpm WD
    Logitech G9 Laser
    Saitek Eclipse III
    VISTA SCORE: 5.9
AO2k9
EmulatorX,
You first described the exact same freezing symptoms I have but a little different problem. My computer freezes when viewing the web in either IE or Firefox. I use the computer as an HTPC on my widescreen tv. The problem only seems to happen when I use a widescreen resolution. Once I reduce resolutions to a fullscreen format... no more problem. You suggested disableing AERO solves your problem. I too have disabled it while using widescreen resolutions and now I have no more problems. My point is, maybe our problem has something to do with Aero and Widescreen resolutions.
