Hi all,
I need a lesson in Virtual Memory please. Was just checking performance and ended up at Virtual Memory. Had a couple of programs fail recently. I do not necessary think it is my system but rather glitches in the two applications themselves, as was the case with compatibility between the latest versions of Firefox and Java. Still . . . think it's wise to check performance every so often.
After reading several posts on the Forum, I'm still not sure what I should do, if anything. Have two questions. Can you please take a look and offer some guidance?
Some info below on my computer. Please let me know if I need to provide anything additional.
OS: Vista 64-bit Home Premium
800 GB hard drive
7 GB Ram
I have three (3) drives: "C" where the system is; "D" where back up is - never touch this; "K" docs and gaming programs
Question 1: Is "real" memory the same as "physical" memory? I believe it is. If so, then I have 7 GB - correct?
Under System Properties, Advanced . . . System says:
C: 342066 MB space available
D: 1531 MB space available
K: 128044 MB space available
Paging file is on "C"
NOTE: I do have the system managing the memory currently
System further says:
Min allowed: 16 MB
Recommended: 10365 MB
Currently allocated: 7210 MB
Question 3: Given the recommendation of 10365 MB above, should I custom set the Virtual Memory? And if so, do I need to do this for each drive?
Thank you all in advance for your assistance.
Meltie
800 GB hard drive
7 GB Ram
Min allowed: 16 MB
Meltie
- HP
- Graphics Card(s)
- NVidia
