Vista 32bit memory limitation
panais
Power User
I have on my computer 4096MB of ram (4 dimms)
Windows vista ultimate 32bit from te default reads 3582MB.
Now... after i install sp1 windows reads 4GB.
I wonder if this is reall or just a virtual.
    Custom Built by me.
    Intel Core 2 Quad Q6600
    Gigabyte GA-X38-DS4
    KINGSTON HYPERX DDR2 4GB (2X2GB) PC6400 800MHZ DUAL CHANNEL KIT
    SAPPHIRE RADEON HD4890 OC 1GB GDDR5
    2/4/5.1/7.1-channel Realtek High Definition
    Samsung LE40A656F1 1080p 100Hz LCD HD TV 50,000:1
    1366x768 in Desktop,1920x1080p in gaming and video
    C:\WD VelociRaptor 150 GB,10,000 RPM
    D:\WESTERN DIGITAL WD15EADS 1.5TB CAVIAR GREEN SATA2 E:\WESTERN DIGITAL WD15EADS 1.5TB CAVIAR GREEN SATA2 No Raid.Copy Paste Is The Safest Way.
    Seasonic 700W 80plus
    A-Case Twin Engine BB
    3 thermaltake smart case fan II + 1 arctic cooling fan
    Wirelles Logitech Laser Mouse MX620
    Wireless Logitech LX710
    ADSL 4000plus
    F:\Sony high speed sata Dvd Rewriter
    KINGSTON HYPER X FAN
    +Cordless Rumblepad 2
Brink
Staff member
mvp
usa us_oklahoma
Hi Panais,
It's real. It was a bug in the 32 bit version of Vista where it would not always see anything over 3GB. The SP1 fixed the problem.
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
panais
Power User
So that means now my os end programs benefit and use all my 4096 ram?
    Custom Built by me.
    Gigabyte GA-X38-DS4
    ADSL 4000plus
Brink
Staff member
mvp
usa us_oklahoma
Yep, it sure will.
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
panais
Power User
This is perfect!!
    Custom Built by me.
    Gigabyte GA-X38-DS4
    ADSL 4000plus
Scotteq
Plays with his WEI
usa us_new_jersey
In 32 bit Windows operating systems, the total addressable space available is 4GB. If you install a total of 4GB worth of RAM, the system will detect/use/display less than 4GB of total memory because of address space allocation for other critical functions, such as:
- System BIOS (including motherboard, add-on cards, etc..)
- Motherboards resources
- Memory mapped I/O
- Configuration for AGP/PCI-Ex/PCI
- Other memory allocations for PCI devices
Different onboard devices and different add-on cards (devices) will result of different total memory size. e.g. more PCI cards installed will require more memory resources, resulting of less memory free for other uses.
This limitation applies to most chipsets & Windows XP/Vista 32-bit version operating systems. Again, this is a limitation of the Operating System not having enough address space to allocate to the system *and* the RAM. Not allocating address space to devices renders them inoperable. Not allocating addresses to RAM simply results in the unaddressed section not being used in an otherwise fully functional computer. Therefore the OS designers assign RAM last.
We can have long debates about mathematical fundamentals and discussions about why the original Windows designers couldn't allocate the full theoretical max of 36 bits of address space so that users today would be able to use more resource. But at the end of the day, the designers and engineers 'Didn't Do That Then'. So we 'Can't Do This Now'.
If you install a Windows operating system, and if more than 3GB memory is required for your system, then the below conditions must be met:
1. A memory controller which supports memory swap functionality is used. The latest chipsets like Intel 975X, 955X, Nvidia NF4 SLI Intel Edition, Nvidia NF4 SLI X16, AMD K8 and newer architectures can support the memory swap function.
2. Installation of Windows XP Pro X64 Ed. (64-bit), Windows Vista 64, or other OS which can provide more than 4GB worth of address space.
Note: According to the latest Change Log published by Microsoft, Windows Vista 32bit SP1 will display the installed amount of RAM. This is a display change only.
    Proudly Built by Me!
    Intel Q6600
    DFI UT LP P35 T2R
    8GB OCZ Reaper DDR2 800 C44GK 4-4-4-12 2T
    Sapphire Radeon 4870x2
    AuzenTech Prelude 7.1
    1 Acer P243 24" and 1 Samsung T260 26" Monitor/HDTV
    Both are running at 19x12
    Seagate 1TB 7200.11 (Vista x64)
    Seagate 500GB 7200.11 (Win 7 x64)
    OCZ GameXtream 900w
    FSB at 400 (1600) Mhz, CPU Multi @ 8 for 3.2Ghz
32Bit has a TOTAL hardware memory address allocation space of 4GB when not running in PAE mode (no, don't ask...1. it won't work on "home" versions of Windows. 2. It's not a nice trade off.).
You have to allocate for devices which require address spaces based on what the ask for; USB controllers, audio cards, USB devices (external storage and the lot), and Video Cards, and THEN what is left over goes to RAM.
Vista SP1 have a "fix" that lies to you and tells you that Windows Vista Recognizes all 4GB on your system. It won't tell you how much you're actually able to address unless you look deeper under the covers (task manager and what not).
    E6850
    EVGA 122-CK-NF67-A1 680i
    4 x OCZ Platinum 1GB
    ATI Radeon HD 5850 1GB
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
panais
Power User
#8
Emmm....
I need a simple answer for a simple question...
With sp1 installed my os and programs will benefit and use all my 4096 ram?
Thanks for ur response.
    Custom Built by me.
    Gigabyte GA-X38-DS4
    ADSL 4000plus
#9
Emmm....
The simple answer is no. Functionally, SP1 works the same as pre-SP1. 32-bit Vista will only be able to use and benefit from ~3Gb RAM (the exact number depends on a few factors). SP1 fixes the way it displays the actual amount of physical RAM installed, but the way it's used by the 32-bit OS hasn't changed.
Hope this helps.
Munkus
Emmm....
Nope.:zip: :D
    E6850
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
Dzomlija
Resistance is Futile
south_africa
#11
Prior to Vista SP1, Vista displayed the total available system memory, which is determined by hardware in the BIOS, and how much is used by internal devices such as HDD & USB controllers, Display adapters, etc.
In Vista SP1, the total installed memory is now reported.
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    2 x 80GB Seagate (I)
    2 x 120GB Seagate (I/S)
    2 x 200GB Seagate (I/S)
    2 x 250GB Seagate (I/S)
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
.Joe
1337 spammer
usa
#12
Question. Should the full 4 GB show up in all applications running in a SP1 system? I've got the RTM SP1 installed, and I have applications still reporting only 3.3 GB. Will the full public release of SP1 resolve that?
    Intel Q6600 Quad Core 2.4 Ghz
    Dell 0TP406
    Nvidia 8800 GT 512 MB
    Dual Dell 22" Widescreen
    3360x1050
    320 GB Internal Main
    500 GB USB External
    160 GB USB External
    2TB USB External
    DSL 3MB
Zdon
Don't worry be happy.
usa us_arizona
#13
My understanding is that PAE will work on 32-bit Vista. But, you say no to "home" versions. Please clarify.
Dzomlija
south_africa
#14
That just depends on which API call the application makes to determine the amount of memory to display. Either the available memory, or the total memory can be queried by an application.
And of course, it doesn't really matter, since a 32-bit application is strictly limited to 2GB RAM anyway, (whether it's being run on XP or Vista), regardless of how much is installed or available.
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Genius
    384kbps
Zdon
usa us_arizona
#15
Right, but more memory, more applications running closer to optimally. I still am wondering about your "home" computer remark. That is what I am hoping to clarify.
Dzomlija
south_africa
#16
I never mentioned PAE on "home" versions. That was bruce2.
But to clarify your question anyway, PAE (Physical Address Extensions) is not available on any consumer version of Windows. It is typically used on 32-Bit server operating systems (Such as Windows Server 2003) to allow the operating system (and enabled applications) to address more than 4GB of memory.
Because x64 can on the hardware level address more than 4GB of memory in excess of TeraBytes, PAE is not necessary on x64 versions of Windows.
So it remains - If you want more than 4GB, you either need to use a server OS that isn't really suited for home use, or switch to a 64-Bit OS, such as Vista x64.
I've been using Vista x64 Ultimate for just over a year now, and it's performance, compatibility and reliability is second to none. Just make sure you can get Vista x64 drivers for all your hardware...:geek:
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Genius
    384kbps
Zdon
usa us_arizona
#17
HaHa. Thanks much. Excuse my dumb for thinking you were replying to me. But, OK, this read seems to imply that PAE applies to Vista 32-bit. And, there are others that seem to imply the same.
Dzomlija
south_africa
#18
That article is misleading. If you were to check on Microsoft's Vista website (or others detailing the memory limitations of Windows Vista), you'll notice that none of the 32-Bit versions of Vista support more than 4GB of memory. So the logical conclusion would be that they don't support PAE...
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Genius
    384kbps
Zdon
usa us_arizona
#19
I know what you mean. But, help. Here are some more:
Memory Management Registry Keys (Windows) and
/pae.
Why is there so much apparent confusion on this issue?
