Solved Vista 64 Audio Stutter
I have just reinstalled the operating system of my Dell Inspiron 1545 after it kept crashing for what appeared to be no reason at all. The crashing problem has gone, it seems, but now the audio is stuttering. It doesn't matter if I am watching something in a media player, on the internet, or just listening to a song. Every so often, the audio stutters.
I have tried the "Disable Enhancements," to no avail. The driver has also been uninstalled and reinstalled, which did nothing. I tried disabling all of the startup services and the audio seemed to be fine when I disabled the Intel Matrix Storage Manager. Could that be causing the problem?
Yard Dog
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    Acer E181H ([email protected]) 128MB GeForce 6150SE nForce 430 (
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
tom982
٩(͡๏̯͡๏)۶
Hello shhhhharlotte and welcome to the forums :party:
Do you have any sort of RAID set up?
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    Samsung EVO 128GB SSD
    Seagate Barracuda 2TB 7200rpm
    NZXT Phantom 410
Yard Dog
How did the memory test go ?
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
tom982
٩(͡๏̯͡๏)۶
Hello shhhhharlotte,
I can't think of any other solution to your problem apart from leaving the Intel Matrix Storage Manager disabled. I don't think it would be a good idea to remove it because I'm not entirely sure what will happen to be honest. If you don't have a RAID setup (you would know if you had one, it takes a while to set up), then there isn't any point having this software running :)
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
All right. Are you sure there won't be any negative effects, despite the fact that I don't have a RAID setup? On the Intel website, it mentioned some things about battery life being prolonged and other benefits. Is that only if you have a RAID setup?
Yard Dog
From what i read of that service, you can safely disable it and not worry about it. If in the future you set up a Raid type system , then you could always enable it. Go ahead and then post back if this is solving the stutter issue please.
    Emachine ET 1161-05
    Acer E181H (1280x7[email protected]) 128MB GeForce 6150SE nForce 430 (
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
wither 3
If you're using onboard audio, you can try reinstalling or updating your MOBO drivers.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
wither 3
Holy cow! I thought the experts in here would be all over this one.
Are you using a laptop? If so, you should be able to go to the vendors' support website and find the motherboard drivers. You would just run the .exe. If you have a problem, post the make and model number of your laptop.
If you have a PC, you probably got a disc with the motherboard drivers. You would just run the disc setup.exe.
I noticed that you said this problem happens randomly. When I'm listening to internet radio, I occasionally get a brief interruption. That's not a system problem.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
Actually, I think that disabling the Intel Matrix Storage Manager fixed the problem. I have been testing the audio and I don't think I caught any stutters. If there were any, they were barely noticeable.
Thank you, everyone, for all your help. It is greatly appreciated :)
Yard Dog
Yes, from what you indicated and Tom's answer. That appeared to be the fix .
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
