Vista 64 Bit - Stopped by Router
rwsanderson
Greetings,
I updated my home PC today from XP Pro to Vista 64 Bit Business.
I was provided the software by my employer and purchased a brand new HD to install it on. Install went fine.
My home network consists of the following:
My PC -XP Pro - wired connection
Wife Laptop - XP Pro - wireless
Kids PC - XP Pro - wireless
Vonage VOIP - wired
PS3 - wired
wii - wireless
d-link router
The above set up works great all the time.
I installed Vista 64 Business on a new HD today and changed nothing else as above. I cannot connect to the Internet at all through my router. When I bypass the router and plug in directly, I can connect without issues. This (for obvious reasons) will not work and was hoping that someone could help me out.
My service provider (Cogeco) will not help me at all since the Internet works without the router connected.
Please tell me what information you require from me in order to help me out.
Thanks in advance.
zigzag3143
Banned
hi and welcome to vistax64
You may just need a router firmware upgrade, or a wifi/lan driver.
can you tell us which D-link and the model of your wired, and wireless devices so we can hunt for drivers
ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
rwsanderson
My router is a D-Link Wireless N Router.
I can access it through 192.168.0.1 from XP but cannot see it or access it through Vista 64.
The router shows as being compatible with Vista 64. http://www.microsoft.com/windows/compatibility/Details.aspx?type=Hardware&p=DIR-615&v=D-Link&uid=&pf=0π=2&c=Networking&sc=Wireless+Routers&os=32-bit and latest firmware is installed on the router.
My network card shows in XP as a Realtek RTL8169/8110 Family Gigabit Ethernet NIC. I downloaded the latest drivers for it on the Vista 64 installation as well.
zigzag3143
Banned
nrs
what firewall on vista? anti virus? is the router configured to allow only certain "mac" addresses? can the xp machine see the vista machine?
any shares?, any encryption?
thanks
ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
rwsanderson
The Vista install is "straight out of the box". No firewall or antivirus other than what Vista would have installed. I have not fired up the other PCs to see if they see the Vista box but will reboot and do that. I am using my XP boot to send and read these messages.
No mac blockages to the best of my knowledge.
I simply loaded Vista, rebooted and tried Explorer with no luck.
zigzag3143
Banned
IE might have auto detect settings checked and that sometimes breaks the connectivity.
In IE tools>internet options>connections>lan settings>uncheck auto detect settings.
let us know
ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
