Ok, installed xp fresh copy, legit.
Installed drivers cd that came with motherboard.
After Installation of all updates from M$ (I have to have every update because of my job), I use my USB flash drive I use it for EVERYTHING!
I get the following "Windows - Delayed write failure."
OK, go see what happened at the flash drive, shows in my computer but when i access it its blank.
Unplug it and plug it back in, works fine until i start to transfer files.
Installed Vista Home Premium clean install legit.
Installed motherboard drivers cd again.
Update windows vista with every update available (119 updates).
Plug in USB drive, transfer files and after a few seconds...
"File not found" error.
Go to my computer the drive is there but when you access it its blank, just like in xp except the error isnt the same.
Its like Vista "forgets" where my usb drive is.
Any help is appreciated, If I have left anything out please tell me so I can help you help me.
Thanks!
Thanks!
- Biostar
- Intel Pentium 4 530 w/ HT 3.0 Ghz
- Biostar G31-M7-TE
- OCZ Reaper 2 Gb DDR2 2X2
- Graphics Card(s)
- Integrated G33/G31 express chipset family (256Mb)
- Realtek High Def
- 20 AOC 16:9
- 1600X900
- 80 GB SATA
20 GB ATA
- PSU
- 400 watt ASUS
- Case
- Custom
- Cooling
- Stock Fans (80mm) X 3
- Dell
- GE
- 3.0 HSI DSL through wireless gateway device
