Solved vista antispyware virus 2012 removal
been infected with this virus and did a search of the net, there are so many different guides on how to remove it from the very simple by downloading stopzilla to very complexed involving reg edit functions, could some one offer advice as to which is the most reliable and effective guide to remove this virus
thanks
i have managed to stop the virus restarting but it it still wont let me scan my pc fully via my zone alarms anti virus it runs for about 2 mins then say complete a normal scan would take a bout 20 mins , ill try the link you suggest and post an updated
Hello combat goofwing and welcome to the forums :party:
As well as following Rich's sound advice, can you do the following for me please:
CKScanner
Please download CKScanner from here to your Desktop.
Make sure that CKScanner.exe is on the your Desktop before running the application!
Double-click on CKScanner.exe and click Search For Files.
After a very short time, when the cursor hourglass disappears, click Save List To File.
A message box will verify the file saved
Attach the log CKFiles.txt that has been created on your desktop with your next post
Malwarebytes Anti-Malware
Download and install MBAM from here
Run a full scan and attach the log with your next post for me to analyse
OTL
Download OTL to your desktop.
Double click on the icon to run it. Make sure all other windows are closed to let it run uninterrupted.
When the window appears, underneath Output at the top change it to Minimal Output.
Under the Standard Registry box change it to All.
Check the boxes beside LOP Check and Purity Check.
Click the Run Scan button. Do not change any settings unless otherwise told to do so. The scan wont take long.
When the scan completes, it will open two notepad windows. OTL.Txt and Extras.Txt. These are saved in the same location as OTL.
Please copy (Edit->Select All, Edit->Copy) the contents of these files, one at a time, and post it with your next reply.
Once OTL has completed its first scan it will save notepad copies of the scans in the folder that OTL was started from. Unless set to produce an Extras log it will only produce OTL.txt in subsequent scans.
A copy of an OTL fix log is saved in a text file at
:\_OTL\MovedFiles
in most cases this will be C:\_OTL\MovedFiles
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    Samsung EVO 128GB SSD
    Seagate Barracuda 2TB 7200rpm
    NZXT Phantom 410
Thanks Tom ill try that when I get in from work tonight ,I already have malware bytes installed at first the virus would not let me run it ,but I manage to update and run it but it finds nothing ill post later
ck scanner ran file attached
update and ran malware bytes and noticed it starts to scan then jumps from 448 items scanned to 28000 items in a split second
otl ran ok
OTL
OTL logfile created on: 30/06/2011 22:43:20 - Run 1
OTL by OldTimer - Version 3.2.25.0 Folder = C:\Users\alan\Desktop
64bit-Windows Vista Home Premium Edition Service Pack 2 (Version = 6.0.6002) - Type = NTWorkstation
Internet Explorer (Version = 7.0.6002.18005)
Locale: 00000809 | Country: United Kingdom | Language: ENG | Date Format: dd/MM/yyyy
6.00 Gb Total Physical Memory | 4.41 Gb Available Physical Memory | 73.47% Memory free
12.10 Gb Paging File | 10.43 Gb Available in Paging File | 86.15% Paging File free
Paging file location(s): ?:\pagefile.sys [binary data]
%SystemDrive% = C: | %SystemRoot% = C:\Windows | %ProgramFiles% = C:\Program Files (x86)
Drive C: | 596.17 Gb Total Space | 171.78 Gb Free Space | 28.81% Space Free | Partition Type: NTFS
Drive D: | 372.61 Gb Total Space | 48.54 Gb Free Space | 13.03% Space Free | Partition Type: NTFS
Computer Name: ALAN-PC | User Name: alan | Logged in as Administrator.
Boot Mode: Normal | Scan Mode: Current user | Include 64bit Scans
Company Name Whitelist: Off | Skip Microsoft Files: Off | No Company Name Whitelist: On | File Age = 30 Days
========== Processes (SafeList) ==========
PRC - C:\Users\alan\Desktop\OTL.exe (OldTimer Tools)
PRC - C:\Program Files (x86)\Splashtop\Splashtop Remote\Server\SRService.exe (Splashtop Inc.)
PRC - C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe (Adobe Systems Incorporated)
PRC - C:\Program Files (x86)\TomTom HOME 2\TomTomHOMEService.exe (TomTom)
PRC - C:\Program Files (x86)\Splashtop\Splashtop Software Updater\SSUService.exe (Splashtop Inc.)
PRC - C:\Program Files (x86)\HTC\Internet Pass-Through\PassThruSvr.exe ()
PRC - C:\Windows\SysWOW64\ZoneLabs\vsmon.exe (Check Point Software Technologies LTD)
PRC - C:\Program Files (x86)\Zone Labs\ZoneAlarm\zlclient.exe (Check Point Software Technologies LTD)
========== Modules (SafeList) ==========
MOD - C:\Users\alan\Desktop\OTL.exe (OldTimer Tools)
MOD - C:\Windows\winsxs\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_d08d7da0442a985d\msvcr80.dll (Microsoft Corporation)
MOD - C:\Windows\winsxs\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_d08d7da0442a985d\msvcp80.dll (Microsoft Corporation)
MOD - C:\Windows\winsxs\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.6002.18305_none_5cb72f2a088b0ed3\comctl32.dll (Microsoft Corporation)
MOD - C:\Program Files\CheckPoint\ZAForceField\WOW64\Plugins\ISWSHEX.dll (Check Point Software Technologies)
MOD - C:\Windows\SysWOW64\wintrust.dll (Microsoft Corporation)
MOD - C:\Windows\SysWOW64\imagehlp.dll (Microsoft Corporation)
========== Win32 Services (SafeList) ==========
SRV:64bit: - (AMD External Events Utility) -- C:\Windows\SysNative\atiesrxx.exe (AMD)
SRV:64bit: - (IswSvc) -- C:\Program Files\CheckPoint\ZAForceField\IswSvc.exe (Check Point Software Technologies)
SRV:64bit: - (WinDefend) -- C:\Program Files\Windows Defender\MpSvc.dll (Microsoft Corporation)
SRV - (SplashtopRemoteService) -- C:\Program Files (x86)\Splashtop\Splashtop Remote\Server\SRService.exe (Splashtop Inc.)
SRV - (AdobeARMservice) -- C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe (Adobe Systems Incorporated)
SRV - (TomTomHOMEService) -- C:\Program Files (x86)\TomTom HOME 2\TomTomHOMEService.exe (TomTom)
SRV - (SSUService) -- C:\Program Files (x86)\Splashtop\Splashtop Software Updater\SSUService.exe (Splashtop Inc.)
SRV - (PassThru Service) -- C:\Program Files (x86)\HTC\Internet Pass-Through\PassThruSvr.exe ()
SRV - (vsmon) -- C:\Windows\SysWOW64\ZoneLabs\vsmon.exe (Check Point Software Technologies LTD)
SRV - (clr_optimization_v4.0.30319_32) -- C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe (Microsoft Corporation)
SRV - (clr_optimization_v2.0.50727_32) -- C:\Windows\Microsoft.NET\Framework\v2.0.50727\mscorsvw.exe (Microsoft Corporation)
========== Driver Services (SafeList) ==========
DRV:64bit: - (atikmdag) -- C:\Windows\SysNative\DRIVERS\atikmdag.sys (ATI Technologies Inc.)
DRV:64bit: - (amdkmdag) -- C:\Windows\SysNative\DRIVERS\atikmdag.sys (ATI Technologies Inc.)
DRV:64bit: - (amdkmdap) -- C:\Windows\SysNative\DRIVERS\atikmpag.sys (Advanced Micro Devices, Inc.)
DRV:64bit: - (RTL8169) -- C:\Windows\SysNative\DRIVERS\Rtlh64.sys (Realtek )
DRV:64bit: - (ISWKL) -- C:\Program Files\CheckPoint\ZAForceField\ISWKL.sys (Check Point Software Technologies)
DRV:64bit: - (htcnprot) -- C:\Windows\SysNative\DRIVERS\htcnprot.sys (Windows (R) Win 7 DDK provider)
DRV:64bit: - (Vsdatant) -- C:\Windows\SysNative\DRIVERS\vsdatant.sys (Check Point Software Technologies LTD)
DRV:64bit: - (KLIF) -- C:\Windows\SysNative\DRIVERS\klif.sys (Kaspersky Lab)
DRV:64bit: - (kl1) -- C:\Windows\SysNative\DRIVERS\kl1.sys (Kaspersky Lab)
DRV:64bit: - (WpdUsb) -- C:\Windows\SysNative\DRIVERS\wpdusb.sys (Microsoft Corporation)
DRV:64bit: - (HTCAND64) -- C:\Windows\SysNative\Drivers\ANDROIDUSB.sys (HTC, Corporation)
DRV:64bit: - (GEARAspiWDM) -- C:\Windows\SysNative\DRIVERS\GEARAspiWDM.sys (GEAR Software Inc.)
DRV:64bit: - (usb_rndisx) -- C:\Windows\SysNative\DRIVERS\usb8023x.sys (Microsoft Corporation)
DRV:64bit: - (Ntfs) -- C:\Windows\SysNative\Wbem\ntfs.mof ()
========== Standard Registry (All) ==========
========== Internet Explorer ==========
IE:64bit: - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Page_URL = MSN.com
IE:64bit: - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Search_URL = Bing
IE:64bit: - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Secondary_Page_URL = [binary data]
IE:64bit: - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Extensions Off Page = about:NoAdd-ons
IE:64bit: - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Local Page = %SystemRoot%\system32\blank.htm
IE:64bit: - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Search Page = Bing
IE:64bit: - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Security Risk Page = about:SecurityRisk
IE:64bit: - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = MSN.com
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Page_URL = MSN.com
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Search_URL = Bing
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Secondary_Page_URL = [binary data]
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Extensions Off Page = about:NoAdd-ons
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Local Page = %SystemRoot%\system32\blank.htm
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Search Page = Bing
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Security Risk Page = about:SecurityRisk
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = MSN.com
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Local Page = C:\Windows\system32\blank.htm
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Search Page = Bing
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = MSN.com
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,StartPageCache = 1
IE - HKCU\..\URLSearchHook: {CFBFAE00-17A6-11D0-99CB-00C04FD64497} - C:\Windows\SysWOW64\ieframe.dll (Microsoft Corporation)
IE - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
IE - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyOverride" = *.local
========== FireFox ==========
FF - prefs.js..extensions.enabledItems: [email protected]:1.7.1
FF - prefs.js..extensions.enabledItems: [email protected]:1.0.2
FF - HKLM\software\mozilla\Firefox\Extensions\\{FFB96CC1-7EB3-449D-B827-DB661701C6BB}: C:\Program Files\CheckPoint\ZAForceField\WOW64\TrustChecker [2011/03/30 19:02:10 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Firefox\Extensions\\{20a82645-c095-46ed-80e3-08825760534b}: c:\Windows\Microsoft.NET\Framework\v3.5\Windows Presentation Foundation\DotNetAssistantExtension\ [2011/04/02 16:40:34 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Firefox\Extensions\\[email protected]: C:\Program Files (x86)\Splashtop\Splashtop Remote\Server\plugin\FFExtensions [2011/05/04 16:49:52 | 000,000,000 | ---D | M]
[2011/04/06 09:22:48 | 000,000,000 | ---D | M] (No name found) -- C:\Users\alan\AppData\Roaming\Mozilla\Extensions
[2011/04/06 09:22:48 | 000,000,000 | ---D | M] (No name found) -- C:\Users\alan\AppData\Roaming\Mozilla\Extensions\[email protected]
[2011/04/06 09:24:09 | 000,000,000 | ---D | M] (Map status indicator) -- C:\PROGRAM FILES (X86)\TOMTOM HOME 2\XUL\EXTENSIONS\[email protected]
O1 HOSTS File: ([2006/09/18 22:37:24 | 000,000,761 | ---- | M]) - C:\Windows\SysNative\drivers\etc\Hosts
O1 - Hosts: 127.0.0.1 localhost
O1 - Hosts: ::1 localhost
O2:64bit: - BHO: (ZoneAlarm Toolbar Registrar) - {8A4A36C2-0535-4D2C-BD3D-496CB7EED6E3} - C:\Program Files\CheckPoint\ZAForceField\TrustChecker\bin\TrustCheckerIEPlugin.dll (Check Point Software Technologies)
O2:64bit: - BHO: (Java(tm) Plug-In 2 SSV Helper) - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre6\bin\jp2ssv.dll (Sun Microsystems, Inc.)
O2 - BHO: (Adobe PDF Link Helper) - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll (Adobe Systems Incorporated)
O2 - BHO: (Groove GFS Browser Helper) - {72853161-30C5-4D22-B7F9-0BBC1D38A37E} - C:\Program Files (x86)\Microsoft Office\Office12\GrooveShellExtensions.dll (Microsoft Corporation)
O2 - BHO: (ZoneAlarm Toolbar Registrar) - {8A4A36C2-0535-4D2C-BD3D-496CB7EED6E3} - C:\Program Files\CheckPoint\ZAForceField\WOW64\TrustChecker\bin\TrustCheckerIEPlugin.dll (Check Point Software Technologies)
O2 - BHO: (Java(tm) Plug-In 2 SSV Helper) - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files (x86)\Java\jre6\bin\jp2ssv.dll (Sun Microsystems, Inc.)
O3:64bit: - HKLM\..\Toolbar: (ZoneAlarm Toolbar) - {EE2AC4E5-B0B0-4EC6-88A9-BCA1A32AB107} - C:\Program Files\CheckPoint\ZAForceField\TrustChecker\bin\TrustCheckerIEPlugin.dll (Check Point Software Technologies)
O3 - HKLM\..\Toolbar: (ZoneAlarm Toolbar) - {EE2AC4E5-B0B0-4EC6-88A9-BCA1A32AB107} - C:\Program Files\CheckPoint\ZAForceField\WOW64\TrustChecker\bin\TrustCheckerIEPlugin.dll (Check Point Software Technologies)
O3:64bit: - HKCU\..\Toolbar\WebBrowser: (ZoneAlarm Toolbar) - {EE2AC4E5-B0B0-4EC6-88A9-BCA1A32AB107} - C:\Program Files\CheckPoint\ZAForceField\TrustChecker\bin\TrustCheckerIEPlugin.dll (Check Point Software Technologies)
O3 - HKCU\..\Toolbar\WebBrowser: (ZoneAlarm Toolbar) - {EE2AC4E5-B0B0-4EC6-88A9-BCA1A32AB107} - C:\Program Files\CheckPoint\ZAForceField\WOW64\TrustChecker\bin\TrustCheckerIEPlugin.dll (Check Point Software Technologies)
O4:64bit: - HKLM..\Run: [ISW] C:\Program Files\CheckPoint\ZAForceField\ForceField.exe (Check Point Software Technologies)
O4:64bit: - HKLM..\Run: [Windows Defender] C:\Program Files\Windows Defender\MSASCui.exe (Microsoft Corporation)
O4 - HKLM..\Run: [Adobe ARM] C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe (Adobe Systems Incorporated)
O4 - HKLM..\Run: [StartCCC] C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static\CLIStart.exe (Advanced Micro Devices, Inc.)
O4 - HKLM..\Run: [SunJavaUpdateSched] C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe (Sun Microsystems, Inc.)
O4 - HKLM..\Run: [ZoneAlarm Client] C:\Program Files (x86)\Zone Labs\ZoneAlarm\zlclient.exe (Check Point Software Technologies LTD)
O4 - HKCU..\Run: [ctfmon.exe] C:\Windows\SysWOW64\ctfmon.exe (Microsoft Corporation)
O4 - HKCU..\Run: [Google Update] C:\Users\alan\AppData\Local\Google\Update\GoogleUpdate.exe (Google Inc.)
O6 - HKLM\Software\Policies\Microsoft\Internet Explorer\control panel present
O6 - HKLM\Software\Policies\Microsoft\Internet Explorer\restrictions present
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoActiveDesktop = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoActiveDesktopChanges = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: ForceActiveDesktopOn = 0
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: BindDirectlyToPropertySetStorage = 0
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: ConsentPromptBehaviorAdmin = 2
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: ConsentPromptBehaviorUser = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: EnableInstallerDetection = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: EnableLUA = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: EnableSecureUIAPaths = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: EnableVirtualization = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: PromptOnSecureDesktop = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: ValidateAdminCodeSignatures = 0
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: dontdisplaylastusername = 0
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: legalnoticecaption =
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: legalnoticetext =
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: scforceoption = 0
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: shutdownwithoutlogon = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: undockwithoutlogon = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: FilterAdministratorToken = 0
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: EnableUIADesktopToggle = 0
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System\UIPI\Clipboard\ExceptionFormats: CF_TEXT = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System\UIPI\Clipboard\ExceptionFormats: CF_BITMAP = 2
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System\UIPI\Clipboard\ExceptionFormats: CF_OEMTEXT = 7
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System\UIPI\Clipboard\ExceptionFormats: CF_DIB = 8
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System\UIPI\Clipboard\ExceptionFormats: CF_PALETTE = 9
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System\UIPI\Clipboard\ExceptionFormats: CF_UNICODETEXT = 13
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System\UIPI\Clipboard\ExceptionFormats: CF_DIBV5 = 17
O7 - HKCU\Software\Policies\Microsoft\Internet Explorer\control panel present
O7 - HKCU\Software\Policies\Microsoft\Internet Explorer\restrictions present
O8:64bit: - Extra context menu item: E&xport to Microsoft Excel - C:\Program Files (x86)\Microsoft Office\Office12\EXCEL.EXE (Microsoft Corporation)
O8 - Extra context menu item: E&xport to Microsoft Excel - C:\Program Files (x86)\Microsoft Office\Office12\EXCEL.EXE (Microsoft Corporation)
O9 - Extra Button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files (x86)\Microsoft Office\Office12\ONBttnIE.dll (Microsoft Corporation)
O9 - Extra 'Tools' menuitem : S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files (x86)\Microsoft Office\Office12\ONBttnIE.dll (Microsoft Corporation)
O9 - Extra Button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\Program Files (x86)\Microsoft Office\Office12\REFIEBAR.DLL (Microsoft Corporation)
O10:64bit: - NameSpace_Catalog5\Catalog_Entries\000000000001 [] - C:\Windows\SysNative\NLAapi.dll (Microsoft Corporation)
O10:64bit: - NameSpace_Catalog5\Catalog_Entries\000000000002 [] - C:\Windows\SysNative\napinsp.dll (Microsoft Corporation)
O10:64bit: - NameSpace_Catalog5\Catalog_Entries\000000000003 [] - C:\Windows\SysNative\pnrpnsp.dll (Microsoft Corporation)
O10:64bit: - NameSpace_Catalog5\Catalog_Entries\000000000004 [] - C:\Windows\SysNative\pnrpnsp.dll (Microsoft Corporation)
O10:64bit: - NameSpace_Catalog5\Catalog_Entries\000000000005 [] - C:\Windows\SysNative\mswsock.dll (Microsoft Corporation)
O10:64bit: - NameSpace_Catalog5\Catalog_Entries\000000000006 [] - C:\Windows\SysNative\winrnr.dll (Microsoft Corporation)
O10:64bit: - NameSpace_Catalog5\Catalog_Entries\000000000007 [] - C:\Program Files (x86)\Bonjour\mdnsNSP.dll (Apple Inc.)
O10:64bit: - Protocol_Catalog9\Catalog_Entries\000000000001 - C:\Windows\SysNative\mswsock.dll (Microsoft Corporation)
O10:64bit: - Protocol_Catalog9\Catalog_Entries\000000000002 - C:\Windows\SysNative\mswsock.dll (Microsoft Corporation)
O10:64bit: - Protocol_Catalog9\Catalog_Entries\000000000003 - C:\Windows\SysNative\mswsock.dll (Microsoft Corporation)
O10:64bit: - Protocol_Catalog9\Catalog_Entries\000000000004 - C:\Windows\SysNative\mswsock.dll (Microsoft Corporation)
O10:64bit: - Protocol_Catalog9\Catalog_Entries\000000000005 - C:\Windows\SysNative\mswsock.dll (Microsoft Corporation)
O10:64bit: - Protocol_Catalog9\Catalog_Entries\000000000006 - C:\Windows\SysNative\mswsock.dll (Microsoft Corporation)
O10:64bit: - Protocol_Catalog9\Catalog_Entries\000000000007 - C:\Windows\SysNative\mswsock.dll (Microsoft Corporation)
O10:64bit: - Protocol_Catalog9\Catalog_Entries\000000000008 - C:\Windows\SysNative\mswsock.dll (Microsoft Corporation)
O10:64bit: - Protocol_Catalog9\Catalog_Entries\000000000009 - C:\Windows\SysNative\mswsock.dll (Microsoft Corporation)
O10:64bit: - Protocol_Catalog9\Catalog_Entries\000000000010 - C:\Windows\SysNative\mswsock.dll (Microsoft Corporation)
O10 - NameSpace_Catalog5\Catalog_Entries\000000000001 [] - C:\Windows\SysWOW64\nlaapi.dll (Microsoft Corporation)
O10 - NameSpace_Catalog5\Catalog_Entries\000000000002 [] - C:\Windows\SysWOW64\NapiNSP.dll (Microsoft Corporation)
O10 - NameSpace_Catalog5\Catalog_Entries\000000000003 [] - C:\Windows\SysWOW64\pnrpnsp.dll (Microsoft Corporation)
O10 - NameSpace_Catalog5\Catalog_Entries\000000000004 [] - C:\Windows\SysWOW64\pnrpnsp.dll (Microsoft Corporation)
O10 - NameSpace_Catalog5\Catalog_Entries\000000000005 [] - C:\Windows\SysWOW64\mswsock.dll (Microsoft Corporation)
O10 - NameSpace_Catalog5\Catalog_Entries\000000000006 [] - C:\Windows\SysWOW64\winrnr.dll (Microsoft Corporation)
O10 - NameSpace_Catalog5\Catalog_Entries\000000000007 [] - C:\Program Files (x86)\Bonjour\mdnsNSP.dll (Apple Inc.)
O10 - Protocol_Catalog9\Catalog_Entries\000000000001 - C:\Windows\SysWOW64\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000002 - C:\Windows\SysWOW64\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000003 - C:\Windows\SysWOW64\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000004 - C:\Windows\SysWOW64\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000005 - C:\Windows\SysWOW64\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000006 - C:\Windows\SysWOW64\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000007 - C:\Windows\SysWOW64\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000008 - C:\Windows\SysWOW64\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000009 - C:\Windows\SysWOW64\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000010 - C:\Windows\SysWOW64\mswsock.dll (Microsoft Corporation)
O13 - gopher Prefix: missing
O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} http://java.sun.com/update/1.6.0/jinstall-1_6_0_26-windows-i586.cab (Java Plug-in 1.6.0_26)
O16 - DPF: {CAFEEFAC-0016-0000-0026-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0_26-windows-i586.cab (Java Plug-in 1.6.0_26)
O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0_26-windows-i586.cab (Java Plug-in 1.6.0_26)
O16 - DPF: {0D41B8C5-2599-4893-8183-00195EC8D5F9} http://support.asus.com/select/asusTek_sys_ctrl3.cab (asusTek_sysctrl Class)
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 192.168.0.1
O18:64bit: - Protocol\Handler\about {3050F406-98B5-11CF-BB82-00AA00BDCE0B} - C:\Windows\SysNative\mshtml.dll (Microsoft Corporation)
O18:64bit: - Protocol\Handler\cdl {3dd53d40-7b8b-11D0-b013-00aa0059ce02} - C:\Windows\SysNative\urlmon.dll (Microsoft Corporation)
O18:64bit: - Protocol\Handler\dvd {12D51199-0DB5-46FE-A120-47A3D7D937CC} - C:\Windows\SysNative\msvidctl.dll (Microsoft Corporation)
O18:64bit: - Protocol\Handler\file {79eac9e7-baf9-11ce-8c82-00aa004ba90b} - C:\Windows\SysNative\urlmon.dll (Microsoft Corporation)
O18:64bit: - Protocol\Handler\ftp {79eac9e3-baf9-11ce-8c82-00aa004ba90b} - C:\Windows\SysNative\urlmon.dll (Microsoft Corporation)
O18:64bit: - Protocol\Handler\grooveLocalGWS {88FED34C-F0CA-4636-A375-3CB6248B04CD} - Reg Error: Key error. File not found
O18:64bit: - Protocol\Handler\http {79eac9e2-baf9-11ce-8c82-00aa004ba90b} - C:\Windows\SysNative\urlmon.dll (Microsoft Corporation)
O18:64bit: - Protocol\Handler\https {79eac9e5-baf9-11ce-8c82-00aa004ba90b} - C:\Windows\SysNative\urlmon.dll (Microsoft Corporation)
O18:64bit: - Protocol\Handler\its {9D148291-B9C8-11D0-A4CC-0000F80149F6} - C:\Windows\SysNative\itss.dll (Microsoft Corporation)
O18:64bit: - Protocol\Handler\javascript {3050F3B2-98B5-11CF-BB82-00AA00BDCE0B} - C:\Windows\SysNative\mshtml.dll (Microsoft Corporation)
O18:64bit: - Protocol\Handler\local {79eac9e7-baf9-11ce-8c82-00aa004ba90b} - C:\Windows\SysNative\urlmon.dll (Microsoft Corporation)
O18:64bit: - Protocol\Handler\mailto {3050f3DA-98B5-11CF-BB82-00AA00BDCE0B} - C:\Windows\SysNative\mshtml.dll (Microsoft Corporation)
O18:64bit: - Protocol\Handler\mhtml {05300401-BCBC-11d0-85E3-00C04FD85AB4} - C:\Windows\SysNative\inetcomm.dll (Microsoft Corporation)
O18:64bit: - Protocol\Handler\mk {79eac9e6-baf9-11ce-8c82-00aa004ba90b} - C:\Windows\SysNative\urlmon.dll (Microsoft Corporation)
O18:64bit: - Protocol\Handler\ms-help {314111c7-a502-11d2-bbca-00c04f8ec294} - Reg Error: Key error. File not found
O18:64bit: - Protocol\Handler\ms-its {9D148291-B9C8-11D0-A4CC-0000F80149F6} - C:\Windows\SysNative\itss.dll (Microsoft Corporation)
O18:64bit: - Protocol\Handler\res {3050F3BC-98B5-11CF-BB82-00AA00BDCE0B} - C:\Windows\SysNative\mshtml.dll (Microsoft Corporation)
O18:64bit: - Protocol\Handler\tv {CBD30858-AF45-11D2-B6D6-00C04FBBDE6E} - C:\Windows\SysNative\msvidctl.dll (Microsoft Corporation)
O18:64bit: - Protocol\Handler\vbscript {3050F3B2-98B5-11CF-BB82-00AA00BDCE0B} - C:\Windows\SysNative\mshtml.dll (Microsoft Corporation)
O18 - Protocol\Handler\about {3050F406-98B5-11CF-BB82-00AA00BDCE0B} - C:\Windows\SysWOW64\mshtml.dll (Microsoft Corporation)
O18 - Protocol\Handler\cdl {3dd53d40-7b8b-11D0-b013-00aa0059ce02} - C:\Windows\SysWOW64\urlmon.dll (Microsoft Corporation)
O18 - Protocol\Handler\dvd {12D51199-0DB5-46FE-A120-47A3D7D937CC} - C:\Windows\SysWOW64\MSVidCtl.dll (Microsoft Corporation)
O18 - Protocol\Handler\file {79eac9e7-baf9-11ce-8c82-00aa004ba90b} - C:\Windows\SysWOW64\urlmon.dll (Microsoft Corporation)
O18 - Protocol\Handler\ftp {79eac9e3-baf9-11ce-8c82-00aa004ba90b} - C:\Windows\SysWOW64\urlmon.dll (Microsoft Corporation)
O18 - Protocol\Handler\grooveLocalGWS {88FED34C-F0CA-4636-A375-3CB6248B04CD} - C:\Program Files (x86)\Microsoft Office\Office12\GrooveSystemServices.dll (Microsoft Corporation)
O18 - Protocol\Handler\http {79eac9e2-baf9-11ce-8c82-00aa004ba90b} - C:\Windows\SysWOW64\urlmon.dll (Microsoft Corporation)
O18 - Protocol\Handler\https {79eac9e5-baf9-11ce-8c82-00aa004ba90b} - C:\Windows\SysWOW64\urlmon.dll (Microsoft Corporation)
O18 - Protocol\Handler\its {9D148291-B9C8-11D0-A4CC-0000F80149F6} - C:\Windows\SysWOW64\itss.dll (Microsoft Corporation)
O18 - Protocol\Handler\javascript {3050F3B2-98B5-11CF-BB82-00AA00BDCE0B} - C:\Windows\SysWOW64\mshtml.dll (Microsoft Corporation)
O18 - Protocol\Handler\local {79eac9e7-baf9-11ce-8c82-00aa004ba90b} - C:\Windows\SysWOW64\urlmon.dll (Microsoft Corporation)
O18 - Protocol\Handler\mailto {3050f3DA-98B5-11CF-BB82-00AA00BDCE0B} - C:\Windows\SysWOW64\mshtml.dll (Microsoft Corporation)
O18 - Protocol\Handler\mhtml {05300401-BCBC-11d0-85E3-00C04FD85AB4} - C:\Windows\SysWOW64\inetcomm.dll (Microsoft Corporation)
O18 - Protocol\Handler\mk {79eac9e6-baf9-11ce-8c82-00aa004ba90b} - C:\Windows\SysWOW64\urlmon.dll (Microsoft Corporation)
O18 - Protocol\Handler\ms-help {314111c7-a502-11d2-bbca-00c04f8ec294} - C:\Program Files (x86)\Common Files\microsoft shared\Help\hxds.dll (Microsoft Corporation)
O18 - Protocol\Handler\ms-its {9D148291-B9C8-11D0-A4CC-0000F80149F6} - C:\Windows\SysWOW64\itss.dll (Microsoft Corporation)
O18 - Protocol\Handler\res {3050F3BC-98B5-11CF-BB82-00AA00BDCE0B} - C:\Windows\SysWOW64\mshtml.dll (Microsoft Corporation)
O18 - Protocol\Handler\tv {CBD30858-AF45-11D2-B6D6-00C04FBBDE6E} - C:\Windows\SysWOW64\MSVidCtl.dll (Microsoft Corporation)
O18 - Protocol\Handler\vbscript {3050F3B2-98B5-11CF-BB82-00AA00BDCE0B} - C:\Windows\SysWOW64\mshtml.dll (Microsoft Corporation)
O18:64bit: - Protocol\Filter\application/octet-stream {1E66F26B-79EE-11D2-8710-00C04F79ED0D} - C:\Windows\SysNative\mscoree.dll (Microsoft Corporation)
O18:64bit: - Protocol\Filter\application/x-complus {1E66F26B-79EE-11D2-8710-00C04F79ED0D} - C:\Windows\SysNative\mscoree.dll (Microsoft Corporation)
O18:64bit: - Protocol\Filter\application/x-msdownload {1E66F26B-79EE-11D2-8710-00C04F79ED0D} - C:\Windows\SysNative\mscoree.dll (Microsoft Corporation)
O18:64bit: - Protocol\Filter\deflate {8f6b0360-b80d-11d0-a9b3-006097942311} - C:\Windows\SysNative\urlmon.dll (Microsoft Corporation)
O18:64bit: - Protocol\Filter\gzip {8f6b0360-b80d-11d0-a9b3-006097942311} - C:\Windows\SysNative\urlmon.dll (Microsoft Corporation)
O18:64bit: - Protocol\Filter\text/xml {807563E5-5146-11D5-A672-00B0D022E945} - C:\Program Files\Common Files\Microsoft Shared\OFFICE12\MSOXMLMF.DLL (Microsoft Corporation)
O18 - Protocol\Filter\application/octet-stream {1E66F26B-79EE-11D2-8710-00C04F79ED0D} - C:\Windows\SysWow64\mscoree.dll (Microsoft Corporation)
O18 - Protocol\Filter\application/x-complus {1E66F26B-79EE-11D2-8710-00C04F79ED0D} - C:\Windows\SysWow64\mscoree.dll (Microsoft Corporation)
O18 - Protocol\Filter\application/x-msdownload {1E66F26B-79EE-11D2-8710-00C04F79ED0D} - C:\Windows\SysWow64\mscoree.dll (Microsoft Corporation)
O18 - Protocol\Filter\deflate {8f6b0360-b80d-11d0-a9b3-006097942311} - C:\Windows\SysWOW64\urlmon.dll (Microsoft Corporation)
O18 - Protocol\Filter\gzip {8f6b0360-b80d-11d0-a9b3-006097942311} - C:\Windows\SysWOW64\urlmon.dll (Microsoft Corporation)
O18 - Protocol\Filter\text/xml {807563E5-5146-11D5-A672-00B0D022E945} - C:\Program Files (x86)\Common Files\microsoft shared\OFFICE12\MSOXMLMF.DLL (Microsoft Corporation)
O20:64bit: - HKLM Winlogon: Shell - (explorer.exe) - C:\Windows\explorer.exe (Microsoft Corporation)
O20:64bit: - HKLM Winlogon: UserInit - (C:\Windows\system32\userinit.exe) - C:\Windows\SysNative\userinit.exe (Microsoft Corporation)
O20:64bit: - HKLM Winlogon: VMApplet - (rundll32 shell32) - C:\Windows\SysNative\shell32.dll (Microsoft Corporation)
O20:64bit: - HKLM Winlogon: VMApplet - (Control_RunDLL "sysdm.cpl") - C:\Windows\SysNative\sysdm.cpl (Microsoft Corporation)
O20 - HKLM Winlogon: Shell - (explorer.exe) - C:\Windows\SysWow64\explorer.exe (Microsoft Corporation)
O20 - HKLM Winlogon: UserInit - (c:\windows\syswow64\userinit.exe) - c:\Windows\SysWOW64\userinit.exe (Microsoft Corporation)
O20 - HKLM Winlogon: VMApplet - (rundll32 shell32) - C:\Windows\SysWow64\shell32.dll (Microsoft Corporation)
O20 - HKLM Winlogon: VMApplet - (Control_RunDLL "sysdm.cpl") - C:\Windows\SysWow64\sysdm.cpl (Microsoft Corporation)
O21:64bit: - SSODL: WebCheck - {E6FB5E20-DE35-11CF-9C87-00AA005127ED} - C:\Windows\SysNative\webcheck.dll (Microsoft Corporation)
O21 - SSODL: WebCheck - {E6FB5E20-DE35-11CF-9C87-00AA005127ED} - C:\Windows\SysWOW64\webcheck.dll (Microsoft Corporation)
O22:64bit: - SharedTaskScheduler: {8C7461EF-2B13-11d2-BE35-3078302C2030} - Component Categories cache daemon - C:\Windows\SysNative\browseui.dll (Microsoft Corporation)
O22 - SharedTaskScheduler: {8C7461EF-2B13-11d2-BE35-3078302C2030} - Component Categories cache daemon - C:\Windows\SysWOW64\browseui.dll (Microsoft Corporation)
O24 - Desktop WallPaper: C:\Users\alan\AppData\Roaming\Microsoft\Windows Photo Gallery\Windows Photo Gallery Wallpaper.jpg
O24 - Desktop BackupWallPaper: C:\Users\alan\AppData\Roaming\Microsoft\Windows Photo Gallery\Windows Photo Gallery Wallpaper.jpg
O28 - HKLM ShellExecuteHooks: {B5A7F190-DDA6-4420-B3BA-52453494E6CD} - C:\Program Files (x86)\Microsoft Office\Office12\GrooveShellExtensions.dll (Microsoft Corporation)
O29:64bit: - HKLM SecurityProviders - (credssp.dll) - C:\Windows\SysWow64\credssp.dll (Microsoft Corporation)
O29 - HKLM SecurityProviders - (credssp.dll) - C:\Windows\SysWow64\credssp.dll (Microsoft Corporation)
O30:64bit: - LSA: Authentication Packages - (msv1_0) - C:\Windows\SysNative\msv1_0.dll (Microsoft Corporation)
O30 - LSA: Authentication Packages - (msv1_0) - C:\Windows\SysWow64\msv1_0.dll (Microsoft Corporation)
O30:64bit: - LSA: Security Packages - (kerberos) - C:\Windows\SysNative\kerberos.dll (Microsoft Corporation)
O30:64bit: - LSA: Security Packages - (msv1_0) - C:\Windows\SysNative\msv1_0.dll (Microsoft Corporation)
O30:64bit: - LSA: Security Packages - (schannel) - C:\Windows\SysNative\schannel.dll (Microsoft Corporation)
O30:64bit: - LSA: Security Packages - (wdigest) - C:\Windows\SysNative\wdigest.dll (Microsoft Corporation)
O30:64bit: - LSA: Security Packages - (tspkg) - C:\Windows\SysNative\tspkg.dll (Microsoft Corporation)
O30 - LSA: Security Packages - (kerberos) - C:\Windows\SysWow64\kerberos.dll (Microsoft Corporation)
O30 - LSA: Security Packages - (msv1_0) - C:\Windows\SysWow64\msv1_0.dll (Microsoft Corporation)
O30 - LSA: Security Packages - (schannel) - C:\Windows\SysWow64\schannel.dll (Microsoft Corporation)
O30 - LSA: Security Packages - (wdigest) - C:\Windows\SysWow64\wdigest.dll (Microsoft Corporation)
O30 - LSA: Security Packages - (tspkg) - C:\Windows\SysWow64\tspkg.dll (Microsoft Corporation)
O31 - SafeBoot: AlternateShell - cmd.exe
O32 - HKLM CDRom: AutoRun - 1
O34 - HKLM BootExecute: (autocheck autochk *) - File not found
O35:64bit: - HKLM\..comfile [open] -- "%1" %*
O35:64bit: - HKLM\..exefile [open] -- "%1" %*
O35 - HKLM\..comfile [open] -- "%1" %*
O35 - HKLM\..exefile [open] -- "%1" %*
O37:64bit: - HKLM\...com [@ = comfile] -- "%1" %*
O37:64bit: - HKLM\...exe [@ = exefile] -- "%1" %*
O37 - HKLM\...com [@ = comfile] -- "%1" %*
O37 - HKLM\...exe [@ = exefile] -- "%1" %*
O37 - HKCU\...exe [@ = exefile] -- Reg Error: Key error. File not found
========== Files/Folders - Created Within 30 Days ==========
[2011/06/30 22:34:27 | 000,580,096 | ---- | C] (OldTimer Tools) -- C:\Users\alan\Desktop\OTL.exe
[2011/06/30 11:13:56 | 000,000,000 | ---D | C] -- C:\ProgramData\STOPzilla!
[2011/06/28 13:05:10 | 000,000,000 | ---D | C] -- C:\Users\alan\garmin
[2011/06/21 14:16:40 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Common Files\Adobe
[2011/06/21 10:33:32 | 000,000,000 | ---D | C] -- C:\Windows\pss
[2011/06/15 16:19:15 | 000,000,000 | ---D | C] -- C:\Users\alan\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\DVD Catalyst
[2011/06/15 15:17:02 | 000,759,808 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\mshtmled.dll
[2011/06/15 15:17:02 | 000,478,208 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\mshtmled.dll
[2011/06/15 15:17:01 | 000,590,848 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\msfeeds.dll
[2011/06/15 15:17:01 | 000,485,376 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\html.iec
[2011/06/15 15:17:01 | 000,471,040 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\msfeeds.dll
[2011/06/15 15:17:01 | 000,389,632 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\html.iec
[2011/06/15 15:17:01 | 000,249,856 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\iepeers.dll
[2011/06/15 15:17:01 | 000,193,024 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\iepeers.dll
[2011/06/15 15:17:00 | 000,086,528 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\ieencode.dll
[2011/06/15 15:17:00 | 000,078,336 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\ieencode.dll
[2011/06/15 15:16:59 | 000,422,400 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\ieapfltr.dll
[2011/06/15 15:16:59 | 000,380,928 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\ieapfltr.dll
[2011/06/15 15:16:41 | 000,847,360 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\oleaut32.dll
[2011/06/15 10:53:48 | 000,000,000 | ---D | C] -- C:\Users\alan\E PAD
[2011/06/10 15:06:45 | 000,000,000 | R--D | C] -- C:\Users\alan\Dropbox
[2011/06/10 15:04:32 | 000,000,000 | ---D | C] -- C:\Users\alan\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Dropbox
[2011/06/10 15:03:47 | 000,000,000 | ---D | C] -- C:\Users\alan\AppData\Roaming\Dropbox
[2011/06/08 14:19:50 | 000,000,000 | ---D | C] -- C:\android
[2011/06/08 14:19:13 | 000,525,544 | ---- | C] (Sun Microsystems, Inc.) -- C:\Windows\SysNative\deployJava1.dll
[2011/06/08 14:19:13 | 000,190,752 | ---- | C] (Sun Microsystems, Inc.) -- C:\Windows\SysNative\javaws.exe
[2011/06/08 14:19:13 | 000,171,808 | ---- | C] (Sun Microsystems, Inc.) -- C:\Windows\SysNative\javaw.exe
[2011/06/08 14:19:13 | 000,171,808 | ---- | C] (Sun Microsystems, Inc.) -- C:\Windows\SysNative\java.exe
[2011/06/08 14:18:14 | 000,000,000 | ---D | C] -- C:\Program Files\Java
[2011/06/08 14:11:26 | 000,000,000 | ---D | C] -- C:\Users\alan\.android
[2011/06/08 14:11:24 | 000,000,000 | ---D | C] -- C:\ProgramData\Sun
[2011/06/08 14:11:22 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Common Files\Java
[2011/06/08 14:10:18 | 000,472,808 | ---- | C] (Sun Microsystems, Inc.) -- C:\Windows\SysWow64\deployJava1.dll
[2011/06/08 14:10:18 | 000,157,472 | ---- | C] (Sun Microsystems, Inc.) -- C:\Windows\SysWow64\javaws.exe
[2011/06/08 14:10:18 | 000,145,184 | ---- | C] (Sun Microsystems, Inc.) -- C:\Windows\SysWow64\javaw.exe
[2011/06/08 14:10:18 | 000,145,184 | ---- | C] (Sun Microsystems, Inc.) -- C:\Windows\SysWow64\java.exe
[2011/06/08 14:09:46 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Java
[2011/06/02 15:52:49 | 000,000,000 | ---D | C] -- C:\af0a89f5e38c9c706f86dc14e767a766
[2011/04/25 12:48:15 | 000,082,816 | ---- | C] (VSO Software) -- C:\Users\alan\AppData\Roaming\pcouffin.sys
[1 C:\Windows\SysNative\drivers\*.tmp files -> C:\Windows\SysNative\drivers\*.tmp -> ]
========== Files - Modified Within 30 Days ==========
[2011/06/30 22:38:35 | 000,703,388 | ---- | M] () -- C:\Windows\SysNative\PerfStringBackup.INI
[2011/06/30 22:38:35 | 000,608,760 | ---- | M] () -- C:\Windows\SysNative\perfh009.dat
[2011/06/30 22:38:35 | 000,108,268 | ---- | M] () -- C:\Windows\SysNative\perfc009.dat
[2011/06/30 22:34:26 | 000,580,096 | ---- | M] (OldTimer Tools) -- C:\Users\alan\Desktop\OTL.exe
[2011/06/30 22:34:09 | 000,459,264 | ---- | M] () -- C:\Users\alan\Desktop\CKScanner.exe
[2011/06/30 22:31:43 | 000,003,616 | -H-- | M] () -- C:\Windows\SysNative\7B296FB0-376B-497e-B012-9C450E1B7327-2P-1.C7483456-A289-439d-8115-601632D005A0
[2011/06/30 22:31:43 | 000,003,616 | -H-- | M] () -- C:\Windows\SysNative\7B296FB0-376B-497e-B012-9C450E1B7327-2P-0.C7483456-A289-439d-8115-601632D005A0
[2011/06/30 22:31:40 | 000,067,584 | --S- | M] () -- C:\Windows\bootstat.dat
[2011/06/30 12:17:04 | 000,000,904 | ---- | M] () -- C:\Windows\tasks\GoogleUpdateTaskUserS-1-5-21-4240333563-575618758-3584005618-1000UA.job
[2011/06/30 11:25:45 | 000,000,528 | ---- | M] () -- C:\Windows\SysNative\drivers\kgpcpy.cfg
[2011/06/30 11:24:45 | 000,000,112 | ---- | M] () -- C:\Windows\SysNative\drivers\kgpfr2.cfg
[2011/06/30 10:17:00 | 000,000,852 | ---- | M] () -- C:\Windows\tasks\GoogleUpdateTaskUserS-1-5-21-4240333563-575618758-3584005618-1000Core.job
[2011/06/30 10:15:00 | 000,011,196 | -HS- | M] () -- C:\Users\alan\AppData\Local\43pr3145p1ank2bl181n4tqg6c0d32fwtgu58srb33ja
[2011/06/30 10:15:00 | 000,011,196 | -HS- | M] () -- C:\ProgramData\43pr3145p1ank2bl181n4tqg6c0d32fwtgu58srb33ja
[2011/06/30 08:17:44 | 000,002,037 | ---- | M] () -- C:\Users\alan\Desktop\Google Chrome.lnk
[2011/06/30 08:17:44 | 000,001,999 | ---- | M] () -- C:\Users\alan\Application Data\Microsoft\Internet Explorer\Quick Launch\Google Chrome.lnk
[2011/06/29 16:13:04 | 000,377,000 | ---- | M] () -- C:\Windows\SysNative\FNTCACHE.DAT
[2011/06/21 19:03:49 | 000,010,752 | ---- | M] () -- C:\Users\alan\AppData\Local\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
[2011/06/21 14:16:43 | 000,001,922 | ---- | M] () -- C:\Users\Public\Desktop\Adobe Reader X.lnk
[2011/06/21 10:32:19 | 000,001,715 | ---- | M] () -- C:\Users\alan\Desktop\MySyncFolder.lnk
[2011/06/15 16:19:15 | 000,000,918 | ---- | M] () -- C:\Users\alan\Application Data\Microsoft\Internet Explorer\Quick Launch\DVD Catalyst 4.lnk
[2011/06/15 16:19:15 | 000,000,894 | ---- | M] () -- C:\Users\alan\Desktop\DVD Catalyst 4.lnk
[2011/06/14 11:31:48 | 001,342,881 | ---- | M] () -- C:\Users\alan\Platinum Sudoku v1.2.3.apk
[2011/06/10 15:06:45 | 000,000,940 | ---- | M] () -- C:\Users\alan\Desktop\Dropbox.lnk
[2011/06/08 14:20:37 | 000,000,394 | ---- | M] () -- C:\Users\alan\Desktop\android - Shortcut.lnk
[2011/06/08 14:18:21 | 000,525,544 | ---- | M] (Sun Microsystems, Inc.) -- C:\Windows\SysNative\deployJava1.dll
[2011/06/08 14:18:21 | 000,190,752 | ---- | M] (Sun Microsystems, Inc.) -- C:\Windows\SysNative\javaws.exe
[2011/06/08 14:18:21 | 000,171,808 | ---- | M] (Sun Microsystems, Inc.) -- C:\Windows\SysNative\javaw.exe
[2011/06/08 14:18:21 | 000,171,808 | ---- | M] (Sun Microsystems, Inc.) -- C:\Windows\SysNative\java.exe
[2011/06/08 14:10:02 | 000,472,808 | ---- | M] (Sun Microsystems, Inc.) -- C:\Windows\SysWow64\deployJava1.dll
[2011/06/08 14:10:02 | 000,157,472 | ---- | M] (Sun Microsystems, Inc.) -- C:\Windows\SysWow64\javaws.exe
[2011/06/08 14:10:02 | 000,145,184 | ---- | M] (Sun Microsystems, Inc.) -- C:\Windows\SysWow64\javaw.exe
[2011/06/08 14:10:02 | 000,145,184 | ---- | M] (Sun Microsystems, Inc.) -- C:\Windows\SysWow64\java.exe
[2011/06/02 15:52:48 | 000,000,000 | -H-- | M] () -- C:\Windows\wusa.lock
========== Files Created - No Company Name ==========
[2011/06/30 22:34:19 | 000,459,264 | ---- | C] () -- C:\Users\alan\Desktop\CKScanner.exe
[2011/06/30 11:24:45 | 000,000,112 | ---- | C] () -- C:\Windows\SysNative\drivers\kgpfr2.cfg
[2011/06/30 11:24:15 | 000,000,528 | ---- | C] () -- C:\Windows\SysNative\drivers\kgpcpy.cfg
[2011/06/30 10:12:46 | 000,011,196 | -HS- | C] () -- C:\Users\alan\AppData\Local\43pr3145p1ank2bl181n4tqg6c0d32fwtgu58srb33ja
[2011/06/30 10:12:46 | 000,011,196 | -HS- | C] () -- C:\ProgramData\43pr3145p1ank2bl181n4tqg6c0d32fwtgu58srb33ja
[2011/06/21 14:16:43 | 000,001,922 | ---- | C] () -- C:\Users\Public\Desktop\Adobe Reader X.lnk
[2011/06/21 14:16:43 | 000,001,804 | ---- | C] () -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Adobe Reader X.lnk
[2011/06/14 11:31:58 | 001,342,881 | ---- | C] () -- C:\Users\alan\Platinum Sudoku v1.2.3.apk
[2011/06/10 15:06:45 | 000,000,940 | ---- | C] () -- C:\Users\alan\Desktop\Dropbox.lnk
[2011/06/08 14:20:37 | 000,000,394 | ---- | C] () -- C:\Users\alan\Desktop\android - Shortcut.lnk
[2011/06/02 15:52:48 | 000,000,000 | -H-- | C] () -- C:\Windows\wusa.lock
[2011/05/05 14:53:15 | 000,111,932 | ---- | C] () -- C:\Windows\SysWow64\EPPICPrinterDB.dat
[2011/05/05 14:53:15 | 000,031,053 | ---- | C] () -- C:\Windows\SysWow64\EPPICPattern131.dat
[2011/05/05 14:53:15 | 000,027,417 | ---- | C] () -- C:\Windows\SysWow64\EPPICPattern121.dat
[2011/05/05 14:53:15 | 000,026,154 | ---- | C] () -- C:\Windows\SysWow64\EPPICPattern1.dat
[2011/05/05 14:53:15 | 000,024,903 | ---- | C] () -- C:\Windows\SysWow64\EPPICPattern3.dat
[2011/05/05 14:53:15 | 000,021,390 | ---- | C] () -- C:\Windows\SysWow64\EPPICPattern5.dat
[2011/05/05 14:53:15 | 000,020,148 | ---- | C] () -- C:\Windows\SysWow64\EPPICPattern2.dat
[2011/05/05 14:53:15 | 000,011,811 | ---- | C] () -- C:\Windows\SysWow64\EPPICPattern4.dat
[2011/05/05 14:53:15 | 000,004,943 | ---- | C] () -- C:\Windows\SysWow64\EPPICPattern6.dat
[2011/05/05 14:53:15 | 000,001,146 | ---- | C] () -- C:\Windows\SysWow64\EPPICPresetData_DU.dat
[2011/05/05 14:53:15 | 000,001,139 | ---- | C] () -- C:\Windows\SysWow64\EPPICPresetData_PT.dat
[2011/05/05 14:53:15 | 000,001,139 | ---- | C] () -- C:\Windows\SysWow64\EPPICPresetData_BP.dat
[2011/05/05 14:53:15 | 000,001,136 | ---- | C] () -- C:\Windows\SysWow64\EPPICPresetData_ES.dat
[2011/05/05 14:53:15 | 000,001,129 | ---- | C] () -- C:\Windows\SysWow64\EPPICPresetData_FR.dat
[2011/05/05 14:53:15 | 000,001,129 | ---- | C] () -- C:\Windows\SysWow64\EPPICPresetData_CF.dat
[2011/05/05 14:53:15 | 000,001,120 | ---- | C] () -- C:\Windows\SysWow64\EPPICPresetData_IT.dat
[2011/05/05 14:53:15 | 000,001,107 | ---- | C] () -- C:\Windows\SysWow64\EPPICPresetData_GE.dat
[2011/05/05 14:53:15 | 000,001,104 | ---- | C] () -- C:\Windows\SysWow64\EPPICPresetData_EN.dat
[2011/05/05 14:53:15 | 000,000,097 | ---- | C] () -- C:\Windows\SysWow64\PICSDK.ini
[2011/04/25 12:48:15 | 000,099,384 | ---- | C] () -- C:\Users\alan\AppData\Roaming\inst.exe
[2011/04/25 12:48:15 | 000,007,859 | ---- | C] () -- C:\Users\alan\AppData\Roaming\pcouffin.cat
[2011/04/25 12:48:15 | 000,001,167 | ---- | C] () -- C:\Users\alan\AppData\Roaming\pcouffin.inf
[2011/04/02 16:26:53 | 000,117,248 | ---- | C] () -- C:\Windows\SysWow64\EhStorAuthn.dll
[2011/04/02 16:26:33 | 000,107,612 | ---- | C] () -- C:\Windows\SysWow64\StructuredQuerySchema.bin
[2011/04/02 16:26:17 | 000,368,640 | ---- | C] () -- C:\Windows\SysWow64\msjetoledb40.dll
[2011/04/01 14:50:31 | 000,018,904 | ---- | C] () -- C:\Windows\SysWow64\StructuredQuerySchemaTrivial.bin
[2011/03/30 21:14:46 | 000,000,000 | ---- | C] () -- C:\Windows\ativpsrm.bin
[2011/03/30 19:49:15 | 000,000,732 | ---- | C] () -- C:\Users\alan\AppData\Local\d3d9caps64.dat
[2011/03/30 17:10:02 | 000,010,752 | ---- | C] () -- C:\Users\alan\AppData\Local\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
[2011/01/13 03:03:20 | 000,003,155 | ---- | C] () -- C:\Windows\SysWow64\atipblag.dat
[2009/02/26 07:50:32 | 000,000,176 | ---- | C] () -- C:\Windows\explorer.exe.config
[2008/01/21 03:50:05 | 000,060,124 | ---- | C] () -- C:\Windows\SysWow64\tcpmon.ini
[2006/11/02 16:37:05 | 000,067,584 | --S- | C] () -- C:\Windows\bootstat.dat
[2006/11/02 13:37:14 | 000,215,943 | ---- | C] () -- C:\Windows\SysWow64\dssec.dat
[2006/11/02 13:24:17 | 000,000,741 | ---- | C] () -- C:\Windows\SysWow64\NOISE.DAT
[2006/11/02 13:18:17 | 000,673,088 | ---- | C] () -- C:\Windows\SysWow64\mlang.dat
[2006/11/02 10:47:54 | 000,043,131 | ---- | C] () -- C:\Windows\mib.bin
========== LOP Check ==========
[2011/05/04 16:49:14 | 000,000,000 | ---D | M] -- C:\Users\alan\AppData\Roaming\ASUS
[2011/06/21 10:32:30 | 000,000,000 | ---D | M] -- C:\Users\alan\AppData\Roaming\ASUS WebStorage
[2011/05/05 15:44:40 | 000,000,000 | ---D | M] -- C:\Users\alan\AppData\Roaming\ASUS.AF361EFD06694D11175EA8BF6E21597A36AD9F1D.1
[2011/03/30 19:02:31 | 000,000,000 | ---D | M] -- C:\Users\alan\AppData\Roaming\CheckPoint
[2011/06/21 10:32:57 | 000,000,000 | ---D | M] -- C:\Users\alan\AppData\Roaming\Dropbox
[2011/06/15 16:19:36 | 000,000,000 | ---D | M] -- C:\Users\alan\AppData\Roaming\DVD Catalyst 4
[2011/05/04 16:43:18 | 000,000,000 | ---D | M] -- C:\Users\alan\AppData\Roaming\eCareme
[2011/06/07 16:27:52 | 000,000,000 | ---D | M] -- C:\Users\alan\AppData\Roaming\EPSON
[2011/05/11 14:37:09 | 000,000,000 | ---D | M] -- C:\Users\alan\AppData\Roaming\HandBrake
[2011/04/06 17:22:10 | 000,000,000 | ---D | M] -- C:\Users\alan\AppData\Roaming\HTC
[2011/04/06 17:19:17 | 000,000,000 | ---D | M] -- C:\Users\alan\AppData\Roaming\HTC.388BC06ACDAB6261375BCE37FBA2E023C0D7EE34.1
[2011/05/18 12:57:03 | 000,000,000 | ---D | M] -- C:\Users\alan\AppData\Roaming\Outlook
[2011/04/06 09:22:45 | 000,000,000 | ---D | M] -- C:\Users\alan\AppData\Roaming\TomTom
[2011/04/25 13:02:02 | 000,000,000 | ---D | M] -- C:\Users\alan\AppData\Roaming\Vso
[2011/06/30 12:42:56 | 000,032,522 | ---- | M] () -- C:\Windows\Tasks\SCHEDLGU.TXT
========== Purity Check ==========
< End of report >
  • ckfiles.txt
OTL extras
OTL Extras logfile created on: 30/06/2011 22:43:20 - Run 1
========== Extra Registry (SafeList) ==========
========== File Associations ==========
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\<extension>]
.url [@ = InternetShortcut] -- rundll32.exe ieframe.dll,OpenURL %l
.cpl [@ = cplfile] -- C:\Windows\SysWow64\control.exe (Microsoft Corporation)
[HKEY_CURRENT_USER\SOFTWARE\Classes\<extension>]
========== Shell Spawning ==========
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\<key>\shell\[command]\command]
batfile [open] -- "%1" %* File not found
cmdfile [open] -- "%1" %* File not found
comfile [open] -- "%1" %* File not found
exefile [open] -- "%1" %* File not found
helpfile [open] -- Reg Error: Key error.
inffile [install] -- %SystemRoot%\System32\InfDefaultInstall.exe "%1" (Microsoft Corporation)
InternetShortcut [open] -- rundll32.exe ieframe.dll,OpenURL %l File not found
InternetShortcut [print] -- rundll32.exe C:\Windows\system32\mshtml.dll,PrintHTML "%1" (Microsoft Corporation)
piffile [open] -- "%1" %* File not found
regfile [merge] -- Reg Error: Key error.
scrfile [config] -- "%1" File not found
scrfile [install] -- rundll32.exe desk.cpl,InstallScreenSaver %l File not found
scrfile [open] -- "%1" /S File not found
txtfile [edit] -- Reg Error: Key error.
Unknown [openas] -- %SystemRoot%\system32\rundll32.exe %SystemRoot%\system32\shell32.dll,OpenAs_RunDLL %1 File not found
Directory [cmd] -- cmd.exe /s /k pushd "%V" (Microsoft Corporation)
Directory [find] -- %SystemRoot%\Explorer.exe (Microsoft Corporation)
Folder [open] -- %SystemRoot%\Explorer.exe /separate,/idlist,%I,%L (Microsoft Corporation)
Folder [explore] -- %SystemRoot%\Explorer.exe /separate,/e,/idlist,%I,%L (Microsoft Corporation)
Drive [find] -- %SystemRoot%\Explorer.exe (Microsoft Corporation)
cplfile [cplopen] -- %SystemRoot%\System32\control.exe "%1",%* (Microsoft Corporation)
========== Security Center Settings ==========
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center]
"cval" = 1
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring]
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Svc]
"AntiVirusOverride" = 0
"AntiSpywareOverride" = 0
"FirewallOverride" = 0
"VistaSp1" = 9F 9E 16 8C DC 5B C8 01 [binary data]
"VistaSp2" = 78 58 60 97 0A F2 CB 01 [binary data]
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Svc\Vol]
"oobe_av" = 1
========== Firewall Settings ==========
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile]
"EnableFirewall" = 0
"DisableNotifications" = 0
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\PublicProfile]
========== Authorized Applications List ==========
========== Vista Active Open Ports Exception List ==========
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\FirewallRules]
"{8940D195-BAEF-4B45-8594-76BAACB0A204}" = lport=6004 | protocol=17 | dir=in | app=c:\program files (x86)\microsoft office\office12\outlook.exe |
========== Vista Active Application Exception List ==========
"{025CEFBF-57DF-42F6-9BF3-B19CADC79E7C}" = protocol=6 | dir=in | app=c:\program files (x86)\microsoft office\office12\groove.exe |
"{05FCEAE6-D7D6-4CD6-879B-17BB2257A7FE}" = protocol=6 | dir=in | app=c:\windows\syswow64\zonelabs\vsmon.exe |
"{1BC04B4F-5351-4AA6-A354-9478D4FD4029}" = protocol=6 | dir=in | app=c:\program files (x86)\microsoft office\office12\onenote.exe |
"{2410FE7E-8290-44DD-9D6E-F2D1E44A5A4B}" = protocol=17 | dir=in | app=c:\users\alan\appdata\roaming\dropbox\bin\dropbox.exe |
"{37D98BD4-0110-4216-9C45-37493DFFB478}" = protocol=17 | dir=in | app=c:\program files (x86)\microsoft office\office12\groove.exe |
"{85ABE9B1-3AB1-4FB0-B271-F3E01186759F}" = protocol=17 | dir=in | app=c:\program files (x86)\bonjour\mdnsresponder.exe |
"{8B57542C-A9A2-4E40-93D1-E03612AF7883}" = dir=in | app=c:\program files (x86)\itunes\itunes.exe |
"{93DC2FB8-B645-4570-8ACF-43759DE56E04}" = protocol=6 | dir=in | app=c:\users\alan\appdata\roaming\dropbox\bin\dropbox.exe |
"{DACC713D-F83A-41AA-8C55-3D6B2D0005BB}" = protocol=17 | dir=in | app=c:\program files (x86)\microsoft office\office12\onenote.exe |
"{E6D124FC-A9D4-4E36-8F83-A50A6CB4639C}" = protocol=17 | dir=in | app=c:\windows\syswow64\zonelabs\vsmon.exe |
"{FEA76A20-E360-4267-9ECA-116BFC003F6D}" = protocol=6 | dir=in | app=c:\program files (x86)\bonjour\mdnsresponder.exe |
"TCP Query User{764C68C8-01FB-4C23-8D7D-6B42A2DCDEDA}C:\program files (x86)\asus\asus sync\asusupctloader.exe" = protocol=6 | dir=in | app=c:\program files (x86)\asus\asus sync\asusupctloader.exe |
"UDP Query User{2BB0970F-3F2A-40FF-9034-93D9ACEE5014}C:\program files (x86)\asus\asus sync\asusupctloader.exe" = protocol=17 | dir=in | app=c:\program files (x86)\asus\asus sync\asusupctloader.exe |
========== HKEY_LOCAL_MACHINE Uninstall List ==========
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall]
"{071c9b48-7c32-4621-a0ac-3f809523288f}" = Microsoft Visual C++ 2005 Redistributable (x64)
"{26A24AE4-039D-4CA4-87B4-2F86416026FF}" = Java(TM) 6 Update 26 (64-bit)
"{43A79282-8566-671D-A9CC-A82F54497F0A}" = ATI Catalyst Install Manager
"{6E8E85E8-CE4B-4FF5-91F7-04999C9FAE6A}" = Microsoft Visual C++ 2005 Redistributable (x64)
"{8F473675-D702-45F9-8EBC-342B40C17BF5}" = Apple Mobile Device Support
"{90120000-002A-0000-1000-0000000FF1CE}" = Microsoft Office Office 64-bit Components 2007
"{90120000-002A-0409-1000-0000000FF1CE}" = Microsoft Office Shared 64-bit MUI (English) 2007
"{90120000-0116-0409-1000-0000000FF1CE}" = Microsoft Office Shared 64-bit Setup Metadata MUI (English) 2007
"{9545E9DB-6F4C-4404-BF25-E221BE8B44C5}" = iTunes
"{9D2795DC-59E3-4E75-B59D-D23A6A18CE9C}" = ASUS Android USB Drivers
"{CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9}" = Microsoft .NET Framework 3.5 SP1
"{DA5E371C-6333-3D8A-93A4-6FD5B20BCC6E}" = Microsoft Visual C++ 2010 x64 Redistributable - 10.0.30319
"{E4F5E48E-7155-4CF9-88CD-7F377EC9AC54}" = Bonjour
"{F5B09CFD-F0B2-36AF-8DF4-1DF6B63FC7B4}" = Microsoft .NET Framework 4 Client Profile
"{FBBF8FCB-046D-7688-FB4A-53DD34BB7648}" = ccc-utility64
"EPSON Printer and Utilities" = EPSON Printer Software
"Microsoft .NET Framework 3.5 SP1" = Microsoft .NET Framework 3.5 SP1
"Microsoft .NET Framework 4 Client Profile" = Microsoft .NET Framework 4 Client Profile
"WinRAR archiver" = WinRAR 4.00 (64-bit)
"ZoneAlarm Toolbar" = ZoneAlarm Toolbar
"{02E89EFC-7B07-4D5A-AA03-9EC0902914EE}" = VC 9.0 Runtime
"{02EBDBB9-4600-41D3-B566-40CB861511D2}" = World of Warcraft FREE Trial
"{15B8C1EF-CA1B-1050-FDF6-92BFF1AB7C42}" = Catalyst Control Center Graphics Previews Common
"{196467F1-C11F-4F76-858B-5812ADC83B94}" = MSXML 4.0 SP3 Parser
"{196BB40D-1578-3D01-B289-BEFC77A11A1E}" = Microsoft Visual C++ 2010 x86 Redistributable - 10.0.30319
"{1C9FE53E-5922-9982-26C2-29C75F34D5DC}" = Catalyst Control Center InstallProxy
"{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}" = Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148
"{26A24AE4-039D-4CA4-87B4-2F83216026FF}" = Java(TM) 6 Update 26
"{2AE0B374-90DA-416C-9AF9-436585FD34DD}" = ASUS Sync
"{2DC94AFD-A6E2-4AB4-9132-4A3F8E07B386}" = Apple Application Support
"{31A559C1-9E4D-423B-9DD3-34A6C5398752}" = HTC BMP USB Driver
"{4A03706F-666A-4037-7777-5F2748764D10}" = Java Auto Updater
"{5645FB61-898F-4F59-AF80-52FEF3D63A64}" = HTC Sync
"{57752979-A1C9-4C02-856B-FBB27AC4E02C}" = QuickTime
"{5A7248FE-53C6-6838-C092-6E5AE0C01169}" = Catalyst Control Center Graphics Previews Vista
"{5CDE2F17-B82C-F25A-EE97-A0F84B1B5B96}" = Catalyst Control Center HydraVision Full
"{6D6664A9-3342-4948-9B7E-034EFE366F0F}" = HTC Driver Installer
"{837b34e3-7c30-493c-8f6a-2b0f04e2912c}" = Microsoft Visual C++ 2005 Redistributable
"{83C06969-09DE-5DEE-EC30-254168715100}" = Catalyst Control Center Graphics Full Existing
"{852BD922-520E-209D-0AEC-2A8886693B36}" = Catalyst Control Center Core Implementation
"{8A39CAD8-D852-E57C-C9EC-66B24A81EC8B}" = CCC Help English
"{8F3C31C5-9C3A-4AA8-8EFA-71290A7AD533}" = TomTom HOME Visual Studio Merge Modules
"{90120000-0015-0409-0000-0000000FF1CE}" = Microsoft Office Access MUI (English) 2007
"{90120000-0016-0409-0000-0000000FF1CE}" = Microsoft Office Excel MUI (English) 2007
"{90120000-0018-0409-0000-0000000FF1CE}" = Microsoft Office PowerPoint MUI (English) 2007
"{90120000-0019-0409-0000-0000000FF1CE}" = Microsoft Office Publisher MUI (English) 2007
"{90120000-001A-0409-0000-0000000FF1CE}" = Microsoft Office Outlook MUI (English) 2007
"{90120000-001B-0409-0000-0000000FF1CE}" = Microsoft Office Word MUI (English) 2007
"{90120000-001F-0409-0000-0000000FF1CE}" = Microsoft Office Proof (English) 2007
"{90120000-001F-040C-0000-0000000FF1CE}" = Microsoft Office Proof (French) 2007
"{90120000-001F-0C0A-0000-0000000FF1CE}" = Microsoft Office Proof (Spanish) 2007
"{90120000-002C-0409-0000-0000000FF1CE}" = Microsoft Office Proofing (English) 2007
"{90120000-0030-0000-0000-0000000FF1CE}" = Microsoft Office Enterprise 2007
"{90120000-0044-0409-0000-0000000FF1CE}" = Microsoft Office InfoPath MUI (English) 2007
"{90120000-006E-0409-0000-0000000FF1CE}" = Microsoft Office Shared MUI (English) 2007
"{90120000-00A1-0409-0000-0000000FF1CE}" = Microsoft Office OneNote MUI (English) 2007
"{90120000-00BA-0409-0000-0000000FF1CE}" = Microsoft Office Groove MUI (English) 2007
"{90120000-0114-0409-0000-0000000FF1CE}" = Microsoft Office Groove Setup Metadata MUI (English) 2007
"{90120000-0115-0409-0000-0000000FF1CE}" = Microsoft Office Shared Setup Metadata MUI (English) 2007
"{90120000-0117-0409-0000-0000000FF1CE}" = Microsoft Office Access Setup Metadata MUI (English) 2007
"{94A1911F-CD2F-4B9C-B171-2B43DCD213AA}" = Splashtop Remote
"{94FA9FA6-5294-494D-A8F1-1E654CBB5736}" = Epson Easy Photo Print 2
"{9749B943-7D5D-09E3-16EE-6F8BEC7A474F}" = Skins
"{A1F9909D-B829-41E4-EDDA-6CD5A69AB706}" = Catalyst Control Center Graphics Light
"{A49C7C20-F82D-0185-47B4-8A8A38AEBD3E}" = ccc-core-static
"{AC76BA86-7AD7-1033-7B44-AA1000000001}" = Adobe Reader X (10.1.0)
"{AFF7E080-1974-45BF-9310-10DE1A1F5ED0}" = Adobe AIR
"{B2AE1185-18AA-9DE2-6E09-29A91D5A8F17}" = Catalyst Control Center Graphics Full New
"{B2D55EB8-32C5-4B43-9006-9E97DECBA178}" = Epson Easy Photo Print Plug-in for PMB(Picture Motion Browser)
"{C41300B9-185D-475E-BFEC-39EF732F19B1}" = Apple Software Update
"{CE78F40B-97C8-4D23-A895-92FEDD54DCCD}" = Plex Media Server
"{D3B1C799-CB73-42DE-BA0F-2344793A095C}" = Catalyst Control Center - Branding
"Adobe AIR" = Adobe AIR
"Adobe Flash Player ActiveX" = Adobe Flash Player 10 ActiveX
"ASUS WebStorage" = ASUS WebStorage
"DVD Catalyst" = DVD Catalyst 4.0.3 Beta 6
"DVD Shrink_is1" = DVD Shrink 3.2
"DVDFab 8 Qt_is1" = DVDFab 8.0.9.0 (09/05/2011) Qt
"DVDFab Decrypter_is1" = DVDFab Decrypter 3.0.4.0
"ENTERPRISE" = Microsoft Office Enterprise 2007
"EPSON Scanner" = EPSON Scan
"HandBrake" = HandBrake 0.9.5
"InstallShield_{94A1911F-CD2F-4B9C-B171-2B43DCD213AA}" = Splashtop Remote
"Magic DVD Copier_is1" = Magic DVD Copier Version 5.0.1
"Malwarebytes' Anti-Malware_is1" = Malwarebytes' Anti-Malware version 1.51.0.1200
"TomTom HOME" = TomTom HOME 2.8.1.2218
"VLC media player" = VideoLAN VLC media player 0.8.4a
"ZoneAlarm Anti-virus" = ZoneAlarm Anti-virus
========== HKEY_CURRENT_USER Uninstall List ==========
[HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall]
"Dropbox" = Dropbox
"Google Chrome" = Google Chrome
========== Last 10 Event Log Errors ==========
[ Application Events ]
Error - 30/06/2011 03:18:50 | Computer Name = alan-PC | Source = Bonjour Service | ID = 100
Description = Task Scheduling Error: m->NextScheduledSPRetry 3994
Error - 30/06/2011 06:08:43 | Computer Name = alan-PC | Source = WinMgmt | ID = 10
Description =
Error - 30/06/2011 06:25:00 | Computer Name = alan-PC | Source = WinMgmt | ID = 10
Description =
Error - 30/06/2011 06:27:36 | Computer Name = alan-PC | Source = VSS | ID = 12301
Description =
Error - 30/06/2011 06:27:36 | Computer Name = alan-PC | Source = System Restore | ID = 8193
Description =
Error - 30/06/2011 07:18:12 | Computer Name = alan-PC | Source = WinMgmt | ID = 10
Description =
Error - 30/06/2011 07:39:06 | Computer Name = alan-PC | Source = WinMgmt | ID = 10
Description =
Error - 30/06/2011 17:33:16 | Computer Name = alan-PC | Source = WinMgmt | ID = 10
Description =
Error - 30/06/2011 17:36:37 | Computer Name = alan-PC | Source = Application Hang | ID = 1002
Description = The program CKScanner.exe version 1.9.1.1 stopped interacting with
Windows and was closed. To see if more information about the problem is available,
check the problem history in the Problem Reports and Solutions control panel. Process
ID: 1150 Start Time: 01cc376d8cfc05df Termination Time: 70
Error - 30/06/2011 17:37:25 | Computer Name = alan-PC | Source = Application Hang | ID = 1002
ID: cec Start Time: 01cc376dd258fb1f Termination Time: 0
[ System Events ]
Error - 05/05/2011 11:02:36 | Computer Name = alan-PC | Source = cdrom | ID = 262151
Description = The device, \Device\CdRom0, has a bad block.
Error - 05/05/2011 11:02:44 | Computer Name = alan-PC | Source = cdrom | ID = 262151
Error - 05/05/2011 11:02:51 | Computer Name = alan-PC | Source = cdrom | ID = 262151
Error - 05/05/2011 13:06:00 | Computer Name = alan-PC | Source = DCOM | ID = 10005
Description =
Error - 05/05/2011 13:06:00 | Computer Name = alan-PC | Source = Service Control Manager | ID = 7009
Description =
Error - 05/05/2011 13:06:00 | Computer Name = alan-PC | Source = Service Control Manager | ID = 7000
Description =
Description =
Description =
Error - 06/05/2011 08:45:13 | Computer Name = alan-PC | Source = Dhcp | ID = 1002
Description = The IP address lease 192.168.0.5 for the Network Card with network
address 001FD0DC50A4 has been denied by the DHCP server 192.168.0.1 (The DHCP Server
sent a DHCPNACK message).
Error - 07/05/2011 13:38:28 | Computer Name = alan-PC | Source = EventLog | ID = 6008
Description = The previous system shutdown at 13:54:49 on 06/05/2011 was unexpected.
< End of report >
malware log
Malwarebytes' Anti-Malware 1.51.0.1200
Malwarebytes : Free anti-malware, anti-virus and spyware removal download
Database version: 6989
Windows 6.0.6002 Service Pack 2
Internet Explorer 7.0.6002.18005
30/06/2011 23:01:40
mbam-log-2011-06-30 (23-01-40).txt
Scan type: Quick scan
Objects scanned: 160780
Time elapsed: 1 minute(s), 22 second(s)
Memory Processes Infected: 0
Memory Modules Infected: 0
Registry Keys Infected: 0
Registry Values Infected: 0
Registry Data Items Infected: 0
Folders Infected: 0
Files Infected: 0
(No malicious items detected)
Folders Infected:
Files Infected:
Do the full scan, not the quick scan with malwarebytes.
Can you upload both of the following files to VirusTotal
They are hidden so you will need to show hidden files and protected system files http://www.vistax64.com/tutorials/86163-hidden-files-folders.html
Send me the links to both of the reports :)
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
I don't quite understand what's wrong here. What's executed permission? Did you upload the files to Virus Total?
I'm going to sleep now, but I'll continue helping you in the morning :)
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    Samsung EVO 128GB SSD
    Seagate Barracuda 2TB 7200rpm
    NZXT Phantom 410
malwarebytes log, even though i have unchecked hidden folders the 2 files you requested can not be found in those location , my anti virus ran through night and found and deleted 2 trojans, however 2 things i have noticed, this morning tried to run a virus scan and it only took 1 minute instead of 20 mins and my i con that shows data transfer when connected to the net is showing nothing even though data is coming in
malwarebytes' Anti-Malware 1.51.0.1200
01/07/2011 07:20:01
mbam-log-2011-07-01 (07-20-01).txt
Scan type: Full scan (C:\|D:\|)
Objects scanned: 739120
Time elapsed: 2 hour(s), 44 minute(s), 54 second(s)
Folders Infected: 0
Files Infected: 1
Folders Infected:
Files Infected:
c:\Windows.old\Users\Alan\AppData\Local\thinstall\Cache\Stubs\73b244baf8731a093e063c7d0ed57c0e5f2b07\verclsid.exe (Trojan.Backdoor) -> Quarantined and deleted successfully.
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
No worries, it's what we're here for :)
Thank you for the rep!
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
The scan completed while.I was away from the pc and when I got back to it the window has closed,so didn't get to see final result I know at about 99% it had found 4 infected files,since then it seems to be back to normal running ok .should I run the any of the other programs again and post results up
One last OTL log please :) Just to make sure its all gone
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
OTL logfile created on: 04/07/2011 13:04:41 - Run 2
OTL by OldTimer - Version 3.2.25.0 Folder = C:\Users\alan\Desktop
64bit-Windows Vista Home Premium Edition Service Pack 2 (Version = 6.0.6002) - Type = NTWorkstation
Internet Explorer (Version = 7.0.6002.18005)
Locale: 00000809 | Country: United Kingdom | Language: ENG | Date Format: dd/MM/yyyy
6.00 Gb Total Physical Memory | 4.37 Gb Available Physical Memory | 72.87% Memory free
12.21 Gb Paging File | 10.41 Gb Available in Paging File | 85.27% Paging File free
Paging file location(s): ?:\pagefile.sys [binary data]
%SystemDrive% = C: | %SystemRoot% = C:\Windows | %ProgramFiles% = C:\Program Files (x86)
Drive C: | 596.17 Gb Total Space | 152.44 Gb Free Space | 25.57% Space Free | Partition Type: NTFS
Drive D: | 372.61 Gb Total Space | 48.54 Gb Free Space | 13.03% Space Free | Partition Type: NTFS
Drive F: | 3.72 Gb Total Space | 0.08 Gb Free Space | 2.02% Space Free | Partition Type: FAT32
Computer Name: ALAN-PC | User Name: alan | Logged in as Administrator.
Boot Mode: Normal | Scan Mode: Current user | Include 64bit Scans
Company Name Whitelist: Off | Skip Microsoft Files: Off | No Company Name Whitelist: On | File Age = 60 Days
========== Processes (SafeList) ==========
PRC - C:\Users\alan\Desktop\OTL.exe (OldTimer Tools)
PRC - C:\Program Files (x86)\Splashtop\Splashtop Remote\Server\SRService.exe (Splashtop Inc.)
PRC - C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe (Adobe Systems Incorporated)
PRC - C:\Program Files (x86)\TomTom HOME 2\TomTomHOMEService.exe (TomTom)
PRC - C:\Program Files (x86)\Splashtop\Splashtop Software Updater\SSUService.exe (Splashtop Inc.)
PRC - C:\Program Files (x86)\HTC\Internet Pass-Through\PassThruSvr.exe ()
PRC - C:\Windows\SysWOW64\ZoneLabs\vsmon.exe (Check Point Software Technologies LTD)
PRC - C:\Program Files (x86)\Zone Labs\ZoneAlarm\zlclient.exe (Check Point Software Technologies LTD)
========== Modules (SafeList) ==========
MOD - C:\Users\alan\Desktop\OTL.exe (OldTimer Tools)
MOD - C:\Windows\winsxs\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_d08d7da0442a985d\msvcr80.dll (Microsoft Corporation)
MOD - C:\Windows\winsxs\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_d08d7da0442a985d\msvcp80.dll (Microsoft Corporation)
MOD - C:\Windows\winsxs\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.6002.18305_none_5cb72f2a088b0ed3\comctl32.dll (Microsoft Corporation)
MOD - C:\Program Files\CheckPoint\ZAForceField\WOW64\Plugins\ISWSHEX.dll (Check Point Software Technologies)
MOD - C:\Windows\SysWOW64\wintrust.dll (Microsoft Corporation)
MOD - C:\Windows\SysWOW64\imagehlp.dll (Microsoft Corporation)
========== Win32 Services (SafeList) ==========
SRV:64bit: - (AMD External Events Utility) -- C:\Windows\SysNative\atiesrxx.exe (AMD)
SRV:64bit: - (IswSvc) -- C:\Program Files\CheckPoint\ZAForceField\IswSvc.exe (Check Point Software Technologies)
SRV:64bit: - (WinDefend) -- C:\Program Files\Windows Defender\MpSvc.dll (Microsoft Corporation)
SRV - (SplashtopRemoteService) -- C:\Program Files (x86)\Splashtop\Splashtop Remote\Server\SRService.exe (Splashtop Inc.)
SRV - (AdobeARMservice) -- C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe (Adobe Systems Incorporated)
SRV - (TomTomHOMEService) -- C:\Program Files (x86)\TomTom HOME 2\TomTomHOMEService.exe (TomTom)
SRV - (SSUService) -- C:\Program Files (x86)\Splashtop\Splashtop Software Updater\SSUService.exe (Splashtop Inc.)
SRV - (PassThru Service) -- C:\Program Files (x86)\HTC\Internet Pass-Through\PassThruSvr.exe ()
SRV - (vsmon) -- C:\Windows\SysWOW64\ZoneLabs\vsmon.exe (Check Point Software Technologies LTD)
SRV - (clr_optimization_v4.0.30319_32) -- C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe (Microsoft Corporation)
SRV - (clr_optimization_v2.0.50727_32) -- C:\Windows\Microsoft.NET\Framework\v2.0.50727\mscorsvw.exe (Microsoft Corporation)
========== Driver Services (SafeList) ==========
DRV:64bit: - (atikmdag) -- C:\Windows\SysNative\DRIVERS\atikmdag.sys (ATI Technologies Inc.)
DRV:64bit: - (amdkmdag) -- C:\Windows\SysNative\DRIVERS\atikmdag.sys (ATI Technologies Inc.)
DRV:64bit: - (amdkmdap) -- C:\Windows\SysNative\DRIVERS\atikmpag.sys (Advanced Micro Devices, Inc.)
DRV:64bit: - (RTL8169) -- C:\Windows\SysNative\DRIVERS\Rtlh64.sys (Realtek )
DRV:64bit: - (ISWKL) -- C:\Program Files\CheckPoint\ZAForceField\ISWKL.sys (Check Point Software Technologies)
DRV:64bit: - (htcnprot) -- C:\Windows\SysNative\DRIVERS\htcnprot.sys (Windows (R) Win 7 DDK provider)
DRV:64bit: - (Vsdatant) -- C:\Windows\SysNative\DRIVERS\vsdatant.sys (Check Point Software Technologies LTD)
DRV:64bit: - (KLIF) -- C:\Windows\SysNative\DRIVERS\klif.sys (Kaspersky Lab)
DRV:64bit: - (kl1) -- C:\Windows\SysNative\DRIVERS\kl1.sys (Kaspersky Lab)
DRV:64bit: - (WpdUsb) -- C:\Windows\SysNative\DRIVERS\wpdusb.sys (Microsoft Corporation)
DRV:64bit: - (HTCAND64) -- C:\Windows\SysNative\Drivers\ANDROIDUSB.sys (HTC, Corporation)
DRV:64bit: - (GEARAspiWDM) -- C:\Windows\SysNative\DRIVERS\GEARAspiWDM.sys (GEAR Software Inc.)
DRV:64bit: - (usb_rndisx) -- C:\Windows\SysNative\DRIVERS\usb8023x.sys (Microsoft Corporation)
DRV:64bit: - (Ntfs) -- C:\Windows\SysNative\Wbem\ntfs.mof ()
========== Standard Registry (All) ==========
========== Internet Explorer ==========
IE:64bit: - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Page_URL = MSN.com
IE:64bit: - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Search_URL = Bing
IE:64bit: - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Secondary_Page_URL = [binary data]
IE:64bit: - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Extensions Off Page = about:NoAdd-ons
IE:64bit: - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Local Page = %SystemRoot%\system32\blank.htm
IE:64bit: - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Search Page = Bing
IE:64bit: - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Security Risk Page = about:SecurityRisk
IE:64bit: - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = MSN.com
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Page_URL = MSN.com
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Search_URL = Bing
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Secondary_Page_URL = [binary data]
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Extensions Off Page = about:NoAdd-ons
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Local Page = %SystemRoot%\system32\blank.htm
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Search Page = Bing
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Security Risk Page = about:SecurityRisk
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = MSN.com
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Local Page = C:\Windows\system32\blank.htm
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Search Page = Bing
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = MSN.com
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,StartPageCache = 1
IE - HKCU\..\URLSearchHook: {CFBFAE00-17A6-11D0-99CB-00C04FD64497} - C:\Windows\SysWOW64\ieframe.dll (Microsoft Corporation)
IE - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
IE - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyOverride" = *.local
========== FireFox ==========
FF - prefs.js..extensions.enabledItems: [email protected]:1.7.1
FF - prefs.js..extensions.enabledItems: [email protected]:1.0.2
FF - HKLM\software\mozilla\Firefox\Extensions\\{FFB96CC1-7EB3-449D-B827-DB661701C6BB}: C:\Program Files\CheckPoint\ZAForceField\WOW64\TrustChecker [2011/03/30 19:02:10 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Firefox\Extensions\\{20a82645-c095-46ed-80e3-08825760534b}: c:\Windows\Microsoft.NET\Framework\v3.5\Windows Presentation Foundation\DotNetAssistantExtension\ [2011/04/02 16:40:34 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Firefox\Extensions\\[email protected]: C:\Program Files (x86)\Splashtop\Splashtop Remote\Server\plugin\FFExtensions [2011/05/04 16:49:52 | 000,000,000 | ---D | M]
[2011/04/06 09:22:48 | 000,000,000 | ---D | M] (No name found) -- C:\Users\alan\AppData\Roaming\Mozilla\Extensions
[2011/04/06 09:22:48 | 000,000,000 | ---D | M] (No name found) -- C:\Users\alan\AppData\Roaming\Mozilla\Extensions\[email protected]
[2011/07/01 11:10:38 | 000,000,000 | ---D | M] (Map status indicator) -- C:\PROGRAM FILES (X86)\TOMTOM HOME 2\XUL\EXTENSIONS\[email protected]
O1 HOSTS File: ([2006/09/18 22:37:24 | 000,000,761 | ---- | M]) - C:\Windows\SysNative\drivers\etc\Hosts
O1 - Hosts: 127.0.0.1 localhost
O1 - Hosts: ::1 localhost
O2:64bit: - BHO: (ZoneAlarm Toolbar Registrar) - {8A4A36C2-0535-4D2C-BD3D-496CB7EED6E3} - C:\Program Files\CheckPoint\ZAForceField\TrustChecker\bin\TrustCheckerIEPlugin.dll (Check Point Software Technologies)
O2:64bit: - BHO: (Java(tm) Plug-In 2 SSV Helper) - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre6\bin\jp2ssv.dll (Sun Microsystems, Inc.)
O2 - BHO: (Adobe PDF Link Helper) - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll (Adobe Systems Incorporated)
O2 - BHO: (Groove GFS Browser Helper) - {72853161-30C5-4D22-B7F9-0BBC1D38A37E} - C:\Program Files (x86)\Microsoft Office\Office12\GrooveShellExtensions.dll (Microsoft Corporation)
O2 - BHO: (ZoneAlarm Toolbar Registrar) - {8A4A36C2-0535-4D2C-BD3D-496CB7EED6E3} - C:\Program Files\CheckPoint\ZAForceField\WOW64\TrustChecker\bin\TrustCheckerIEPlugin.dll (Check Point Software Technologies)
O2 - BHO: (Java(tm) Plug-In 2 SSV Helper) - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files (x86)\Java\jre6\bin\jp2ssv.dll (Sun Microsystems, Inc.)
O3:64bit: - HKLM\..\Toolbar: (ZoneAlarm Toolbar) - {EE2AC4E5-B0B0-4EC6-88A9-BCA1A32AB107} - C:\Program Files\CheckPoint\ZAForceField\TrustChecker\bin\TrustCheckerIEPlugin.dll (Check Point Software Technologies)
O3 - HKLM\..\Toolbar: (ZoneAlarm Toolbar) - {EE2AC4E5-B0B0-4EC6-88A9-BCA1A32AB107} - C:\Program Files\CheckPoint\ZAForceField\WOW64\TrustChecker\bin\TrustCheckerIEPlugin.dll (Check Point Software Technologies)
O3:64bit: - HKCU\..\Toolbar\WebBrowser: (ZoneAlarm Toolbar) - {EE2AC4E5-B0B0-4EC6-88A9-BCA1A32AB107} - C:\Program Files\CheckPoint\ZAForceField\TrustChecker\bin\TrustCheckerIEPlugin.dll (Check Point Software Technologies)
O3 - HKCU\..\Toolbar\WebBrowser: (ZoneAlarm Toolbar) - {EE2AC4E5-B0B0-4EC6-88A9-BCA1A32AB107} - C:\Program Files\CheckPoint\ZAForceField\WOW64\TrustChecker\bin\TrustCheckerIEPlugin.dll (Check Point Software Technologies)
O4:64bit: - HKLM..\Run: [ISW] C:\Program Files\CheckPoint\ZAForceField\ForceField.exe (Check Point Software Technologies)
O4:64bit: - HKLM..\Run: [Windows Defender] C:\Program Files\Windows Defender\MSASCui.exe (Microsoft Corporation)
O4 - HKLM..\Run: [Adobe ARM] C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe (Adobe Systems Incorporated)
O4 - HKLM..\Run: [StartCCC] C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static\CLIStart.exe (Advanced Micro Devices, Inc.)
O4 - HKLM..\Run: [SunJavaUpdateSched] C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe (Sun Microsystems, Inc.)
O4 - HKLM..\Run: [ZoneAlarm Client] C:\Program Files (x86)\Zone Labs\ZoneAlarm\zlclient.exe (Check Point Software Technologies LTD)
O4 - HKCU..\Run: [ctfmon.exe] C:\Windows\SysWOW64\ctfmon.exe (Microsoft Corporation)
O4 - HKCU..\Run: [Google Update] C:\Users\alan\AppData\Local\Google\Update\GoogleUpdate.exe (Google Inc.)
O4 - HKCU..\Run: [TomTomHOME.exe] C:\Program Files (x86)\TomTom HOME 2\TomTomHOMERunner.exe (TomTom)
O6 - HKLM\Software\Policies\Microsoft\Internet Explorer\control panel present
O6 - HKLM\Software\Policies\Microsoft\Internet Explorer\restrictions present
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoActiveDesktop = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoActiveDesktopChanges = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: ForceActiveDesktopOn = 0
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: BindDirectlyToPropertySetStorage = 0
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: ConsentPromptBehaviorAdmin = 2
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: ConsentPromptBehaviorUser = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: EnableInstallerDetection = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: EnableLUA = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: EnableSecureUIAPaths = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: EnableVirtualization = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: PromptOnSecureDesktop = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: ValidateAdminCodeSignatures = 0
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: dontdisplaylastusername = 0
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: legalnoticecaption =
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: legalnoticetext =
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: scforceoption = 0
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: shutdownwithoutlogon = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: undockwithoutlogon = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: FilterAdministratorToken = 0
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: EnableUIADesktopToggle = 0
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System\UIPI\Clipboard\ExceptionFormats: CF_TEXT = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System\UIPI\Clipboard\ExceptionFormats: CF_BITMAP = 2
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System\UIPI\Clipboard\ExceptionFormats: CF_OEMTEXT = 7
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System\UIPI\Clipboard\ExceptionFormats: CF_DIB = 8
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System\UIPI\Clipboard\ExceptionFormats: CF_PALETTE = 9
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System\UIPI\Clipboard\ExceptionFormats: CF_UNICODETEXT = 13
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System\UIPI\Clipboard\ExceptionFormats: CF_DIBV5 = 17
O7 - HKCU\Software\Policies\Microsoft\Internet Explorer\control panel present
O7 - HKCU\Software\Policies\Microsoft\Internet Explorer\restrictions present
O8:64bit: - Extra context menu item: E&xport to Microsoft Excel - C:\Program Files (x86)\Microsoft Office\Office12\EXCEL.EXE (Microsoft Corporation)
O8 - Extra context menu item: E&xport to Microsoft Excel - C:\Program Files (x86)\Microsoft Office\Office12\EXCEL.EXE (Microsoft Corporation)
O9 - Extra Button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files (x86)\Microsoft Office\Office12\ONBttnIE.dll (Microsoft Corporation)
O9 - Extra 'Tools' menuitem : S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files (x86)\Microsoft Office\Office12\ONBttnIE.dll (Microsoft Corporation)
O9 - Extra Button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\Program Files (x86)\Microsoft Office\Office12\REFIEBAR.DLL (Microsoft Corporation)
O10:64bit: - NameSpace_Catalog5\Catalog_Entries\000000000001 [] - C:\Windows\SysNative\NLAapi.dll (Microsoft Corporation)
O10:64bit: - NameSpace_Catalog5\Catalog_Entries\000000000002 [] - C:\Windows\SysNative\napinsp.dll (Microsoft Corporation)
O10:64bit: - NameSpace_Catalog5\Catalog_Entries\000000000003 [] - C:\Windows\SysNative\pnrpnsp.dll (Microsoft Corporation)
O10:64bit: - NameSpace_Catalog5\Catalog_Entries\000000000004 [] - C:\Windows\SysNative\pnrpnsp.dll (Microsoft Corporation)
O10:64bit: - NameSpace_Catalog5\Catalog_Entries\000000000005 [] - C:\Windows\SysNative\mswsock.dll (Microsoft Corporation)
O10:64bit: - NameSpace_Catalog5\Catalog_Entries\000000000006 [] - C:\Windows\SysNative\winrnr.dll (Microsoft Corporation)
O10:64bit: - NameSpace_Catalog5\Catalog_Entries\000000000007 [] - C:\Program Files (x86)\Bonjour\mdnsNSP.dll (Apple Inc.)
O10:64bit: - Protocol_Catalog9\Catalog_Entries\000000000001 - C:\Windows\SysNative\mswsock.dll (Microsoft Corporation)
O10:64bit: - Protocol_Catalog9\Catalog_Entries\000000000002 - C:\Windows\SysNative\mswsock.dll (Microsoft Corporation)
O10:64bit: - Protocol_Catalog9\Catalog_Entries\000000000003 - C:\Windows\SysNative\mswsock.dll (Microsoft Corporation)
O10:64bit: - Protocol_Catalog9\Catalog_Entries\000000000004 - C:\Windows\SysNative\mswsock.dll (Microsoft Corporation)
O10:64bit: - Protocol_Catalog9\Catalog_Entries\000000000005 - C:\Windows\SysNative\mswsock.dll (Microsoft Corporation)
O10:64bit: - Protocol_Catalog9\Catalog_Entries\000000000006 - C:\Windows\SysNative\mswsock.dll (Microsoft Corporation)
O10:64bit: - Protocol_Catalog9\Catalog_Entries\000000000007 - C:\Windows\SysNative\mswsock.dll (Microsoft Corporation)
O10:64bit: - Protocol_Catalog9\Catalog_Entries\000000000008 - C:\Windows\SysNative\mswsock.dll (Microsoft Corporation)
O10:64bit: - Protocol_Catalog9\Catalog_Entries\000000000009 - C:\Windows\SysNative\mswsock.dll (Microsoft Corporation)
O10:64bit: - Protocol_Catalog9\Catalog_Entries\000000000010 - C:\Windows\SysNative\mswsock.dll (Microsoft Corporation)
O10 - NameSpace_Catalog5\Catalog_Entries\000000000001 [] - C:\Windows\SysWOW64\nlaapi.dll (Microsoft Corporation)
O10 - NameSpace_Catalog5\Catalog_Entries\000000000002 [] - C:\Windows\SysWOW64\NapiNSP.dll (Microsoft Corporation)
O10 - NameSpace_Catalog5\Catalog_Entries\000000000003 [] - C:\Windows\SysWOW64\pnrpnsp.dll (Microsoft Corporation)
O10 - NameSpace_Catalog5\Catalog_Entries\000000000004 [] - C:\Windows\SysWOW64\pnrpnsp.dll (Microsoft Corporation)
O10 - NameSpace_Catalog5\Catalog_Entries\000000000005 [] - C:\Windows\SysWOW64\mswsock.dll (Microsoft Corporation)
O10 - NameSpace_Catalog5\Catalog_Entries\000000000006 [] - C:\Windows\SysWOW64\winrnr.dll (Microsoft Corporation)
O10 - NameSpace_Catalog5\Catalog_Entries\000000000007 [] - C:\Program Files (x86)\Bonjour\mdnsNSP.dll (Apple Inc.)
O10 - Protocol_Catalog9\Catalog_Entries\000000000001 - C:\Windows\SysWOW64\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000002 - C:\Windows\SysWOW64\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000003 - C:\Windows\SysWOW64\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000004 - C:\Windows\SysWOW64\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000005 - C:\Windows\SysWOW64\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000006 - C:\Windows\SysWOW64\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000007 - C:\Windows\SysWOW64\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000008 - C:\Windows\SysWOW64\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000009 - C:\Windows\SysWOW64\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000010 - C:\Windows\SysWOW64\mswsock.dll (Microsoft Corporation)
O13 - gopher Prefix: missing
O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} http://java.sun.com/update/1.6.0/jinstall-1_6_0_26-windows-i586.cab (Java Plug-in 1.6.0_26)
O16 - DPF: {CAFEEFAC-0016-0000-0026-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0_26-windows-i586.cab (Java Plug-in 1.6.0_26)
O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0_26-windows-i586.cab (Java Plug-in 1.6.0_26)
O16 - DPF: {0D41B8C5-2599-4893-8183-00195EC8D5F9} http://support.asus.com/select/asusTek_sys_ctrl3.cab (asusTek_sysctrl Class)
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 192.168.0.1
O18:64bit: - Protocol\Handler\about {3050F406-98B5-11CF-BB82-00AA00BDCE0B} - C:\Windows\SysNative\mshtml.dll (Microsoft Corporation)
O18:64bit: - Protocol\Handler\cdl {3dd53d40-7b8b-11D0-b013-00aa0059ce02} - C:\Windows\SysNative\urlmon.dll (Microsoft Corporation)
O18:64bit: - Protocol\Handler\dvd {12D51199-0DB5-46FE-A120-47A3D7D937CC} - C:\Windows\SysNative\msvidctl.dll (Microsoft Corporation)
O18:64bit: - Protocol\Handler\file {79eac9e7-baf9-11ce-8c82-00aa004ba90b} - C:\Windows\SysNative\urlmon.dll (Microsoft Corporation)
O18:64bit: - Protocol\Handler\ftp {79eac9e3-baf9-11ce-8c82-00aa004ba90b} - C:\Windows\SysNative\urlmon.dll (Microsoft Corporation)
O18:64bit: - Protocol\Handler\grooveLocalGWS {88FED34C-F0CA-4636-A375-3CB6248B04CD} - Reg Error: Key error. File not found
O18:64bit: - Protocol\Handler\http {79eac9e2-baf9-11ce-8c82-00aa004ba90b} - C:\Windows\SysNative\urlmon.dll (Microsoft Corporation)
O18:64bit: - Protocol\Handler\https {79eac9e5-baf9-11ce-8c82-00aa004ba90b} - C:\Windows\SysNative\urlmon.dll (Microsoft Corporation)
O18:64bit: - Protocol\Handler\its {9D148291-B9C8-11D0-A4CC-0000F80149F6} - C:\Windows\SysNative\itss.dll (Microsoft Corporation)
O18:64bit: - Protocol\Handler\javascript {3050F3B2-98B5-11CF-BB82-00AA00BDCE0B} - C:\Windows\SysNative\mshtml.dll (Microsoft Corporation)
O18:64bit: - Protocol\Handler\local {79eac9e7-baf9-11ce-8c82-00aa004ba90b} - C:\Windows\SysNative\urlmon.dll (Microsoft Corporation)
O18:64bit: - Protocol\Handler\mailto {3050f3DA-98B5-11CF-BB82-00AA00BDCE0B} - C:\Windows\SysNative\mshtml.dll (Microsoft Corporation)
O18:64bit: - Protocol\Handler\mhtml {05300401-BCBC-11d0-85E3-00C04FD85AB4} - C:\Windows\SysNative\inetcomm.dll (Microsoft Corporation)
O18:64bit: - Protocol\Handler\mk {79eac9e6-baf9-11ce-8c82-00aa004ba90b} - C:\Windows\SysNative\urlmon.dll (Microsoft Corporation)
O18:64bit: - Protocol\Handler\ms-help {314111c7-a502-11d2-bbca-00c04f8ec294} - Reg Error: Key error. File not found
O18:64bit: - Protocol\Handler\ms-its {9D148291-B9C8-11D0-A4CC-0000F80149F6} - C:\Windows\SysNative\itss.dll (Microsoft Corporation)
O18:64bit: - Protocol\Handler\res {3050F3BC-98B5-11CF-BB82-00AA00BDCE0B} - C:\Windows\SysNative\mshtml.dll (Microsoft Corporation)
O18:64bit: - Protocol\Handler\tv {CBD30858-AF45-11D2-B6D6-00C04FBBDE6E} - C:\Windows\SysNative\msvidctl.dll (Microsoft Corporation)
O18:64bit: - Protocol\Handler\vbscript {3050F3B2-98B5-11CF-BB82-00AA00BDCE0B} - C:\Windows\SysNative\mshtml.dll (Microsoft Corporation)
O18 - Protocol\Handler\about {3050F406-98B5-11CF-BB82-00AA00BDCE0B} - C:\Windows\SysWOW64\mshtml.dll (Microsoft Corporation)
O18 - Protocol\Handler\cdl {3dd53d40-7b8b-11D0-b013-00aa0059ce02} - C:\Windows\SysWOW64\urlmon.dll (Microsoft Corporation)
O18 - Protocol\Handler\dvd {12D51199-0DB5-46FE-A120-47A3D7D937CC} - C:\Windows\SysWOW64\MSVidCtl.dll (Microsoft Corporation)
O18 - Protocol\Handler\file {79eac9e7-baf9-11ce-8c82-00aa004ba90b} - C:\Windows\SysWOW64\urlmon.dll (Microsoft Corporation)
O18 - Protocol\Handler\ftp {79eac9e3-baf9-11ce-8c82-00aa004ba90b} - C:\Windows\SysWOW64\urlmon.dll (Microsoft Corporation)
O18 - Protocol\Handler\grooveLocalGWS {88FED34C-F0CA-4636-A375-3CB6248B04CD} - C:\Program Files (x86)\Microsoft Office\Office12\GrooveSystemServices.dll (Microsoft Corporation)
O18 - Protocol\Handler\http {79eac9e2-baf9-11ce-8c82-00aa004ba90b} - C:\Windows\SysWOW64\urlmon.dll (Microsoft Corporation)
O18 - Protocol\Handler\https {79eac9e5-baf9-11ce-8c82-00aa004ba90b} - C:\Windows\SysWOW64\urlmon.dll (Microsoft Corporation)
O18 - Protocol\Handler\its {9D148291-B9C8-11D0-A4CC-0000F80149F6} - C:\Windows\SysWOW64\itss.dll (Microsoft Corporation)
O18 - Protocol\Handler\javascript {3050F3B2-98B5-11CF-BB82-00AA00BDCE0B} - C:\Windows\SysWOW64\mshtml.dll (Microsoft Corporation)
O18 - Protocol\Handler\local {79eac9e7-baf9-11ce-8c82-00aa004ba90b} - C:\Windows\SysWOW64\urlmon.dll (Microsoft Corporation)
O18 - Protocol\Handler\mailto {3050f3DA-98B5-11CF-BB82-00AA00BDCE0B} - C:\Windows\SysWOW64\mshtml.dll (Microsoft Corporation)
O18 - Protocol\Handler\mhtml {05300401-BCBC-11d0-85E3-00C04FD85AB4} - C:\Windows\SysWOW64\inetcomm.dll (Microsoft Corporation)
O18 - Protocol\Handler\mk {79eac9e6-baf9-11ce-8c82-00aa004ba90b} - C:\Windows\SysWOW64\urlmon.dll (Microsoft Corporation)
O18 - Protocol\Handler\ms-help {314111c7-a502-11d2-bbca-00c04f8ec294} - C:\Program Files (x86)\Common Files\microsoft shared\Help\hxds.dll (Microsoft Corporation)
O18 - Protocol\Handler\ms-its {9D148291-B9C8-11D0-A4CC-0000F80149F6} - C:\Windows\SysWOW64\itss.dll (Microsoft Corporation)
O18 - Protocol\Handler\res {3050F3BC-98B5-11CF-BB82-00AA00BDCE0B} - C:\Windows\SysWOW64\mshtml.dll (Microsoft Corporation)
O18 - Protocol\Handler\tv {CBD30858-AF45-11D2-B6D6-00C04FBBDE6E} - C:\Windows\SysWOW64\MSVidCtl.dll (Microsoft Corporation)
O18 - Protocol\Handler\vbscript {3050F3B2-98B5-11CF-BB82-00AA00BDCE0B} - C:\Windows\SysWOW64\mshtml.dll (Microsoft Corporation)
O18:64bit: - Protocol\Filter\application/octet-stream {1E66F26B-79EE-11D2-8710-00C04F79ED0D} - C:\Windows\SysNative\mscoree.dll (Microsoft Corporation)
O18:64bit: - Protocol\Filter\application/x-complus {1E66F26B-79EE-11D2-8710-00C04F79ED0D} - C:\Windows\SysNative\mscoree.dll (Microsoft Corporation)
O18:64bit: - Protocol\Filter\application/x-msdownload {1E66F26B-79EE-11D2-8710-00C04F79ED0D} - C:\Windows\SysNative\mscoree.dll (Microsoft Corporation)
O18:64bit: - Protocol\Filter\deflate {8f6b0360-b80d-11d0-a9b3-006097942311} - C:\Windows\SysNative\urlmon.dll (Microsoft Corporation)
O18:64bit: - Protocol\Filter\gzip {8f6b0360-b80d-11d0-a9b3-006097942311} - C:\Windows\SysNative\urlmon.dll (Microsoft Corporation)
O18:64bit: - Protocol\Filter\text/xml {807563E5-5146-11D5-A672-00B0D022E945} - C:\Program Files\Common Files\Microsoft Shared\OFFICE12\MSOXMLMF.DLL (Microsoft Corporation)
O18 - Protocol\Filter\application/octet-stream {1E66F26B-79EE-11D2-8710-00C04F79ED0D} - C:\Windows\SysWow64\mscoree.dll (Microsoft Corporation)
O18 - Protocol\Filter\application/x-complus {1E66F26B-79EE-11D2-8710-00C04F79ED0D} - C:\Windows\SysWow64\mscoree.dll (Microsoft Corporation)
O18 - Protocol\Filter\application/x-msdownload {1E66F26B-79EE-11D2-8710-00C04F79ED0D} - C:\Windows\SysWow64\mscoree.dll (Microsoft Corporation)
O18 - Protocol\Filter\deflate {8f6b0360-b80d-11d0-a9b3-006097942311} - C:\Windows\SysWOW64\urlmon.dll (Microsoft Corporation)
O18 - Protocol\Filter\gzip {8f6b0360-b80d-11d0-a9b3-006097942311} - C:\Windows\SysWOW64\urlmon.dll (Microsoft Corporation)
O18 - Protocol\Filter\text/xml {807563E5-5146-11D5-A672-00B0D022E945} - C:\Program Files (x86)\Common Files\microsoft shared\OFFICE12\MSOXMLMF.DLL (Microsoft Corporation)
O20:64bit: - HKLM Winlogon: Shell - (explorer.exe) - C:\Windows\explorer.exe (Microsoft Corporation)
O20:64bit: - HKLM Winlogon: UserInit - (C:\Windows\system32\userinit.exe) - C:\Windows\SysNative\userinit.exe (Microsoft Corporation)
O20:64bit: - HKLM Winlogon: VMApplet - (rundll32 shell32) - C:\Windows\SysNative\shell32.dll (Microsoft Corporation)
O20:64bit: - HKLM Winlogon: VMApplet - (Control_RunDLL "sysdm.cpl") - C:\Windows\SysNative\sysdm.cpl (Microsoft Corporation)
O20 - HKLM Winlogon: Shell - (explorer.exe) - C:\Windows\SysWow64\explorer.exe (Microsoft Corporation)
O20 - HKLM Winlogon: UserInit - (c:\windows\syswow64\userinit.exe) - c:\Windows\SysWOW64\userinit.exe (Microsoft Corporation)
O20 - HKLM Winlogon: VMApplet - (rundll32 shell32) - C:\Windows\SysWow64\shell32.dll (Microsoft Corporation)
O20 - HKLM Winlogon: VMApplet - (Control_RunDLL "sysdm.cpl") - C:\Windows\SysWow64\sysdm.cpl (Microsoft Corporation)
O21:64bit: - SSODL: WebCheck - {E6FB5E20-DE35-11CF-9C87-00AA005127ED} - C:\Windows\SysNative\webcheck.dll (Microsoft Corporation)
O21 - SSODL: WebCheck - {E6FB5E20-DE35-11CF-9C87-00AA005127ED} - C:\Windows\SysWOW64\webcheck.dll (Microsoft Corporation)
O22:64bit: - SharedTaskScheduler: {8C7461EF-2B13-11d2-BE35-3078302C2030} - Component Categories cache daemon - C:\Windows\SysNative\browseui.dll (Microsoft Corporation)
O22 - SharedTaskScheduler: {8C7461EF-2B13-11d2-BE35-3078302C2030} - Component Categories cache daemon - C:\Windows\SysWOW64\browseui.dll (Microsoft Corporation)
O24 - Desktop WallPaper: C:\Users\alan\AppData\Roaming\Microsoft\Windows Photo Gallery\Windows Photo Gallery Wallpaper.jpg
O24 - Desktop BackupWallPaper: C:\Users\alan\AppData\Roaming\Microsoft\Windows Photo Gallery\Windows Photo Gallery Wallpaper.jpg
O28 - HKLM ShellExecuteHooks: {B5A7F190-DDA6-4420-B3BA-52453494E6CD} - C:\Program Files (x86)\Microsoft Office\Office12\GrooveShellExtensions.dll (Microsoft Corporation)
O29:64bit: - HKLM SecurityProviders - (credssp.dll) - C:\Windows\SysWow64\credssp.dll (Microsoft Corporation)
O29 - HKLM SecurityProviders - (credssp.dll) - C:\Windows\SysWow64\credssp.dll (Microsoft Corporation)
O30:64bit: - LSA: Authentication Packages - (msv1_0) - C:\Windows\SysNative\msv1_0.dll (Microsoft Corporation)
O30 - LSA: Authentication Packages - (msv1_0) - C:\Windows\SysWow64\msv1_0.dll (Microsoft Corporation)
O30:64bit: - LSA: Security Packages - (kerberos) - C:\Windows\SysNative\kerberos.dll (Microsoft Corporation)
O30:64bit: - LSA: Security Packages - (msv1_0) - C:\Windows\SysNative\msv1_0.dll (Microsoft Corporation)
O30:64bit: - LSA: Security Packages - (schannel) - C:\Windows\SysNative\schannel.dll (Microsoft Corporation)
O30:64bit: - LSA: Security Packages - (wdigest) - C:\Windows\SysNative\wdigest.dll (Microsoft Corporation)
O30:64bit: - LSA: Security Packages - (tspkg) - C:\Windows\SysNative\tspkg.dll (Microsoft Corporation)
O30 - LSA: Security Packages - (kerberos) - C:\Windows\SysWow64\kerberos.dll (Microsoft Corporation)
O30 - LSA: Security Packages - (msv1_0) - C:\Windows\SysWow64\msv1_0.dll (Microsoft Corporation)
O30 - LSA: Security Packages - (schannel) - C:\Windows\SysWow64\schannel.dll (Microsoft Corporation)
O30 - LSA: Security Packages - (wdigest) - C:\Windows\SysWow64\wdigest.dll (Microsoft Corporation)
O30 - LSA: Security Packages - (tspkg) - C:\Windows\SysWow64\tspkg.dll (Microsoft Corporation)
O31 - SafeBoot: AlternateShell - cmd.exe
O32 - HKLM CDRom: AutoRun - 1
O32 - AutoRun File - [1601/01/01 01:00:00 | 000,000,077 | ---- | M] () - F:\autorun.inf -- [ FAT32 ]
O34 - HKLM BootExecute: (autocheck autochk *) - File not found
O35:64bit: - HKLM\..comfile [open] -- "%1" %*
O35:64bit: - HKLM\..exefile [open] -- "%1" %*
O35 - HKLM\..comfile [open] -- "%1" %*
O35 - HKLM\..exefile [open] -- "%1" %*
O37:64bit: - HKLM\...com [@ = comfile] -- "%1" %*
O37:64bit: - HKLM\...exe [@ = exefile] -- "%1" %*
O37 - HKLM\...com [@ = comfile] -- "%1" %*
O37 - HKLM\...exe [@ = exefile] -- "%1" %*
O37 - HKCU\...exe [@ = exefile] -- Reg Error: Key error. File not found
========== Files/Folders - Created Within 60 Days ==========
[2011/07/02 15:23:35 | 000,000,000 | ---D | C] -- C:\Users\alan\AppData\Roaming\anpo.republika.pl
[2011/07/02 15:22:39 | 000,000,000 | ---D | C] -- C:\Users\alan\AppData\Roaming\fltk.org
[2011/07/02 15:22:18 | 000,077,312 | ---- | C] (Audio, palmtopy, GPS i inne) -- C:\Windows\gmt.exe
[2011/07/02 15:22:18 | 000,000,000 | ---D | C] -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\GmapTool
[2011/07/02 15:22:18 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\GmapTool
[2011/07/02 12:21:03 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\ESET
[2011/07/01 00:35:17 | 000,000,000 | ---D | C] -- C:\Users\alan\Documents\My Garmin
[2011/07/01 00:35:16 | 000,000,000 | ---D | C] -- C:\Users\alan\AppData\Roaming\GARMIN
[2011/07/01 00:35:16 | 000,000,000 | ---D | C] -- C:\ProgramData\GARMIN
[2011/06/30 22:34:27 | 000,580,096 | ---- | C] (OldTimer Tools) -- C:\Users\alan\Desktop\OTL.exe
[2011/06/28 13:05:10 | 000,000,000 | ---D | C] -- C:\Users\alan\garmin
[2011/06/21 14:16:40 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Common Files\Adobe
[2011/06/21 10:33:32 | 000,000,000 | ---D | C] -- C:\Windows\pss
[2011/06/15 16:19:15 | 000,000,000 | ---D | C] -- C:\Users\alan\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\DVD Catalyst
[2011/06/15 15:17:02 | 000,759,808 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\mshtmled.dll
[2011/06/15 15:17:02 | 000,478,208 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\mshtmled.dll
[2011/06/15 15:17:01 | 000,590,848 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\msfeeds.dll
[2011/06/15 15:17:01 | 000,485,376 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\html.iec
[2011/06/15 15:17:01 | 000,471,040 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\msfeeds.dll
[2011/06/15 15:17:01 | 000,389,632 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\html.iec
[2011/06/15 15:17:01 | 000,249,856 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\iepeers.dll
[2011/06/15 15:17:01 | 000,193,024 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\iepeers.dll
[2011/06/15 15:17:00 | 000,086,528 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\ieencode.dll
[2011/06/15 15:17:00 | 000,078,336 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\ieencode.dll
[2011/06/15 15:16:59 | 000,422,400 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\ieapfltr.dll
[2011/06/15 15:16:59 | 000,380,928 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\ieapfltr.dll
[2011/06/15 15:16:41 | 000,847,360 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\oleaut32.dll
[2011/06/15 10:53:48 | 000,000,000 | ---D | C] -- C:\Users\alan\E PAD
[2011/06/10 15:06:45 | 000,000,000 | R--D | C] -- C:\Users\alan\Dropbox
[2011/06/10 15:04:32 | 000,000,000 | ---D | C] -- C:\Users\alan\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Dropbox
[2011/06/10 15:03:47 | 000,000,000 | ---D | C] -- C:\Users\alan\AppData\Roaming\Dropbox
[2011/06/08 14:19:50 | 000,000,000 | ---D | C] -- C:\android
[2011/06/08 14:19:13 | 000,525,544 | ---- | C] (Sun Microsystems, Inc.) -- C:\Windows\SysNative\deployJava1.dll
[2011/06/08 14:19:13 | 000,190,752 | ---- | C] (Sun Microsystems, Inc.) -- C:\Windows\SysNative\javaws.exe
[2011/06/08 14:19:13 | 000,171,808 | ---- | C] (Sun Microsystems, Inc.) -- C:\Windows\SysNative\javaw.exe
[2011/06/08 14:19:13 | 000,171,808 | ---- | C] (Sun Microsystems, Inc.) -- C:\Windows\SysNative\java.exe
[2011/06/08 14:18:14 | 000,000,000 | ---D | C] -- C:\Program Files\Java
[2011/06/08 14:11:26 | 000,000,000 | ---D | C] -- C:\Users\alan\.android
[2011/06/08 14:11:24 | 000,000,000 | ---D | C] -- C:\ProgramData\Sun
[2011/06/08 14:11:22 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Common Files\Java
[2011/06/08 14:10:18 | 000,472,808 | ---- | C] (Sun Microsystems, Inc.) -- C:\Windows\SysWow64\deployJava1.dll
[2011/06/08 14:10:18 | 000,157,472 | ---- | C] (Sun Microsystems, Inc.) -- C:\Windows\SysWow64\javaws.exe
[2011/06/08 14:10:18 | 000,145,184 | ---- | C] (Sun Microsystems, Inc.) -- C:\Windows\SysWow64\javaw.exe
[2011/06/08 14:10:18 | 000,145,184 | ---- | C] (Sun Microsystems, Inc.) -- C:\Windows\SysWow64\java.exe
[2011/06/08 14:09:46 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Java
[2011/06/02 15:52:49 | 000,000,000 | ---D | C] -- C:\af0a89f5e38c9c706f86dc14e767a766
[2011/05/30 17:31:57 | 000,020,480 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\winusb.dll
[2011/05/30 17:28:37 | 000,042,064 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\drivers\WdfLdr.sys
[2011/05/30 12:13:19 | 000,000,000 | ---D | C] -- C:\Users\alan\.dvdcss
[2011/05/30 12:12:25 | 000,000,000 | ---D | C] -- C:\Users\alan\AppData\Roaming\DVD Catalyst 4
[2011/05/30 12:11:54 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\DVD Catalyst
[2011/05/20 14:04:35 | 000,000,000 | ---D | C] -- C:\ProgramData\Driver Whiz
[2011/05/18 12:57:03 | 000,000,000 | ---D | C] -- C:\Users\alan\AppData\Roaming\Outlook
[2011/05/09 11:51:15 | 000,000,000 | ---D | C] -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DVDFab 8 Qt
[2011/05/09 11:51:10 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\DVDFab 8 Qt
[2011/05/09 11:48:10 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\DVDFab Decrypter 3
[2011/05/09 11:48:10 | 000,000,000 | ---D | C] -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DVDFab Decrypter
[2011/05/08 19:53:43 | 000,000,000 | ---D | C] -- C:\Users\alan\AppData\Roaming\HandBrake
[2011/05/08 19:53:43 | 000,000,000 | ---D | C] -- C:\Users\alan\AppData\Local\HandBrake
[2011/05/08 19:53:36 | 000,000,000 | ---D | C] -- C:\Users\alan\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Handbrake
[2011/05/08 19:53:36 | 000,000,000 | ---D | C] -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Handbrake
[2011/05/08 19:53:36 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Handbrake
[2011/05/08 19:00:19 | 000,000,000 | ---D | C] -- C:\Users\alan\AppData\Roaming\WinRAR
[2011/05/08 19:00:19 | 000,000,000 | ---D | C] -- C:\Users\alan\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\WinRAR
[2011/05/08 19:00:19 | 000,000,000 | ---D | C] -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\WinRAR
[2011/05/08 19:00:16 | 000,000,000 | ---D | C] -- C:\Program Files\WinRAR
[2011/05/05 18:09:22 | 000,000,000 | ---D | C] -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office
[2011/05/05 18:07:15 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Microsoft Works
[2011/05/05 18:06:42 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Microsoft Visual Studio
[2011/05/05 18:06:42 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Common Files\DESIGNER
[2011/05/05 18:06:25 | 000,000,000 | ---D | C] -- C:\Windows\PCHEALTH
[2011/05/05 18:04:44 | 000,000,000 | ---D | C] -- C:\Program Files\Microsoft Office
[2011/05/05 18:04:39 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Microsoft Visual Studio 8
[2011/05/05 18:03:57 | 000,000,000 | ---D | C] -- C:\Users\alan\AppData\Local\Microsoft Help
[2011/05/05 18:03:55 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Microsoft Office
[2011/05/05 18:03:55 | 000,000,000 | ---D | C] -- C:\ProgramData\Microsoft Help
[2011/05/05 18:02:55 | 000,000,000 | RH-D | C] -- C:\MSOCache
[2011/05/05 15:44:40 | 000,000,000 | ---D | C] -- C:\Users\alan\AppData\Roaming\ASUS.AF361EFD06694D11175EA8BF6E21597A36AD9F1D.1
[2011/05/05 15:00:49 | 000,000,000 | -HSD | C] -- C:\aws
[2011/05/05 15:00:41 | 000,000,000 | ---D | C] -- C:\ASUS WebStorage
[2011/05/05 14:57:35 | 000,000,000 | ---D | C] -- C:\ProgramData\UDL
[2011/05/05 14:57:35 | 000,000,000 | ---D | C] -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Epson Software
[2011/05/05 14:56:26 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Epson Software
[2011/05/05 14:55:12 | 000,000,000 | ---D | C] -- C:\Program Files\Epson Software
[2011/05/05 14:53:15 | 000,501,912 | ---- | C] (SEIKO EPSON CORPORATION) -- C:\Windows\SysWow64\PICSDK2.dll
[2011/05/05 14:53:15 | 000,120,992 | ---- | C] (SEIKO EPSON CORPORATION) -- C:\Windows\SysWow64\EpPicPrt.dll
[2011/05/05 14:53:15 | 000,108,704 | ---- | C] (SEIKO EPSON CORPORATION) -- C:\Windows\SysWow64\PICEntry.dll
[2011/05/05 14:53:15 | 000,080,024 | ---- | C] (SEIKO EPSON CORPORATION) -- C:\Windows\SysWow64\PICSDK.dll
[2011/05/05 14:53:15 | 000,071,840 | ---- | C] (SEIKO EPSON CORPORATION) -- C:\Windows\SysWow64\EPPicMgr.dll
[2011/05/05 14:53:10 | 000,000,000 | ---D | C] -- C:\Users\alan\AppData\Roaming\InstallShield
[2011/05/05 14:49:55 | 000,101,888 | ---- | C] (SEIKO EPSON CORP.) -- C:\Windows\SysNative\esxcwiad.dll
[2011/05/05 14:49:55 | 000,000,000 | ---D | C] -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\EPSON Scan
[2011/05/05 14:49:09 | 000,000,000 | ---D | C] -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\EPSON
[2011/05/05 14:48:41 | 000,108,032 | ---- | C] (SEIKO EPSON CORPORATION) -- C:\Windows\SysNative\E_ILMCEE.DLL
[2011/05/05 14:48:41 | 000,081,408 | ---- | C] (SEIKO EPSON CORPORATION) -- C:\Windows\SysNative\E_IBCBCEE.DLL
[2011/05/05 14:48:41 | 000,008,704 | ---- | C] (SEIKO EPSON CORP.) -- C:\Windows\SysNative\E_GCINST.DLL
[2011/05/05 14:46:11 | 000,000,000 | ---D | C] -- C:\ProgramData\EPSON
[2011/05/05 14:34:05 | 000,000,000 | ---D | C] -- C:\Users\alan\AppData\Roaming\EPSON
[2011/05/05 14:28:26 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\EPSON
[2011/05/05 14:28:09 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Common Files\InstallShield
[2011/04/25 12:48:15 | 000,082,816 | ---- | C] (VSO Software) -- C:\Users\alan\AppData\Roaming\pcouffin.sys
[1 C:\Windows\SysNative\drivers\*.tmp files -> C:\Windows\SysNative\drivers\*.tmp -> ]
========== Files - Modified Within 60 Days ==========
[2011/07/04 12:51:29 | 000,003,616 | -H-- | M] () -- C:\Windows\SysNative\7B296FB0-376B-497e-B012-9C450E1B7327-2P-1.C7483456-A289-439d-8115-601632D005A0
[2011/07/04 12:51:29 | 000,003,616 | -H-- | M] () -- C:\Windows\SysNative\7B296FB0-376B-497e-B012-9C450E1B7327-2P-0.C7483456-A289-439d-8115-601632D005A0
[2011/07/04 12:47:58 | 000,000,852 | ---- | M] () -- C:\Windows\tasks\GoogleUpdateTaskUserS-1-5-21-4240333563-575618758-3584005618-1000Core.job
[2011/07/04 12:39:27 | 000,000,904 | ---- | M] () -- C:\Windows\tasks\GoogleUpdateTaskUserS-1-5-21-4240333563-575618758-3584005618-1000UA.job
[2011/07/04 12:39:22 | 000,067,584 | --S- | M] () -- C:\Windows\bootstat.dat
[2011/07/03 20:42:36 | 000,703,388 | ---- | M] () -- C:\Windows\SysNative\PerfStringBackup.INI
[2011/07/03 20:42:36 | 000,608,760 | ---- | M] () -- C:\Windows\SysNative\perfh009.dat
[2011/07/03 20:42:36 | 000,108,268 | ---- | M] () -- C:\Windows\SysNative\perfc009.dat
[2011/07/01 19:24:05 | 000,011,776 | ---- | M] () -- C:\Users\alan\AppData\Local\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
[2011/06/30 22:34:26 | 000,580,096 | ---- | M] (OldTimer Tools) -- C:\Users\alan\Desktop\OTL.exe
[2011/06/30 22:34:09 | 000,459,264 | ---- | M] () -- C:\Users\alan\Desktop\CKScanner.exe
[2011/06/30 11:25:45 | 000,000,528 | ---- | M] () -- C:\Windows\SysNative\drivers\kgpcpy.cfg
[2011/06/30 11:24:45 | 000,000,112 | ---- | M] () -- C:\Windows\SysNative\drivers\kgpfr2.cfg
[2011/06/30 10:15:00 | 000,011,196 | -HS- | M] () -- C:\Users\alan\AppData\Local\43pr3145p1ank2bl181n4tqg6c0d32fwtgu58srb33ja
[2011/06/30 10:15:00 | 000,011,196 | -HS- | M] () -- C:\ProgramData\43pr3145p1ank2bl181n4tqg6c0d32fwtgu58srb33ja
[2011/06/30 08:17:44 | 000,002,037 | ---- | M] () -- C:\Users\alan\Desktop\Google Chrome.lnk
[2011/06/30 08:17:44 | 000,001,999 | ---- | M] () -- C:\Users\alan\Application Data\Microsoft\Internet Explorer\Quick Launch\Google Chrome.lnk
[2011/06/29 16:13:04 | 000,377,000 | ---- | M] () -- C:\Windows\SysNative\FNTCACHE.DAT
[2011/06/21 14:16:43 | 000,001,922 | ---- | M] () -- C:\Users\Public\Desktop\Adobe Reader X.lnk
[2011/06/21 10:32:19 | 000,001,715 | ---- | M] () -- C:\Users\alan\Desktop\MySyncFolder.lnk
[2011/06/15 16:19:15 | 000,000,918 | ---- | M] () -- C:\Users\alan\Application Data\Microsoft\Internet Explorer\Quick Launch\DVD Catalyst 4.lnk
[2011/06/15 16:19:15 | 000,000,894 | ---- | M] () -- C:\Users\alan\Desktop\DVD Catalyst 4.lnk
[2011/06/14 11:31:48 | 001,342,881 | ---- | M] () -- C:\Users\alan\Platinum Sudoku v1.2.3.apk
[2011/06/10 15:06:45 | 000,000,940 | ---- | M] () -- C:\Users\alan\Desktop\Dropbox.lnk
[2011/06/08 14:20:37 | 000,000,394 | ---- | M] () -- C:\Users\alan\Desktop\android - Shortcut.lnk
[2011/06/08 14:18:21 | 000,525,544 | ---- | M] (Sun Microsystems, Inc.) -- C:\Windows\SysNative\deployJava1.dll
[2011/06/08 14:18:21 | 000,190,752 | ---- | M] (Sun Microsystems, Inc.) -- C:\Windows\SysNative\javaws.exe
[2011/06/08 14:18:21 | 000,171,808 | ---- | M] (Sun Microsystems, Inc.) -- C:\Windows\SysNative\javaw.exe
[2011/06/08 14:18:21 | 000,171,808 | ---- | M] (Sun Microsystems, Inc.) -- C:\Windows\SysNative\java.exe
[2011/06/08 14:10:02 | 000,472,808 | ---- | M] (Sun Microsystems, Inc.) -- C:\Windows\SysWow64\deployJava1.dll
[2011/06/08 14:10:02 | 000,157,472 | ---- | M] (Sun Microsystems, Inc.) -- C:\Windows\SysWow64\javaws.exe
[2011/06/08 14:10:02 | 000,145,184 | ---- | M] (Sun Microsystems, Inc.) -- C:\Windows\SysWow64\javaw.exe
[2011/06/08 14:10:02 | 000,145,184 | ---- | M] (Sun Microsystems, Inc.) -- C:\Windows\SysWow64\java.exe
[2011/06/02 15:52:48 | 000,000,000 | -H-- | M] () -- C:\Windows\wusa.lock
[2011/05/30 17:32:10 | 000,000,000 | -H-- | M] () -- C:\Windows\SysNative\drivers\Msft_Kernel_WinUSB_01009.Wdf
[2011/05/30 17:29:03 | 000,000,000 | -H-- | M] () -- C:\Windows\SysNative\drivers\MsftWdf_Kernel_01009_Coinstaller_Critical.Wdf
[2011/05/30 12:22:50 | 000,001,004 | ---- | M] () -- C:\Users\alan\Application Data\Microsoft\Internet Explorer\Quick Launch\ASUS Sync.lnk
[2011/05/30 12:22:50 | 000,000,980 | ---- | M] () -- C:\Users\Public\Desktop\ASUS Sync.lnk
[2011/05/29 09:11:30 | 000,039,984 | ---- | M] (Malwarebytes Corporation) -- C:\Windows\SysWow64\drivers\mbamswissarmy.sys
[2011/05/29 09:11:20 | 000,025,912 | ---- | M] (Malwarebytes Corporation) -- C:\Windows\SysNative\drivers\mbam.sys
[2011/05/18 17:36:44 | 240,922,846 | ---- | M] () -- C:\Users\alan\VIDEO0036.3gp
[2011/05/18 11:56:19 | 000,000,442 | ---- | M] () -- C:\Users\alan\Application Data\Microsoft\Internet Explorer\Quick Launch\E-PAD - Shortcut.lnk
[2011/05/18 09:32:10 | 000,001,067 | ---- | M] () -- C:\Users\alan\Application Data\Microsoft\Internet Explorer\Quick Launch\tom tom stuff - Shortcut.lnk
[2011/05/09 11:51:16 | 000,000,855 | ---- | M] () -- C:\Users\alan\Desktop\DVDFab 8 Qt.lnk
[2011/05/09 11:48:11 | 000,000,867 | ---- | M] () -- C:\Users\alan\Desktop\DVDFab Decrypter.lnk
[2011/05/08 19:53:36 | 000,000,858 | ---- | M] () -- C:\Users\alan\Desktop\Handbrake.lnk
[2011/05/05 14:57:35 | 000,002,002 | ---- | M] () -- C:\Users\Public\Desktop\Epson Easy Photo Print.lnk
[2011/05/05 14:55:12 | 000,000,306 | ---- | M] () -- C:\Windows\setup.iss
[2011/05/05 14:49:55 | 000,000,765 | ---- | M] () -- C:\Users\Public\Desktop\EPSON Scan.lnk
========== Files Created - No Company Name ==========
[2011/06/30 22:34:19 | 000,459,264 | ---- | C] () -- C:\Users\alan\Desktop\CKScanner.exe
[2011/06/30 11:24:45 | 000,000,112 | ---- | C] () -- C:\Windows\SysNative\drivers\kgpfr2.cfg
[2011/06/30 11:24:15 | 000,000,528 | ---- | C] () -- C:\Windows\SysNative\drivers\kgpcpy.cfg
[2011/06/30 10:12:46 | 000,011,196 | -HS- | C] () -- C:\Users\alan\AppData\Local\43pr3145p1ank2bl181n4tqg6c0d32fwtgu58srb33ja
[2011/06/30 10:12:46 | 000,011,196 | -HS- | C] () -- C:\ProgramData\43pr3145p1ank2bl181n4tqg6c0d32fwtgu58srb33ja
[2011/06/21 14:16:43 | 000,001,922 | ---- | C] () -- C:\Users\Public\Desktop\Adobe Reader X.lnk
[2011/06/21 14:16:43 | 000,001,804 | ---- | C] () -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Adobe Reader X.lnk
[2011/06/14 11:31:58 | 001,342,881 | ---- | C] () -- C:\Users\alan\Platinum Sudoku v1.2.3.apk
[2011/06/10 15:06:45 | 000,000,940 | ---- | C] () -- C:\Users\alan\Desktop\Dropbox.lnk
[2011/06/08 14:20:37 | 000,000,394 | ---- | C] () -- C:\Users\alan\Desktop\android - Shortcut.lnk
[2011/06/02 15:52:48 | 000,000,000 | -H-- | C] () -- C:\Windows\wusa.lock
[2011/05/30 17:32:10 | 000,000,000 | -H-- | C] () -- C:\Windows\SysNative\drivers\Msft_Kernel_WinUSB_01009.Wdf
[2011/05/30 17:29:03 | 000,000,000 | -H-- | C] () -- C:\Windows\SysNative\drivers\MsftWdf_Kernel_01009_Coinstaller_Critical.Wdf
[2011/05/30 17:28:39 | 000,000,003 | ---- | C] () -- C:\Windows\SysNative\drivers\MsftWdf_Kernel_01009_Inbox_Critical.Wdf
[2011/05/30 12:22:50 | 000,001,004 | ---- | C] () -- C:\Users\alan\Application Data\Microsoft\Internet Explorer\Quick Launch\ASUS Sync.lnk
[2011/05/30 12:22:50 | 000,000,980 | ---- | C] () -- C:\Users\Public\Desktop\ASUS Sync.lnk
[2011/05/30 12:11:55 | 000,000,918 | ---- | C] () -- C:\Users\alan\Application Data\Microsoft\Internet Explorer\Quick Launch\DVD Catalyst 4.lnk
[2011/05/30 12:11:55 | 000,000,894 | ---- | C] () -- C:\Users\alan\Desktop\DVD Catalyst 4.lnk
[2011/05/18 17:41:19 | 240,922,846 | ---- | C] () -- C:\Users\alan\VIDEO0036.3gp
[2011/05/18 11:56:19 | 000,000,442 | ---- | C] () -- C:\Users\alan\Application Data\Microsoft\Internet Explorer\Quick Launch\E-PAD - Shortcut.lnk
[2011/05/09 11:51:16 | 000,000,855 | ---- | C] () -- C:\Users\alan\Desktop\DVDFab 8 Qt.lnk
[2011/05/09 11:48:11 | 000,000,867 | ---- | C] () -- C:\Users\alan\Desktop\DVDFab Decrypter.lnk
[2011/05/08 19:53:36 | 000,000,858 | ---- | C] () -- C:\Users\alan\Desktop\Handbrake.lnk
[2011/05/05 15:00:50 | 000,001,715 | ---- | C] () -- C:\Users\alan\Desktop\MySyncFolder.lnk
[2011/05/05 14:57:35 | 000,002,002 | ---- | C] () -- C:\Users\Public\Desktop\Epson Easy Photo Print.lnk
[2011/05/05 14:55:02 | 000,000,306 | ---- | C] () -- C:\Windows\setup.iss
[2011/05/05 14:53:15 | 000,111,932 | ---- | C] () -- C:\Windows\SysWow64\EPPICPrinterDB.dat
[2011/05/05 14:53:15 | 000,031,053 | ---- | C] () -- C:\Windows\SysWow64\EPPICPattern131.dat
[2011/05/05 14:53:15 | 000,027,417 | ---- | C] () -- C:\Windows\SysWow64\EPPICPattern121.dat
[2011/05/05 14:53:15 | 000,026,154 | ---- | C] () -- C:\Windows\SysWow64\EPPICPattern1.dat
[2011/05/05 14:53:15 | 000,024,903 | ---- | C] () -- C:\Windows\SysWow64\EPPICPattern3.dat
[2011/05/05 14:53:15 | 000,021,390 | ---- | C] () -- C:\Windows\SysWow64\EPPICPattern5.dat
[2011/05/05 14:53:15 | 000,020,148 | ---- | C] () -- C:\Windows\SysWow64\EPPICPattern2.dat
[2011/05/05 14:53:15 | 000,013,732 | ---- | C] () -- C:\Windows\SysWow64\EPPICLocal_EN.cfg
[2011/05/05 14:53:15 | 000,011,811 | ---- | C] () -- C:\Windows\SysWow64\EPPICPattern4.dat
[2011/05/05 14:53:15 | 000,006,442 | ---- | C] () -- C:\Windows\SysWow64\EPPICLocal_IT.cfg
[2011/05/05 14:53:15 | 000,006,347 | ---- | C] () -- C:\Windows\SysWow64\EPPICLocal_PT.cfg
[2011/05/05 14:53:15 | 000,006,347 | ---- | C] () -- C:\Windows\SysWow64\EPPICLocal_BP.cfg
[2011/05/05 14:53:15 | 000,006,335 | ---- | C] () -- C:\Windows\SysWow64\EPPICLocal_GE.cfg
[2011/05/05 14:53:15 | 000,006,195 | ---- | C] () -- C:\Windows\SysWow64\EPPICLocal_FR.cfg
[2011/05/05 14:53:15 | 000,006,195 | ---- | C] () -- C:\Windows\SysWow64\EPPICLocal_CF.cfg
[2011/05/05 14:53:15 | 000,006,122 | ---- | C] () -- C:\Windows\SysWow64\EPPICLocal_DU.cfg
[2011/05/05 14:53:15 | 000,006,103 | ---- | C] () -- C:\Windows\SysWow64\EPPICLocal_ES.cfg
[2011/05/05 14:53:15 | 000,005,817 | ---- | C] () -- C:\Windows\SysWow64\EPPICLocal_KO.cfg
[2011/05/05 14:53:15 | 000,005,436 | ---- | C] () -- C:\Windows\SysWow64\EPPICLocal_SC.cfg
[2011/05/05 14:53:15 | 000,004,943 | ---- | C] () -- C:\Windows\SysWow64\EPPICPattern6.dat
[2011/05/05 14:53:15 | 000,002,889 | ---- | C] () -- C:\Windows\SysWow64\EPPICLocal_RU.cfg
[2011/05/05 14:53:15 | 000,002,426 | ---- | C] () -- C:\Windows\SysWow64\EPPICLocal_TC.cfg
[2011/05/05 14:53:15 | 000,001,146 | ---- | C] () -- C:\Windows\SysWow64\EPPICPresetData_DU.dat
[2011/05/05 14:53:15 | 000,001,139 | ---- | C] () -- C:\Windows\SysWow64\EPPICPresetData_PT.dat
[2011/05/05 14:53:15 | 000,001,139 | ---- | C] () -- C:\Windows\SysWow64\EPPICPresetData_BP.dat
[2011/05/05 14:53:15 | 000,001,136 | ---- | C] () -- C:\Windows\SysWow64\EPPICPresetData_ES.dat
[2011/05/05 14:53:15 | 000,001,129 | ---- | C] () -- C:\Windows\SysWow64\EPPICPresetData_FR.dat
[2011/05/05 14:53:15 | 000,001,129 | ---- | C] () -- C:\Windows\SysWow64\EPPICPresetData_CF.dat
[2011/05/05 14:53:15 | 000,001,120 | ---- | C] () -- C:\Windows\SysWow64\EPPICPresetData_IT.dat
[2011/05/05 14:53:15 | 000,001,107 | ---- | C] () -- C:\Windows\SysWow64\EPPICPresetData_GE.dat
[2011/05/05 14:53:15 | 000,001,104 | ---- | C] () -- C:\Windows\SysWow64\EPPICPresetData_EN.dat
[2011/05/05 14:53:15 | 000,000,097 | ---- | C] () -- C:\Windows\SysWow64\PICSDK.ini
[2011/05/05 14:49:55 | 000,000,765 | ---- | C] () -- C:\Users\Public\Desktop\EPSON Scan.lnk
[2011/04/25 12:48:15 | 000,099,384 | ---- | C] () -- C:\Users\alan\AppData\Roaming\inst.exe
[2011/04/25 12:48:15 | 000,007,859 | ---- | C] () -- C:\Users\alan\AppData\Roaming\pcouffin.cat
[2011/04/25 12:48:15 | 000,001,167 | ---- | C] () -- C:\Users\alan\AppData\Roaming\pcouffin.inf
[2011/04/02 16:26:53 | 000,117,248 | ---- | C] () -- C:\Windows\SysWow64\EhStorAuthn.dll
[2011/04/02 16:26:33 | 000,107,612 | ---- | C] () -- C:\Windows\SysWow64\StructuredQuerySchema.bin
[2011/04/02 16:26:17 | 000,368,640 | ---- | C] () -- C:\Windows\SysWow64\msjetoledb40.dll
[2011/04/01 14:50:31 | 000,018,904 | ---- | C] () -- C:\Windows\SysWow64\StructuredQuerySchemaTrivial.bin
[2011/03/30 21:14:46 | 000,000,000 | ---- | C] () -- C:\Windows\ativpsrm.bin
[2011/03/30 19:49:15 | 000,000,732 | ---- | C] () -- C:\Users\alan\AppData\Local\d3d9caps64.dat
[2011/03/30 17:10:02 | 000,011,776 | ---- | C] () -- C:\Users\alan\AppData\Local\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
[2011/01/13 03:03:20 | 000,003,155 | ---- | C] () -- C:\Windows\SysWow64\atipblag.dat
[2009/02/26 07:50:32 | 000,000,176 | ---- | C] () -- C:\Windows\explorer.exe.config
[2008/01/21 03:50:05 | 000,060,124 | ---- | C] () -- C:\Windows\SysWow64\tcpmon.ini
[2006/11/02 16:37:05 | 000,067,584 | --S- | C] () -- C:\Windows\bootstat.dat
[2006/11/02 13:37:14 | 000,215,943 | ---- | C] () -- C:\Windows\SysWow64\dssec.dat
[2006/11/02 13:24:17 | 000,000,741 | ---- | C] () -- C:\Windows\SysWow64\NOISE.DAT
[2006/11/02 13:18:17 | 000,673,088 | ---- | C] () -- C:\Windows\SysWow64\mlang.dat
[2006/11/02 10:47:54 | 000,043,131 | ---- | C] () -- C:\Windows\mib.bin
========== LOP Check ==========
[2011/07/02 15:23:35 | 000,000,000 | ---D | M] -- C:\Users\alan\AppData\Roaming\anpo.republika.pl
[2011/05/04 16:49:14 | 000,000,000 | ---D | M] -- C:\Users\alan\AppData\Roaming\ASUS
[2011/06/21 10:32:30 | 000,000,000 | ---D | M] -- C:\Users\alan\AppData\Roaming\ASUS WebStorage
[2011/05/05 15:44:40 | 000,000,000 | ---D | M] -- C:\Users\alan\AppData\Roaming\ASUS.AF361EFD06694D11175EA8BF6E21597A36AD9F1D.1
[2011/03/30 19:02:31 | 000,000,000 | ---D | M] -- C:\Users\alan\AppData\Roaming\CheckPoint
[2011/06/21 10:32:57 | 000,000,000 | ---D | M] -- C:\Users\alan\AppData\Roaming\Dropbox
[2011/06/15 16:19:36 | 000,000,000 | ---D | M] -- C:\Users\alan\AppData\Roaming\DVD Catalyst 4
[2011/05/04 16:43:18 | 000,000,000 | ---D | M] -- C:\Users\alan\AppData\Roaming\eCareme
[2011/06/07 16:27:52 | 000,000,000 | ---D | M] -- C:\Users\alan\AppData\Roaming\EPSON
[2011/07/02 15:22:39 | 000,000,000 | ---D | M] -- C:\Users\alan\AppData\Roaming\fltk.org
[2011/07/01 00:45:32 | 000,000,000 | ---D | M] -- C:\Users\alan\AppData\Roaming\GARMIN
[2011/05/11 14:37:09 | 000,000,000 | ---D | M] -- C:\Users\alan\AppData\Roaming\HandBrake
[2011/04/06 17:22:10 | 000,000,000 | ---D | M] -- C:\Users\alan\AppData\Roaming\HTC
[2011/04/06 17:19:17 | 000,000,000 | ---D | M] -- C:\Users\alan\AppData\Roaming\HTC.388BC06ACDAB6261375BCE37FBA2E023C0D7EE34.1
[2011/05/18 12:57:03 | 000,000,000 | ---D | M] -- C:\Users\alan\AppData\Roaming\Outlook
[2011/04/06 09:22:45 | 000,000,000 | ---D | M] -- C:\Users\alan\AppData\Roaming\TomTom
[2011/04/25 13:02:02 | 000,000,000 | ---D | M] -- C:\Users\alan\AppData\Roaming\Vso
[2011/07/03 07:03:24 | 000,032,522 | ---- | M] () -- C:\Windows\Tasks\SCHEDLGU.TXT
========== Purity Check ==========
< End of report >
