Vista Backups
sincky
1
I have searched over the forums about the Vista backup and I can't find the answer I'm looking for. I want to use the backup app that came with Vista business, however I'm not into wizards. I know what I want backed up, but I don't know how to get rid of the wizard. I either do a full backup or incimental. I don't want either. Is there a way to have it work something like the backup in XP?
1,823
I wish we had NT Backup. Backup and Restore removed tape drives. In Ultimate x64,
Control Panel - Backup and Restore console allows backups of files and entire computer.
    16GB DDR667
    SAS RAID
solonfox
45
Vista includes robocopy a command line tool that replaces xcopy (xcopy is still there too). Using robocopy, you could do what you want.
Start, key in 'cmd' and enter. At the cursor prompt key 'robocopy /?' to see the command line reference (key 'robocopy /? | more' to view one page at a time using the spacebar to advance to the next page).
However, a command line tool probably isn't what you want. I recommend downloading the Robocopy GUI. See - Utility Spotlight: Robocopy GUI and download the code from there.
It will probably do what you want.
-solon fox
johngalt
Antidisestablishmentarian
3,909
Location
3rd Rock
Another option is to look into third party backup tools. A couple of really good ones are Cobian backup and DriveImageXL. Another option - if you have Seagate drives, then you can download their backup tool, which is a watered down version of Acronis True Image.
    The Beast Model V
    eVGA X58 Classified3
    3 * 4GB Mushkin Enhanced Redline CL7 DDR3 1600 MHz (PC3-12800)
    eVGA GTX 970 + eVGA GTX 560 Ti 448 Core Calssified (PhysX)
    Realtek HD Audio (onboard)
    2 * Lenovo LT2323pwA
    2 * 1920 x 1080
    2 * Seagate Barracuda 7200.12 ST31000528AS 1TB 7200 RPM SATA II
    Seagate Barracuda 7200.12 ST1500DL001 1.5 TB SATA II
    ThermalTake BlackWidow 850W
    ThermalTake Level 10 GT
    Corsair H100 (CPU) + Air (2 * 210 mm + 3 * 120mm fans)
    Logitech MX Master
    Logitech G15 (gen 2)
    180 Mbit down / 15 Mbit up
    3 VMs built off IP 14971:
    UUP disabled / single VHD | UUP disabled / dual VHDs with moved \User Tree | UUP enabled / single VHD
