Solved Vista becomes invisible in dual boot order change to XP as default
Larvald
Hi!
I had Vista on C: drive and later installed XP on D: drive.
Boot order was then Vista - XP, worked ok. I then changed the boot order where XP to be the default . And now the boot manager does not allow me to even choose Vista, but goes directly to XP. The changes I did in Vista.
I have "restorepoint delete" fix active ( http://www.vistax64.com/tutorials/127417-system-restore-points-stop-xp-dual-boot-delete.html)
Restoring the fix does no difference to this issue other than making boot.ini visible for changes on the XP side, but without options for Vista.
Has my Vista gone "hasta la vista" or is it "see you never more". Is there some means of getting it alive again?
Lars
Brink
Staff member
mvp
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
MilesAhead
Eclectician
@Larvald if Brink's suggestion doesn't work you may be able to fix it up using VistaBootPro. Used to be free but I think they ask $9 for it now. Anyway, when I added XP to a Vista machine one of the steps after installing XP was getting Vista boot menu back by using VistaBootPro in XP. Either way should work.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
Larvald
Hi MilesAhead!
VistaBootPro (7,95€) did help me out.
I figured out how I ended up in this situation. I painted myself in the corner by setting the time, being impatient waiting, to show list of operating systems at statup to zero, thus going staight into the default. Or then it was that "someone" or something having done that.
Strange why the startup recovery didn't return the default value of 30 secs.
Thank's guys for your help.
Lars
Brink
Staff member
mvp
Lars, I'm happy to hear that you got it sorted. :)
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
MilesAhead
Eclectician
@Larvald yeah those bootup options are often nebulous. I dual boot Vista and XP so I thought if I set XP to "default" it would be the one chosen in the menu if I let it time out. Nope. No menu. Just boots XP. Go figure. :)
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
