Vista Biz 64-bit does not recognize firewire devices.
cyberdiety
In-house build of a Non-linear Editing workstation. Evga 780i mobo, Intel quad 2.4 Cpu, 8GB OCZ SLI DDR 800 RAM, 500GB 7200rpm OS drive (WD), 2.5TB onboard RAID 0 array, 2 PNY XLR8 8800GT video card (linked), M-Audio 1010DLT audio card, Iogear 4port Raid 5 card.
All worked fine together then today the firewire devices were no longer recognized. External devices were connected to system with USB to check and devices worked fine. Also were connected to other systems via firewire and were ok. Onboard Texas Instruments 1394 controller driver in device manager says ok. But no firewire connections get made. Neither mobo onboard firewire nor optional firewire port has any effect.
Ideas?
    In-House Build
lordbob75
Lord of Bobs
Vista Pro
Do a restore to the day before this happened.
Did you install anything new or do something different to it?
~Lordbob
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Samsung SP2514N ATA 250Gb 7200RPM
    Samsung [Model] 1Tb 7200RPM SATA2
    Razer Lachesis
    Razer Tarantula
    not fast enough
cyberdiety
Did that and the last thing installed was the iogear card. Everything checked out fine after install. The system restore did not resolve the problem. It seems like a software problem because the devices work fine on other systems and when connected via USB. Also, the 1394 controller driver says it's working properly (yet no recognition of fw devices.)
Any other ideas?
    In-House Build
Everlong
To xor or not to xor
Does any of the hardware connected via Firewire get listed in device manager with a yellow triangle or anything?
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
cyberdiety
Negative. Device manager does not detect any anomalies. Texas Instruments 1394 controller driver says driver working properly. A yellow warning triangle would be nice because it would mean the system sees the device but can't start it for some reason. I can work with that.
    In-House Build
cyberdiety
Update; I reinstalled the hardware and reloaded the evga mobo drivers. I connected a generic consumer dv cam and the firewire 'fired' right up from all ports. The external harddrive and VTR are still not recognized despite changing cables and reinstalling the drivers. It's definitely a windows malfunction I just can't figure out what the cause is.
    In-House Build
cyberdiety
Problem Solved.
Vista is off the hook. We tried out a number of different firewire devices (now I've got to put them all back) and Vista recognized them all. Apparently the firewire inputs on the two devices got fried somehow. Still can't figure out how that happened since everything was properly disconnected and reconnected. That's an entirely other issue. So far, my positive assessment of Vista Biz remains firm.
    In-House Build
lordbob75
Lord of Bobs
Vista Pro
Interesting.... Sounds like a bad wire or hardware problem. Oh well, glad you got it working.
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
