Vista Business (x32) DVD drives disappear
PeterZ
MY CD / DVD drive just gone. I try copying a series of
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}]
on a pad with reg.run at the end but Im not sure how the registry read it. Someone post it a few years ago.
Anyone ?
If system Restore fails to fix the problem set a new restore point and try this.
press Windows key and R
Type regedit, and then click OK.
If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
In the navigation pane, locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
In the right pane, click Upper Filters.
On the Edit menu, click Delete.
When you are prompted to confirm the deletion, click Yes.
In the right pane, click Lower Filters.
Exit Registry Editor.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
