Vista Class Not Registered Errors
radxxryan
Hello,
Over the last few weeks, my Windows Vista laptop has occaisonally been very slow when doing things such as browsing with IE, taking a good 1-2 minutes to bring up my computer or other explorer windows, and taking longer than usual to shut down or restart. I checked for viruses and didn't come up with any.
I am running:
Windows Vista Home Premium
Service Pack 2
220GB HDD
3.00 GB of RAM
I did some research online, and several websites recommended to scan the registry for errors that might be causing the slow down. I used Reg Genie to scan and fix about 700 errors and it worked better after that. But now yesterday it acted up again so I used RegGenie again and it found over 800 errors, and I had also uninstalled a few programs earlier in the day.
After I fixed those errors, the browsing of the Internet was back to normal speed. Then I went to look in My Documents for some reason and a message box popped up and said:
explorer.exe: class not registered.
I've had this PC for over 2 years and have never seen this message before. And the only programs that load ok are IE, Firefox, MS Word and AIM. I can't access My Computer, Control Panel, My Documents, etc. I tried to go to system restore, it says: "A device attached to the system is not functioning" Same message when I try to run regedit. I also cannot get into RegGenie to undo the changes.
I get the feeling I might have to re-install the OS. But if anyone knows of something to try that might reverse this problem, I'd be greatly appreciated.
Thank you.
Thedarkside
You could try going to a command prompt and and running the SFC (system file check) command.
"sfc /scannow" i believe it is
    Toshiba Laptop A505 S6965
    Intel Core2 Duo P7350 2.0Ghz
    4Gb DDR2
    ATI Mobility Radeon HD 4570 (512MB)
    16in.
    1366x768
    500gig
    10Mb/896Kb
richc46
radxxryan
Thanks for the advice guys. Unfortunately my PC doesn't recognize sfc in the command prompt. I downloaded Malwarebytes, both by saving it to desktop and by just running it. When I just clicked run, it downloaded and then said:
ShellExecuteEx failed; Code 31
A device attached to the system is not functioning.
Should I try something in the BIOS; Safe Mode or something similar?
richc46
You probably did not do the sfc correctly. Read the manual, run as administrator, right click and run as administrator.
Once we know that the sfc checks out, there are several other tests we can make. We will figure this out.
