My mum has a Dell Inspiron 1525 with Intel 3945 A/B/B network adapter.
More towards the end of the day when she turns it on, the computer is stuck at identifying network. This is normally fixed by turning off the router and back on again. This causes problems for the 4 others who use the network.
I have tried a number of fixes e.g: windows update, swapping the network adapter with others, making sure the settings are correct...
During the day the computer is fine. So you know: this doesnt happen EVERY day there is not even a patern, it just happens.
My solution was changing the encryption to WEP and what do you know???
IT WORKS... BUT I dont want to use wep because it is easy to crack and cancels out the Wireless N features...
Also My Vista pc works fine BUT when at my friends house it is stuck with a yellow exclamation point by the network taskbar icon... It stays like this and i cant connect even though his room is 1 room away......
WINDOWS 7 and Mac works fine in both occasions...
Please help...
Please help...
- Custom Gaming Rig 780G
- AMG Athlon II X2 255 3.8/2MB/2500MHz 45nm AM3
- Gigabyte GA-MA78LMT-S2 AM3, Core Boost, Ultra Durable 3
- 2X 4GB Kingston DDR3 1066MHz @ 1666MHz Dual Channel
- Graphics Card(s)
- HIS HD Radeon 7770 GHz Edition iCooler Core: 1000MHz
- Realtek HD Audio
- Dell E2311H DVI/VGA 5ms response, Full HD
- 1920x1080 @ 60Hz
- 320GB Seagate Barracuda 7200.02 SATA II
- PSU
- Cooler Master Extreme Power Plus 700w
- Case
- Lian-Li PC-6010 With Side Window
- Cooling
- Aywun A4 80mm fan
- Logitech K120 Wired Keyboard
- Logitech K120 Wired Mouse
- 802.11B/G/N 17Mb/s
- Other Info
- AMD Catalyst 12.6
Thomson A/B/G/N Router
LiteON CD/DVD Player
GAME PERFORMANCE:
Battlefield 3: 41 FPS High 1x AA @ 1280x720
Mass Effect 2 and 3: 60 FPS Highest 4x AA @ 1920x1080
Counter Strike Source (and other Valve games):
300 FPS (max FPS in game) Highest settings 8x AA 16x AF @ 1920x1080!!!
