Vista Desktop Wallpaper Fit options, I thought there were 5 options?
lersince1991
When I used to change my wallpaper I had 5 options to fit the image to the screen, cant remember them exactly but they were something like; Stretch to screen, fit horizontal, fit vertical, centered, and tiled.
Why is it now that I only have; Centered, Tiled and stretch to screen?
Was this an update because this is really annoying!?
It was much easier to fit the wallpaper to screen without stretching it when I could fit horizontal and vertical?
Why can I not do this now? :mad:
Brink
Staff member
mvp
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
Dwarf
The Contemplator
Hi lersince1991 and welcome to the forums :party:
In the incarnations of Windows that I have used (Win 98SE, Win XP, Vista and, at work, Win 2000), there have ever only been the 3 options, viz 'Fit to screen', 'Tile' and 'Center'. I have never heard of the other options you mention - are you sure that they existed? Perhaps they were part of a 3rd party wallpaper sequencer/customiser.
Dwarf
I have just seen Shawns reply - the 3rd party program would appear to be 'DreamScene', which, since it only works with the Ultimate and I only have Home Premium version of Vista, would explain why I haven't heard of or seen the other options you mentioned.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
lersince1991
I am 100% sure that I had these extra fitting options and I don't recall installing additional software.
I am unsure of how dreamscene has relevance to this issue though?
I do have dreamscene installed but since my graphics card on my laptop cannot run it, I have disabled it in windows features.
So If I enable dreamscene again I will be able to use the extra options?
Is there a hack to get dreamscene to work on my graphics card lol, it worked in the beta a while back flawlessly. :)
Cheers
Dwarf
The Contemplator
Hi lersince1991,
If you re-enable DreamScene you should be able to use the extra options again. However, note the following (taken from 'Windows Vista In Depth'):
"DreamScene full-motion video wallpaper is an enjoyable addition to Vista Ultimate, but it requires a powerful 3D graphics card. Users with integrated laptop graphics or older discrete graphics cards with limited RAM or 3D rendering capabilities are likely to discover that DreamScene reduces system reponsiveness."
I would have suggested that you install a more powerful graphics card on your PC, but since it is a laptop that will not be possible (or extremely difficult if it is). Instead, make sure that you have installed the maximum amount of RAM that your laptop can take and check regularly for updates for your graphics driver as a more recent driver might mean the difference between being able to run DreamScene and not being able to.
Dwarf
    Gigabyte IF233
skunksmash
im coming for cake
Hi lersince1991
is this what you meant....??:)
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech cordless optical
    logitech EX110
    2mb
