Vista firewall inbound effectiveness
scottjms
2
Hello,
I was wondering how secure the windows Vista firewall is as far as inbound security. I currently have it set to block all incoming connections, however, when doing a port scan on it from inside my network, multiple ports showed as being there, although the PC itself did not show as being active (it does not respond to pings). I tried to telnet to a couple of the ports and didn't get any prompts, just a blank screen that eventually dropped me back to the command line, whereas a bad connection would tell me it can't connect. So I'm wondering why exactly they are showing up, and would someone be capable of connecting to them. I am just trying to get it nice and secure before I go hopping on any public wifi networks, because I know a few of them don't do client isolation. Thanks in advance for any help!
Scott
JayD
60
Location
North Lincolnshire
Im not an Expert on Windows Firewall in Vista but i Think you should have some rules set before you even think about Going on a public WiFi Hotspot. i know on mine ive had no problems but im not sure how ive set it up ive jsut trialed and errored with it to be perfectly honest. Vista does make it easy though. have a look and you might figure it out :)
    Acer 5630WLMi
    Intel Centrino Duo 1.66Ghz, 667MHz FSB, 2MB L2 Cache
    1x 2GB 800MHz DDR2
    Onboard 256 Intel Rubish
    Onboard Intel HD
    15.4" Crystalbrite
    160GB SATA
    N/A
    N/A
    N/A
    Laser Optical
    Laptop
    2.6mbps Download, Upload unknown (not tested)
scottjms
2
Hey, thanks for the reply. I wasn't on the computer in question when I made the post, so I was a little wrong in how I phrased things.
The option is block all incoming connections. Now, that sounds good to me, but like I said, it still shows up on a port scan, but I wasn't able to connect to any of the ports with telnet. I don't have any rules set, because I don't want anything coming in that I didn't ask for. I just rescanned it, and it still shows as being dead (not responding to a ping), but also lists open ports, there are about 5 shown as open, and that was just a scan of 1-1024.
247
Location
OR , USA
Sunbelt and ZoneAlarm are good free firewalls.Comodo also has a good one but its hard to find without the anti-virus bundle.
I was playing TF2 a 1st person shooter and these 2 brothers had like 900 pings :O I always try to help people out so I asked what with the pings ??? They said their WIFI got jacked a lot.They installed Comodo "I couldn't remember the others" and were like wow dude thx so much ! They had 100-120 pings / latency after that.
    gateway
    intel quad
    8 gig
    nvidia
    realtek
    19' widescreen
    1440 x 900
    581 gb
    High speed Comcast cable
