Solved Vista fonts have changed/messed up
samfau2
Hi there, earlier i realised that my vista default font is different, i.e. the font for icons, on dialog boxes and even in firefox etc have got bolder in places and also not as fine.
How can i restore the default fonts? Ive checked the appearance options and it still says they are Segoe UI (thats the default font right?)
Unfortunately ive got system restore turned off so no luck there.
Any help would be really appreciated.
Edit: heres a few pics:
Brink
Staff member
mvp
Hello Samfau,
While some programs will have their own font settings that will need to be changed instead, you might also check in Step One of OPTION ONE in the tutorial below to make sure it is set with the default font as well to see if that may help.
http://www.vistax64.com/tutorials/106279-fonts-change-default.html
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
kword88
Power User
that happens to me occasionally. some program or other changes my refresh rate from 60fps to 29fps. this causes all the text to look thick and "jaggy". i use a 46" LCD. if you use something similar, i would suggest checking the refresh rate.
let us know if you cant find the setting for it.
    Aleinware Area-51
    core 2 extreme x9000 2.8 Ghz
    4 Gig
    (2) Nvidia 8800m GTX in Sli
    Onboard RealTek
    42" JVC LCD HDTV
    1920x1080p 32 bit
    (2) seagate 7200rpm in RAID 0
    (1) maxtor external 1 terabyte firewire
    laptop
    logitech Anywhere Mouse and built-in touchpad
    a really spiffy backlit one that i can change color ;>)
    Cable
samfau2
Thanks for the responses but ive now fixed the problem.
I found that cleartype wasnt enabled so turning that on fixed everything! Woo
Brink
Staff member
mvp
Samfau,
I'm happy to hear that you got it sorted. :)
    Lumia 1520 phone
