Vista freezes at green start up bar/freezes for a few seconds on desktop
kickoutthejams
I've an Asus f5sl laptop with Vista Home Premium (32bit) but it's been freezing on me lately.
When I boot up, it gets to the black screen with the green bar but after a few seconds, the green bar freezes and I can't log in. Occasionally it boots up after around half an hour but then Vista periodically freezes for a few seconds before resuming (which is annoying when trying to write out something etc)
I don't see any problems in Safe Mode so is possibly a driver? I've updated all my drivers, completely updated using WIndows Update, ran antispyware, used System Restore etc
Only problem is; I've moved to a new country, and like a fool, I left my Vista start up disk back home. Which I would otherwise have tried.
Thanks
    Asus F5SL series laptop
    Intel Core Duo T5550 (1.83ghz)
    2GB
    ATI Mobility Radeon HD 3470
    Generic PNP Monitor
stoneys-nutz
Gamerholic
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    300 Gig Maxtor, (External)
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
kickoutthejams
Hey, thanks for the quick reply.
I tried running SFC (Start-Run-SFC and then Start-Run-SFC /scannow) but a black box appeared before disappearing almost instantly; is that suppsoed to happen?
    2GB
    Generic PNP Monitor
archie123
I Tunes hates Me
boot into safemode the hit start/acessories/run
in the box type msconfig then hit return
goto the boot tab
put a check in "os boot information" and "make all boot settings permanant"
hot apply then boot as normal
this will get rid of the green bar and instead show whats being loaded , when it freezes let us know what the bottom line of info says (may be information on a specific driver or service thats loading and causing it to freeze)
its a longshot but worth a look
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
stoneys-nutz
Gamerholic
Did you run it as administrator ?.
Go to start>all programs>accessories> and right click on command prompt and select run as administrator, give that a go.
Good luck and post your results, thanks.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
kickoutthejams
I checked the os boot information box and Vista said something about crcdisk before staying on a screen saying Microsoft Windows Version 6 Kernel 2 or something like that. When I got onto Vista, it kept freezing so much that I had to reboot in Safe MOde.
I've attached the results from the SFC.
    2GB
    Generic PNP Monitor
kickoutthejams
*bump*
Anyone able to help?
    2GB
    Generic PNP Monitor
