Vista hangs during startup
Barryco
I have built up a new system...been running perfectly since August 2008.
2 nights ago I had just finished an update to itunes and some other apple software which required a restart. Upon restart, the system hung while booting...didn't get to the user account log-in screen....it froze with a blackscreen with the mouse cursor sitting there in the middle.
I have done the following things and observed the following behaviour:
  • I have not added any hardware to the system
  • Windows Update has doing automatic updates
  • the systems boots and runs perfectly in safe mode with networking
  • I have reverted to a couple of different restore points prior to installing the apple software...no change
  • I have disabled all non-Microsoft software from starting up via Windows Defender...no change
  • I can get the system to boot to where it displays the user accounts login screen. When I click on an account and enter the password it will hang at that point. Mouse continues to respond but no further response. Disk drive light goes solid but no sound of the disk operating
  • If at the user account log in screen I select to shut the system down it will hang during shutdown
  • checking the event logs shows a range of various fatal errors....I can provide more info on this at later posts if needed but the messages look quite similar to other posts given for a range of different behaviours so I am not sure which if any are relevant.
  • Booting to the Vista CD and doing a repair found no errors.
In short, my perfectly happy and functioning system has suddenly gone mental for no obvious reason.
ANy suggestions greatfully appreciated.
    Home built
    Intel Core 2 Duo 8500
    Gigabyte
    4 Gb
    Integrated
    Integrated
    Samsung 19" LCD
    750 Gb Samsung
atl530i
Run memtest.
    Home Brew
    Intel E7200
    Gigabyte EP45-UD3P
    Kingston 4GB DDR2-800
    ATi Radeon HD3870 PCIe
    Creative Labs Audigy 2
    Samsung SyncMaster 940BW
    Seagate 7200.10 SATAII 250GB x2 RAID 0
    Western Digital 640AAKS
    Antec Neo550
    Antec P180
    Zalman 9500
    Logitech S510 Combo
    Logitech S510 Combo
    Comcast @ 10Mb
SIW2
Hi Barryco,
Seems the Apple updates have caused some damage somewhere.
The startup repair did not help, because the problem occurs after Vista has booted. System restore only restores the o/s settings to that point. Seems other applications/ drivers have been affected.
You could try a variety of things like checking drivers in device manager, uninstalling all apps. one by one to see which may have been corrupted, running SFC, analysing event log errors...
Or you could do a Repair install which takes just over 20 -25 minutes
http://www.vistax64.com/tutorials/88236-repair-install-vista.html
Hope it helps
SIW2
    Intel E8400
    ASRock1333-GLAN R2.0
    2gb DDR2 800
    nvidia 9500GT 1gb
Barryco
Thanks for the feedback.
SOme questions:
  • how do I run memtest?
  • What's SFC?
  • I can't uninstall the Apple apps because in safe mode when I try and deinstall them I get an error "The Windows installer service is not available in Safe Mode. Please try again when your system is not in Safe Mode or you can use System Restore to return your machine to a previous good dtate"
Re: System Restore I don't understand the earlier post. Isn't the whole point that it takes you to an earlier version of the systm? SO if I do a system restore to a time before I did the Apple updates, shouldn't the system be like the updates were never applied?
My head hurts....
Thanks
Barry
    Home built
    Gigabyte
    4 Gb
    Integrated
    Integrated
    Samsung 19" LCD
    750 Gb Samsung
SIW2
Hi Barryco,
Suggest you try going into safe mode by tapping F8 after the Bios screen ( black writing on white screen ) and before Windows loads.
Arrow down to Last known good configuration and press Enter.
Hope it helps
SIW2
    Intel E8400
    2gb DDR2 800
    nvidia 9500GT 1gb
bruce2
Vista Pro
If nothing above helps, you probably need to reinstall Vista. Hope you have backup your data. Good luck.
    E6850
    EVGA 122-CK-NF67-A1 680i
    4 x OCZ Platinum 1GB
    ATI Radeon HD 5850 1GB
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
Bare Foot Kid
R.I.P. August 13th 2014
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
Barryco
Alas SFC found no errors.
I think I will go for the repair install.
I'll let you know what happens.
Thanks again for the advice.
    Home built
    Gigabyte
    4 Gb
    Integrated
    Integrated
    Samsung 19" LCD
    750 Gb Samsung
Bare Foot Kid
Hello Barryco!
Thanks for the update; yes keep us informed!
Later :shock: Ted
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
Barryco
Well it's sorted out but I am not quite sure what happened.
I found that if I waited when the system appeared to hang at login it eventually came back and ran OK after 10 mins or so. At that point a window popped up to tell me that Windows Update needs me to shutdown.
AFter doinf the shutdown things are good.
I'm guessing that what happened was that Windows Update was in the middle of doing some damn thing and what I took for a hang was actually it doing its thing installing, cleaning up or whatever. I'm used to snappy response on my PC as it is a fairly high spec machine so I am not used to waiting for more than a second or two for anything.
I have now set it to download automatically but ask me to choose what I install so that I have somecontrol over the process.
Thanks to you all for your help.
Barry
    Home built
    Gigabyte
    4 Gb
    Integrated
    Integrated
    Samsung 19" LCD
    750 Gb Samsung
