Vista Home Prem. Toshiba Satellite A205 screen minimizes often for no reason!!Help!!
Weny40403
No matter what I am doing the window that I am working in minimizes when I click on a button just right. For example if I click near the edge of a button or on the scroll bar the window will minimize itself. I is VERY annoying I hope someone will respond, as I saw that someone else posted the same problem back in July but got no replies. Please someone help me out and don't leave my hang'n. :huh:
Thanks!
Wendy
    TOSHIBA SATELLITE A205-S6808
    intel Centrino
    Dolby Sound Room
    roadrunner broadband
rive0108
Re: Vista Home Prem. Toshiba Satellite A205 screen minimizes often for no reason!!Hel
I have researched this and every instance occurs with Toshiba.
This may be why:
Toshiba had "tap zones" enabled on the track pad..
If you tapped the corners or dragged in from the corners it did things like
minimizing windows.
You need to go into the mouse properties and look in the advance synaptic
properties and turn them off.
You can also uninstall the Toshiba-Synaptic software in Add/Remove Programs, restart computer and let Microsoft install the touchpad driver/software. This should fix your "corner tapping" issue. and still give full touchpad/tapping/vertical scroll functionality. (see below thumbnails)
    T7600G Core2Duo 2.66 Ghz
    Intel 945PM + ICH7 Chipset
    4GB DDR2 PC2-5300 667MHz
    Mobility Radeon x1900 256MB
    Realtek HD
    WUXGA 17"
    1920X1200
    640GB 7200RPM SATA/RAID 0 (2x320GB)
    and 320GB 7200RPM External
    Wireless Microsoft 3000
    10 mbps/2 mbps
    Optical Drive:
    Panasonic UJ-220 DL BD-RE (Blu-Ray)
rive0108
Does this resolve your issue?
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
    Optical Drive:
Fastboy42
Banned
I have a Toshiba Satellite,
If you don't want to uninstall the Toshiba Synaptic Touchpad driver, there should be an icon down in the bottom right corner of your screen,Right click properties then have a fiddle with the settings.I know that you can change the points on your touchpad which let you scroll and stuff.
Maybe this will help as well.
    Toshiba Satellite Pro l300
    Intel(R) Celeron(R) CPU 550 @ 2.00GHz
    Intel Corp. 88395664Q
    DDR2, PC2-5300 (333 MHz), 1024 MBytes, Hyundai Electronics,DDR2, PC2-5300 (333 MHz), 2048 MBytes, Ap
    Realtek HD Audio
    Matte screen
    1024 x 768 x 4294967296 colors
    120gb SATA 2.5inch FUJITSU MHZ2120BH G1 ATA Device
    Notebook
    Fan cooled
    Logitech Cordless Optical
    Logitech Cordless Desktop EX110
    256Kbps
    I like Spore,Rabbits and I'm a Computer Freak.
