Vista Home Premium keeps getting BSOD
ok. Im blonde, 52, and Female. That says it all. Just read what I got from Who crashed Out Put.
computer name: LAURA-PC
windows version: Windows Vista Service Pack 2, 6.0, build: 6002
windows dir: C:\Windows
CPU: AuthenticAMD AMD Athlon(tm) 64 X2 Dual Core Processor 4000+ AMD586, level: 15
2 logical processors, active mask: 3
RAM: 937177088 total
VM: 2147352576, free: 1979158528
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Mon 8/26/2013 6:34:13 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\Mini082613-02.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x4DD69)
Bugcheck code: 0x1000007F (0x8, 0xFFFFFFFF803D3130, 0x0, 0x0)
Error: UNEXPECTED_KERNEL_MODE_TRAP_M
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that a trap was generated by the Intel CPU and the kernel failed to catch this trap.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This problem might be caused by a thermal issue.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: ntkrpamp.exe (nt!Kei386EoiHelper+0x1736)
Bugcheck code: 0x7F (0x8, 0xFFFFFFFF803D3130, 0x0, 0x0)
Bug check description: This bug check indicates that the Intel CPU generated a trap and the kernel failed to catch this trap.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: ntkrpamp.exe .
Google query: ntkrpamp.exe UNEXPECTED_KERNEL_MODE_TRAP
On Mon 8/26/2013 3:34:27 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\Mini082613-01.dmp
This was probably caused by the following module: ntkrnlpa.exe (nt+0x4DECD)
Bugcheck code: 0xA (0xF18, 0x2, 0x0, 0xFFFFFFFF826AA705)
Error: IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\ntkrnlpa.exe
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
On Mon 8/26/2013 3:07:01 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\Mini082513-02.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x4DECD)
Bugcheck code: 0xA (0x800000F, 0x2, 0x0, 0xFFFFFFFF81EBFFB9)
On Sun 8/25/2013 2:46:39 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\Mini082513-01.dmp
This was probably caused by the following module: ntkrnlpa.exe (nt+0x98292)
Bugcheck code: 0x1A (0x41287, 0x3FFD0001, 0x0, 0x0)
Error: MEMORY_MANAGEMENT
Bug check description: This indicates that a severe memory management error occurred.
This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
Conclusion
5 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
ntkrpamp.exe
Ok so I have no Idea which driver to what software. I have ran Malware, Superanti, AVG, and they found a few things, but I ended up closing IE and downloading chrome cause IE wouldnt stay running. Chrome also shuts down but not every 10 min. Then it takes 10 min just for my computer to go to the desktop after it is turned on, IF ...it doesnt freeze or go to BSOD. Ok Help???
Also Playtopus was discovered on here, and PUP. I have no Idea if they are gone, I just uninstalled Platopus. Couldnt find it in registry tho.
    Gateway
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
I did do that yesterday afternoon. It did go to the blue screen. then I restarted it and wasnt sure what to do next. I disabled a few things also from start menu. AVG is what I disabled. But so far so good. No BSOD. When I play a game from FB it quits alot.
    Gateway
Ok today it did again while I was running a scan. I saw that it quit while scanning drivers. So I followed your reply, and it was different than what I did yesterday. This time it wouldnt boot up so I went into safe mode and disabled it. so now How do I know which Driver it is? I was able to scan my drivers and looked through the out dated ones. One is the motherboard. Hmmmm Hope I dont hurt anything if I update that friver. I had no idea they had drivers! I couldnt find the right number at the website. its 6150 LE Geforce. But it says 600 series. I did go there but it says used for windows 8 lol so confusing. I homeschool my daughter, so I need this Computer running right. Thank you for helping!
    Gateway
Hello??? Did you leave me???? Today my computer started right up. It didnt take 10 min. to load. Hmmm it has a mind of its own. But everytine I scan it, when it gets to drivers, it shuts down.Im not sure how to figure out which driver.
    Gateway
Try using a different antivirus. I don't like AVG. Many use microsoft security essentials.
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
I took off AVG. Never have liked that one. I have 3 computers now, all doing the same thing!!! I cleaned my Vista, but stupid me cant find CDs to restore it, so it is virtually BLANK!! The other 2 are XP and I took the AVG off and IE. They now work
    Gateway
