Vista machine not joined xp domain
jmorris
Hello all,
I've just spent the last day and a half reading forums, but no-one seems to have had the same problem as I have.
We've just bought a new vista business x64 machine to add to our existing network. All the other machines are running xp pro sp2. I've added the vista machine to the domain and logged in using my domain id. In the 'Network' folder I can see all the other machine names. So far, so good.
If I try and access one, however, I get one of two things:
1. A dialog asking for username and password. It doesn't accept anything I type in.
2. An error message saying the account is locked.
I can ping any of the xp machines, by name or ip and get a response ok.
Trying to access in the other direction, all is fine. From an xp machine, I can access any folder on the vista machine, make changes, everything. I've installed LLTD on one of the xp machines, so it appears on the full map thing, otherwise it has made no difference.
All folders have been set to 'Everyone full access'.
Any ideas?
z3r010
Staff member
    Windows 10
    me
    Asus RAMPAGE V EXTREME
    Creative
    6 @ 2560x1440
    3x 1TB Samsung Evo 840's
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Logitech Performance MX
    Surface Ergonomic.
    350 Mb/s
    WinTV NovaTD
    HP CP1515n Color Laser
    Microsoft LifeCam Cinema
    APC 750i Smart UPS
    windows 10
    Surface Pro 3
    Intel HD Graphics 4400
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
jmorris
Looked like a goer, but no joy. Still get the same thing.
Forgot to say above that we have a hardware firewall on the network, so all windows firewalls are turned off.
jmorris
Finally sorted the problem.
I found a Vista enterprise disc here, so I installed that. Still nothing.
Then I changed the LAN manager authentication level to 'send LM and NTLM - use NTLMv2 if negotiated' and that's fixed it. I'm sure I tried that yesterday. Perhaps it didn't go in or maybe you need to upgrade from business as well.
Anyway, it's all good now. Thanks for your help /z3r010
