Vista Network Gigabit Bandwidth degradation when audio is on.
Sebastiii
I have found a bug on 2 Pc(s) with Vista 64 and 32.
When i listen a sound (mp3, divx, dvd etc.) in windows -> the bandwidth become low.
I use iperf to see it and why i use this tool, it's because when i streaming from PC to my PC, it's work very well only if i disable the sound.
Without sound : the datarate is equal to 90Mbytes (my network is gigabit).
With sound if wmplayer, powerdvd, winamp etc. : the datarate is equal to 5.8Mbytes.
i see it too if i transfert file on net work, if no soft with sound is open -> All work done.
Thx for your help,
Sebastiii.
    Icore
    P6T Deluxe
    Kingston 3x2Go
    GeForce 9600GT
    Analog Device Soundmax AD1989b
    NEC 20" Wide
i found a solution :
Reports have been flooding the web that the network transfer speed of Windows Vista drops to a low level when the user plays music at the same time. While there does not seem to be a obvious connection between network transfers and sounds being played and everyone would probably consider other possibilities first it seems that a service called MMCSS, the Multimedia Class Scheduler Service.
Mark Russinovich described the technical process in his blog explaining that ‘when a multimedia application begins playback, the multimedia APIs it uses call the MMCSS service to boost the priority of the playback thread into the realtime range’ which basically means that every other thread - including network transfers - see a performance drop because of this.
The following method has been working for most users who experienced the slowdown in network traffic in Vista while playing music.
Don’t play music while transferring files. This is pretty obvious but probably not the best solution for most users
Remove the MMCSS dependency of Windows Audio in the registry. To do that navigate to the key HKEY_LOCAL_MACHINE \SYSTEM \CurrentControlSet \Services \Audiosrv, right-click the DependOnService string and remove MMCSS from it.
Solution @ Fix for slow Vista Network Transfer while playing Music
The fix involves editing the Registry to turn off Network Throttling. As always create a System Restore Point to backup your Registry, then follow the steps below.
Click the Start Orb and type Regedit in the search box.
Click Regedit.exe at the top of the search results under programs.
if you are prompted for an administrator password or for a confirmation, type the password, or click Continue.
Navigate to the following key
HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindows NTCurrentVersionMultimediaSystemProfile
In the right hand pane double click NetworkThrottlingIndex and type in FFFFFFFF (that’s 8 F’s) in the Hexadecimal field.
Click Ok and restart your computer for the settings to take effect.
@ How to Improve Network Performance in Windows Vista | Vista Revisited
Sebastiii
    Icore
    P6T Deluxe
    Kingston 3x2Go
    GeForce 9600GT
    NEC 20" Wide
