japanadian
I am having a problem starting a computer running Vista Home Premium 32-bit. It goes to the loading screen (the one with the green bars sliding towards the right) and goes to disk check. The disk check freezes when it gets to 61% and it freezes if I try to skip it.
Vista will not boot even in Safe Mode. When it gets to loading files it loads some and stops at crcdisk.sys. It won't go any further no matter how long I leave it.
The computer recently crashed and when I was trying to do a Factory Restore. I set it to save all the files on the computer and then reinstall Windows but it came up with an error and Windows would no longer load.
I got a USB HDD reader to check if any files were still on the disk, but there was nothing. One thing that I thought was strange:
When the computer freezes and I take a look at the hard disk light on the bottom of the laptop, it says that the computer is reading the disk (at least, it stays on) and blinks in a rhythmic pattern. But when I put my ear to the hard disk, it doesn't seem to be spinning at all.
If anyone has some advice, please let me know, as I need the computer up and running soon. Thanks in advance!
- TOSHIBA Satellite A200 -FEO
- Intel Centrino 2
- 1014MB
- 1280 x 800
- 250GB HDD
- Standard PS/2 Keyboard
- HID-compliant mouse, PS/2 Compatible Mouse
