Vista PC wont boot - need help to repair the BCD to load OS
cmberry20
Ok, heres what happened:
Vista got stuck on the loading splash screen with the green bar moving along the bottom. Left it for 15 minutes & didnt budge.
Reset the PC & tried again - same thing.
So, I booted of a recovery disk & ran CHKDSK /R.
Found a few errors & repaired them & rebooted.
Now, Vista didnt boot at all & i just got the message:
'Operating System Missing'
So, I booted from a Vista disk (Ultimate)
Chose repair but was greeted with an empty 'System Recovery Options' box.
Clicked next anyway & got to the repair menu.
Select 'Startup Repair' & it went off on its merry way for about 3 minutes but then reported back that there wasnt any operating system to repair.
So, went back to the repair menu & went opened up the Command Prompt.
Went through the usual boot repair methods:
bootrec /fixmbr
(this operation was completed successfully)
bootrec /fixboot
bootrec /ScanOS
(Successfully Scanned Windows Installations. Total Identified Windows Installtions: 1
[1] D:\Windows
This i thought was odd, why D: ? normally Vista is on C:
Anyway, carried on:
bootrec /rebuildbcd
(Successfully Scannec Windows Installations. Total Idenified Windows Installtions: 1
[1] D:\Windows
Add installation to bootlist? Y, N or All)
Selected Y & then got this error message:
'This Volume does not contain a recognized file system. Please make sure that all required file system drivers are loaded & that the volume is not corrupted'
bugger.
I evern tried this:
del d:\boot\ /f /s
bootrec /fixmbr
bootrec /rebuildbcd
got the same error.
I can see the harddrive fine. I can even browse the files & folders on the drive within Command Prompt, so its there & not corrupted.
I just cant fix the boot problem.
Anyone got any ideas?
btw - reformat or upgrading to Windows 7 is not viable at this moment in time.
Cheers
cmberry20
No, PC had been running fine for ~12 months plus.
Its not as if it has software added or changed as its a CAD workstation & only used for drawings & doesnt even have an internet connection.
Ashvin Busviah
when are you getting on the screen when you starting the computer?
Are you sure you have just run a repair and not actually tried a recovery and stopped it mid way??
cmberry20
I've tried a repair & it said that it couldnt repair the OS.
My issue at the moment is 'bootrec /rebuildbcd'
Its picking up the OS, but i get this message:
I think if i can solve this then i might be able to repair the boot loader.
Anyone know why i'm getting this error?
Cheers
btw, I guessing theres no repair option in Vista like there is in XP where I can reinstall Vista which repairs the installation but leave all the files, programs & users intact.
cmberry20
As i mentioned in my original post the start up repair didnt work.
I came to the conclusion that the boot part was completely borked, however, I dont let things like this beat me & i actually managed to fix the bleedin thing.
This is what i did.
Removed the HDD from the PC & plugged it into another Vista PC as a Slave/Secondary drive.
I then made a backup of the drive (the Windows Partition) using Acronis.
Next, I wiped the drive of all partitions so it resembled a new HDD.
I then completely cloned the PC drive that i was working on to the now blank HDD.
Once that was complete I restored the saved image back to the disk & plugged it back it to the original PC.
Had to do one more thing, which was boot of the recovery disk & do a quick repair in the System Recovery Options box & the PC reboot as good as new.
Bit of a long way round but at least i didnt loose any data etc.
