Solved Vista Save Power Mode
Computerjunkie
When ever i leave my computer idled for a long time the monitors turn black and i can't do anything but shut it down and start it up again. When i shut it down it says "Out of range input 1" Then i turn it off again and this time it has an error saying Vista didn't start up correctly, then i hit "start windows normally" then i can do stuff. How do i wake it up without shutting it down. Thanks
VaguelyRapt
Electrosexual
Power User
It's some sort of issue with the screen resolution/other graphics compatibility issues. Did you recently install something new graphics related? New graphics card? New monitor? Change resolution?
If you have the patience, try lowering your screen resolution and wait for the problem to happen just to see if it's a resolution issue.
    HP dv5-1120ej Notebook PC
    Intel Dual 2.16GHz
    NVidia GeForce 9200M GS, 256MB
    320GB internal, 320GB external, 1TB external to come (big download library XD)
    Fast enough
    Firefox, Foobar, and AutoHotkey! Go open source!
