Vista SP1 Instal Fails Everytime
SSSCMike
2
Hello, I have tried installing Windows Vista SP1 roughly 8-10 times now, with no luck any time. It always gets to 98% complete on the first stage, then sits there for awhile before reverting, rebooting, and trying again.
First time I got error code 0x800F0826, and Microsoft directs me here: Error message when you try to install Windows Vista Service Pack 1: "Installation was not successful" or "An internal error occurred while installing the service pack"
None of the resolutions work.
Then I got this message a few times 0x800705B4
Which I have read is a "Timed out" error.
Its always at 98% on stage 1 of 3 that it hangs up before it fails and reverts.
I have given my manufacturer remote access to my PC, they re-registered the windows update dll files, removed any pending/queued updates that may have been causing it to fail(which also cleaned out my update history) and had me download a file titled Windows6.0-KB936330-X86-wave0.exe from Microsoft.
Still no luck, same errors, same time of the install. I have also download and burned to a disk the .ISO file Microsoft has to download of SP1, with no luck still, again same errors at the same time.
If someone could help, it would be much appreciated.
Here is some information from my computer I think might be useful, let me know how to get more of what you need to know if there is any.
Code:
[B] System Information[/B]
[B] Time of this report:[/B] 5/3/2008, 23:13:54
[B] Operating System:[/B] Windows Vista™ Ultimate (6.0, Build 6000) (6000.vista_ldr.071023-1545)
[B] Language:[/B] English (Regional Setting: English)
[B] BIOS:[/B] Phoenix ROM BIOS PLUS Version 1.10 A02
[B] Processor:[/B] Intel(R) Core(TM)2 Extreme CPU Q6850  @ 3.00GHz (4 CPUs), ~3.0GHz
[B] Memory:[/B] 3326MB RAM
[B] Page File:[/B] 1478MB used, 5346MB available
[B] Windows Dir:[/B] C:\Windows
[B] DirectX Version:[/B] DirectX 10
[B] DxDiag Version:[/B] 6.00.6000.16386 32bit Unicode
[B] Display Devices[/B]
[B] Card name:[/B] NVIDIA GeForce 8800 GTX
[B] Manufacturer:[/B] NVIDIA
[B] Chip type:[/B] GeForce 8800 GTX
[B] Display Memory:[/B] 2139 MB
[B] Dedicated Memory:[/B] 732 MB
[B] Shared Memory:[/B] 1406 MB
[B] Current Mode:[/B] 1680 x 1050 (32 bit) (60Hz)
[B] Monitor:[/B] Dell E228WFP
[B] Driver Name:[/B] nvd3dum.dll,nvwgf2um.dll
[B] Driver Version:[/B] 7.15.0011.6925 (English)
[B] Disk & DVD/CD-ROM Drives[/B]
[B] Drive:[/B] C:
[B] Free Space:[/B] 684.0 GB
[B] Total Space:[/B] 938.5 GB
[B] File System:[/B] NTFS
[B] Model:[/B] ARRAY
[B] Drive: D:[/B]
[B] Free Space:[/B] 5.4 GB
[B] Total Space:[/B] 15.4 GB
[B]
Drive: E:[/B][B]
Model:[/B] TSSTcorp CDRWDVD TS-H493B
[B]
Drive: F:[/B][B]
Model:[/B] Optiarc DVD+-RW AD-5170S
[B]
Drive: K:[/B][B]
Model:[/B] PK1444Z QJT184U SCSI CdRom Device
    Intel Core 2 Extreme Q6850
    4GB DDR2
    NVIDIA 8800GTX
    1TB Main
    15GB Backup
Pete B
7
Hmm, I did not see your thread when I posted mine. I have the same problem except I actually get all the way through the whole thing and the PC does the final restart and it reverts when it loads into Windows.
1,351
Location
Canada
Code:
[B]System Information[/B]
[B]Time of this report:[/B] 5/3/2008, 23:13:54
[B]Operating System:[/B] Windows Vista™ Ultimate (6.0, Build 6000) (6000.vista_ldr.071023-1545)
[B]Language:[/B] English (Regional Setting: English)
[B]BIOS:[/B] Phoenix ROM BIOS PLUS Version 1.10 A02
[B]Processor:[/B] Intel(R) Core(TM)2 Extreme CPU Q6850  @ 3.00GHz (4 CPUs), ~3.0GHz
[B]Memory:[/B] 3326MB RAM
[B]Page File:[/B] 1478MB used, 5346MB available
[B]Windows Dir:[/B] C:\Windows
[B]DirectX Version:[/B] DirectX 10
[B]DxDiag Version:[/B] 6.00.6000.16386 32bit Unicode
[B]Display Devices[/B]
[B]Card name:[/B] NVIDIA GeForce 8800 GTX
[B]Manufacturer:[/B] NVIDIA
[B]Chip type:[/B] GeForce 8800 GTX
[B]Display Memory:[/B] 2139 MB
[B]Dedicated Memory:[/B] 732 MB
[B]Shared Memory:[/B] 1406 MB
[B]Current Mode:[/B] 1680 x 1050 (32 bit) (60Hz)
[B]Monitor:[/B] Dell E228WFP
[B]Driver Name:[/B] nvd3dum.dll,nvwgf2um.dll
[B]Driver Version:[/B] 7.15.0011.6925 (English)
[B]Disk & DVD/CD-ROM Drives[/B]
[B]Drive:[/B] C:
[B]Free Space:[/B] 684.0 GB
[B]Total Space:[/B] 938.5 GB
[B]File System:[/B] NTFS
[B]Model:[/B] ARRAY
[B]Drive: D:[/B]
[B]Free Space:[/B] 5.4 GB
[B]Total Space:[/B] 15.4 GB
[B]Model:[/B] ARRAY
[B]Drive: E:[/B]
[B]Model:[/B] TSSTcorp CDRWDVD TS-H493B
[B]Drive: F:[/B]
[B]Model:[/B] Optiarc DVD+-RW AD-5170S
[B]Drive: K:[/B]
[B]Model:[/B] PK1444Z QJT184U SCSI CdRom Device
Hello,
I searched the Knowledge Base, and 0x800705B4 applies to 4 catagories, but only 1 is remotely applicable. The code is for Windows Vista Beta2. It doesn't make sense at all.
SSSCMike
2
I have spent the better part of my day on chat with Microsoft to try to resolve this.
They took remote access to my PC on multiple occasions and tried the following.
Uninstalled my Anti-Virus and Firewall
Reboot.
Start->Run->MSConfig
Through MSConfig under Services click "Hide all Microsoft Services" then select Disable All.
Under the Startup tab, select "Disable All", then click Apply and OK.
Reboot, then try the install.
Still no luck, hangs up on 98%.
Then through another remote access session, they tried the following.
They created a batch file called registry.bat which contained the following
Code:
net stop cryptsvc
net stop wuauserv
ren %windir%\system32\catroot2 catroot2.old
ren %windir%\SoftwareDistribution SoftwareDistribution.old
regsvr32 comcat.dll /s
Regsvr32 Msxml.dll /s
Regsvr32 Msxml2.dll /s
proxycfg -u
Regsvr32 Msxml3.dll /s
regsvr32 shdoc401.dll /s
regsvr32 cdm.dll /s
regsvr32 softpub.dll /s
regsvr32 wintrust.dll /s
regsvr32 initpki.dll /s
regsvr32 dssenh.dll /s
regsvr32 rsaenh.dll /s
regsvr32 gpkcsp.dll /s
regsvr32 sccbase.dll /s
regsvr32 slbcsp.dll /s
regsvr32 mssip32.dll /s
regsvr32 cryptdlg.dll /s
regsvr32 wucltui.dll /s
regsvr32 shdoc401.dll /i /s
regsvr32 asctrls.ocx /s
regsvr32 oleaut32.dll /s
regsvr32 shdocvw.dll /I /s
regsvr32 shdocvw.dll /s
regsvr32 browseui.dll /s
regsvr32 browseui.dll /I /s
regsvr32 msrating.dll /s
regsvr32 mlang.dll /s
regsvr32 hlink.dll /s
regsvr32 mshtmled.dll /s
regsvr32 urlmon.dll /s
regsvr32 plugin.ocx /s
regsvr32 sendmail.dll /s
regsvr32 scrobj.dll /s
regsvr32 mmefxe.ocx /s
regsvr32 corpol.dll /s
regsvr32 jscript.dll /s
regsvr32 msxml.dll /s
regsvr32 imgutil.dll /s
regsvr32 thumbvw.dll /s
regsvr32 cryptext.dll /s
regsvr32 rsabase.dll /s
regsvr32 inseng.dll /s
regsvr32 iesetup.dll /i /s
regsvr32 actxprxy.dll /s
regsvr32 dispex.dll /s
regsvr32 occache.dll /s
regsvr32 occache.dll /i /s
regsvr32 iepeers.dll /s
regsvr32 urlmon.dll /i /s
regsvr32 cdfview.dll /s
regsvr32 webcheck.dll /s
regsvr32 mobsync.dll /s
regsvr32 pngfilt.dll /s
regsvr32 licmgr10.dll /s
regsvr32 icmfilter.dll /s
regsvr32 hhctrl.ocx /s
regsvr32 inetcfg.dll /s
regsvr32 tdc.ocx /s
regsvr32 MSR2C.DLL /s
regsvr32 msident.dll /s
regsvr32 msieftp.dll /s
regsvr32 xmsconf.ocx /s
regsvr32 ils.dll /s
regsvr32 msoeacct.dll /s
regsvr32 inetcomm.dll /s
regsvr32 msdxm.ocx /s
regsvr32 dxmasf.dll /s
regsvr32 l3codecx.ax /s
regsvr32 acelpdec.ax /s
regsvr32 mpg4ds32.ax /s
regsvr32 voxmsdec.ax /s
regsvr32 danim.dll /s
regsvr32 Daxctle.ocx /s
regsvr32 lmrt.dll /s
regsvr32 datime.dll /s
regsvr32 dxtrans.dll /s
regsvr32 dxtmsft.dll /s
regsvr32 WEBPOST.DLL /s
regsvr32 WPWIZDLL.DLL /s
regsvr32 POSTWPP.DLL /s
regsvr32 CRSWPP.DLL /s
regsvr32 FTPWPP.DLL /s
regsvr32 FPWPP.DLL /s
regsvr32 WUAPI.DLL /s
regsvr32 wups2.dll /S
regsvr32 WUAUENG.DLL /s
regsvr32 ATL.DLL /s
regsvr32 WUCLTUI.DLL /s
regsvr32 WUPS.DLL /s
regsvr32 WUWEB.DLL /s
regsvr32 wshom.ocx /s
regsvr32 wshext.dll /s
regsvr32 vbscript.dll /s
regsvr32 scrrun.dll mstinit.exe /setup /s
regsvr32 msnsspc.dll /SspcCreateSspiReg /s
regsvr32 msapsspc.dll /SspcCreateSspiReg /s
proxycfg –d
sc sdset wuauserv
D:(A;;CCLCSWRPWPDTLOCRRC;;;SY)(A;;CCDCLCSWRPWPDTLOCRSDRCWDWO;;;BA)(A;;CCLCSWLOCRRC;;
;AU)(A;;CCLCSWRPWPDTLOCRRC;;;PU)
regsvr32 mshtml.dll /s
net start cryptsvc
net start wuauserv
Then ran that file as administrator.
Downloaded a file from Microsoft.com titled "subinacl.msi" installed it, created a command file called "reset.cmd" which contained the following
Code:
@echo off
title Resetting ACLs...
cd /d "%ProgramFiles%\Windows Resource Kits\Tools"
echo.
echo Resetting ACLs...
echo (this may take several minutes to complete)
echo.
echo ==========================================================================
echo.
echo.
subinacl /subkeyreg HKEY_LOCAL_MACHINE /grant=administrators=f /grant=system=f
echo.
echo.
subinacl /subkeyreg HKEY_CURRENT_USER /grant=administrators=f /grant=system=f
echo.
echo.
subinacl /subkeyreg HKEY_CLASSES_ROOT /grant=administrators=f /grant=system=f
echo.
echo.
echo System Drive...
subinacl /subdirectories %SystemDrive% /grant=administrators=f /grant=system=f
echo.
echo.
echo Windows Directory...
subinacl /subdirectories %windir%\*.* /grant=administrators=f /grant=system=f
echo.
echo.
echo.
echo FINISHED.
echo.
echo Press any key to exit . . .
pause >NUL
Ran that as administrator, let it run and finish up.
Ran msconfig again, turned off all services that were not Microsoft, shut down all Statup processes, then reboot.
After that I was told to try again, so I proceeded to try again. Still no luck, hangs up at 98% before reverting itself.
At this time, their hours of service are over, so I cannot contact them again.
End result is, I still have the problem, SP1 is not installed, and I have no anti-virus or firewall at the moment. But maybe those steps will work for someone else.
    4GB DDR2
    NVIDIA 8800GTX
    1TB Main
    15GB Backup
vijayl
6
hmmmm sounds like you been having fun. Vista sp1 when it works corrupts some files after awhile so you often need to remove it then you cannot reinstall it. As regards microsoft support they took a month to help me update to vista sp1 and then i had to take it off. Just a tip if it does not work ignore the error messages and do a repair installation as shown in the tutorials it works but it is a pain as it has to reinstall all the updates. Also keep an eye on the updates that fail some of those are critical for vista sp1. Finally when you have sp1 on make the dvd as shown in the tutorials that way wont have to reinstall sp1 when it finds a way to muck itself up again.
SIW2
2,741
#8
if you have the MS dvd making a slipstream SP1 version and installing using that is often a good idea.
http://www.vistax64.com/tutorials/151606-vista-sp1-slipstream-installation-dvd.html
Or you could try downloading the SP1 from MS site, instead of using the Windows update.
32bit
Download details: Windows Vista Service Pack 1 Five Language Standalone (KB936330)
64bit
Download details: Windows Vista Service Pack 1 Five Language Standalone for x64-based Systems (KB936330)
If you are in the UK, there is currently a special Vista edition of Computeractive on the newsstands that comes with a dvd including SP1 not sure if it's both bit versions, tho.- if you have trouble with the download.
Hope that helps
SIW2
    Intel E8400
    ASRock1333-GLAN R2.0
    2gb DDR2 800
    nvidia 9500GT 1gb
1,823
#9
Redownload SP1. Use the network installation version. Uninstall your firewall and anti-virus software. Uninstall your video drivers. Use a PS/2 mouse and keyboard. Remove USB and USB 2 devices. Enable your administrator account. try again.
    16GB DDR667
    SAS RAID
fieseler
543
Location
Leicester
#10
Try installing the using sp1 stand alone installer from microsoft download center
or
http://www.microsoft.com/windowsvista/1033/ordermedia/support/default.mspx
you can order a replacement dvd with sp1 already on it if you have the retail version of vista. I decided to reinstall once i got the new dvd & my pc seems to like it better than installing from windows update.
    §ĮŁΣNŦ Д$$Д$$ĮN
    Xeon X3360
    P5W64 WS Pro
    EVGA Geforce GTX470 SC+
    Samsung T200
    WD 1TB RE3
    Thermaltake Toughower 750w
    NZXT Lexa Silver
    Zalman CNPS10x Extreme
    Razer Deathadder 3500dpi
    Razer Lycosa Mirror
    24Mb/s
