You should upgrade or use an
alternative browser .
Vista Ultimate x64 SP1 Memory Question
I recently upgraded my laptop to Vista Ultimate x64 SP1.
I have 4GB of memory and the System screen reports that (it did not prior to SP1).
However, when I look a the physical memory report in Task Manager it still only says 3072 which is 3GB.
What is the deal with that?
I upgraded to the 64bit OS so I could use all of my memory but if it isn't going to use it, then I am going to Ghost back to my 32bit OS.
Gateway
Intel Pentium 2 Core Duo 2GHZ
ATI Radeon Mobile X1400
WD 500GB
in your bios there should be a 'memory remap' feature that you need to enable on some motherboards
check your bios thoroughly for it.
§ĮŁΣNŦ Д$$Д$$ĮN
Xeon X3360
P5W64 WS Pro
EVGA Geforce GTX470 SC+
Samsung T200
WD 1TB RE3
Thermaltake Toughower 750w
NZXT Lexa Silver
Zalman CNPS10x Extreme
Razer Lycosa Mirror
Razer Deathadder 3500dpi
24Mb/s
Hello RBonser, welcome to Vista forums!
If you have integrated graphics and not a separate graphics card; it has first access to the RAM.
Keep us informed!
Later
Ted
* BFK Customs *
Intel C2Q 9550 Yorkfield
ASUS P5Q Pro
8GB Dominator 8500C5D
XFX ATI 1GB 4870 XXX
Realtek HD 7-1
1920x1080P & 1920x1200
Corsair 620HX
CM Cosmos RC-1000
HP Enhansed Multimedia
Razer Diamondback 3G
18.6Mb/s
My First Build ;)
I do have an integrated video board (ATI).
If the case is then that it still will only use 3GB then is there any reason I should stay with 64bit?
Gateway
WD 500GB
Hello again.
You might as well; the 32-bit won't have access to it either.
Later
Ted
* BFK Customs *
ASUS P5Q Pro
Realtek HD 7-1
Corsair 620HX
CM Cosmos RC-1000
18.6Mb/s
My First Build ;)
To be clear, are you saying that I should or should not just run 32bit Vista?
Gateway
WD 500GB
Hello again.
To me it makes more sense to stay with 64-bit; unless you have apps/progs that can't run in the 64-bit environment.
Later
Ted
* BFK Customs *
ASUS P5Q Pro
Realtek HD 7-1
Corsair 620HX
CM Cosmos RC-1000
18.6Mb/s
My First Build ;)
I actually already ghosted back to my 32bit install.
I found that things did not work well for be in 64bit.
IE7 crashed a lot more. Firefox had problems with Flash. Most of all, I did not notice any real performance increase to justify having to deal with making sure I found 64bit versions of software.
I may install it on another hard drive to play with but I think I am sticking with 32bit until 64bit becomes a lot more mainstreme (probably with Windows 7)
Thanks for your help though.
Gateway
WD 500GB
Hello again.
You're welcome; I'm pleased you've found a solution that works for you.
You may want to visit the new
Windows Seven Forums at this link.
Later
Ted
* BFK Customs *
ASUS P5Q Pro
Realtek HD 7-1
Corsair 620HX
CM Cosmos RC-1000
18.6Mb/s
My First Build ;)
